    343
  1. Nope. Ford hasn't provided this at all in recent memory. Even with a gauge it only tells you whether it's within normal range or not - not the actual temp. You may be able to get it with an obd-II scanner.
  2. You can't but the dealer can. It's called OASIS.
  3. Not sure if all Edges came with Sync or not but most did for sure. If it did there should be a Sync powered by Microsoft badge near the radio. It is standard with MFT.
  4. According to what I've seen on other forums: 1 - no but you can download the software yourself using the link in the TSB. I'll try to post it if I can find it. You'd still have to go to the dealer for a new card I presume. 2 - no 3 - yes - response is reported to be much better and much faster with improved voice recognition
  5. What Waldo is saying is there is no inherent delay in the throttle electronics - the delay is in the PCM so changing the throttle itself won't help much because it won't override the PCM.
  6. It's called Accessory delay and it works the radio, windows, etc. for 10 minutes after turning off the ignition until the door is opened. Just use accessory mode if you want to leave it on longer.
  7. I'll ping Robert Lane to check this thread. It's up to him.
  8. If you only have one working key you can't do it yourself - has to go back to the dealer. This is for your safety so a valet can't clone a key to your vehicle using just the one key.
  9. There's a term for that in the old telephone world. CCWT - came clear while testing
  10. The point was that the buyout is really just a guess based on the estimated residual value at the time of lease. It may or may not be the current wholesale price 2 or 3 years later. The market can change. Sometimes the buyout is cheaper than the current market and sometimes it's more expensive.
  11. You can use it with X plan. Everything you buy is "dealer stock" - that phrase used to mean that you only get the incentives when the vehicle is delivered regardless of whether you order or buy off the lot. But now Ford offers incentive protection so you can usually get either the incentives at time of order or when it arrives.
  12. It could be your ipod. Can you try a different mp3 player?
  13. Either the card works or it doesn't so if it works you're ok.
  14. This was for the new software a few months ago. It came from Ford with a new SD card for nav maps. If you already got the updated nav sd card you should be ok.
  15. akirby
    Gas Cap?
    The capless system has an anti-siphon feature.
  16. akirby
    Gas Cap?
    A Ford capless system got siphoned or a regular capped system?
  17. Ford switched from 5W-30 to 5W-20 specifically for better fuel economy. Although it wouldn't be more than a few tenths of a mpg. Although if they used 10w-40 that might be more noticeable (and detrimental).
  18. akirby
    Gas Cap?
    Most people like it and don't have any problems with debris.
  19. If premium fuel helped then there is something wrong with the engine.
  20. What type of kit and for what purpose (looks, shorter stopping distance, etc.)
  21. You may have a bad shifter that's simulating a button press even when you haven't pressed anything.
  22. It probably just doesn't allow spaces in the name.
  23. akirby
    Fuel Additives?
    Some components are sensitive to certain chemicals. Some may be fine others may not be so they just recommend against it. Use it at your own risk.
