Everything posted by NatG
P0456 - Evaporative Emissions System - Small leak detected
NatG replied to EdgeGermany's topic in 3.5L
It's interesting: I just started to have my CEL come on, and I had a reading on the code and it was for the EVAP system (specifically P0456). There are several codes for the EVAP system, and while some indicate it can be a fuel "cap" issue (capless fuel system on newer Edges), the P0456 seems to be one code that indates the fuel cap is not the issue (read this link: http://www.obd-codes.com/p0456) So, I popped open my Haynes (Page 6-22) manual and found some images that help locate the EVAP system. For me, the connections on the bottom of the car have a protective cover. This cover was damaged on my car (likely a result of parking in some of the snow we had here in NJ), and I was able to find my problem. I know you posted this some months back, and you may have found a resolution, but I figured you would still like a response (and possible course of action). I couldn't upload the image to this site, so I am linking ot the image on a free hosting site. Hopefully it sticks around. -
Cracked Driver's side window
NatG replied to NatG's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Had the Edge garaged for a bit. Just getting around to getting the window guy. $265 plus tax for the repair (including part). -
I appreciate the feedback, guys. @WWWPerfA_ZN0W: That was my though at one point. It would make the most sense given the circumstances. @omar302: I had a friend who claimed that the a window in his Accord blew out because of the heat in the car generating pressure against the glass. I thought it was rediculous, just for the reason you outlined (it's much warmer in other parts of the world). But I do think the heat is making the crack worse, as the crack spread another inch when the car was just sitting. @akirby: Yeah, $300 was what I was expecting. My deductable is less: it is something to consider to have my provider cover it. -
So the car is a 2011 Ford Edge Limited, Bordeaux Red, black leather. I've been lucky when it comes to windows in cars: I've had chips in windshields, but I have never had any damage to the door windows. I come out of a meeting for my job, and there it is: cracked window. There's no sign of impact on the door, and the glass feels smooth. So as far as I know, there's no impact to the window itself. The crack starts from under the door sill and goes halfway up the window. The crack has become marginally worse since discovery. It's been hot here in NJ, and I can only guess that it's the pressure from the car's interior heating up. I normally do not, but I have the windows cracked to allow the pressure to dissipate. So my questions to the form are as follows: 1) Any idea what the cause might be? Is it possible that the pressure from the heat in the car cracked it? 2) Do I have to worry about the window shattering while driving (or in general)? 3) What should I do until I can get it repaired? (I have already put blue masking tape on the window over the crack). 4) Any estimate on cost to repair from a shop? Thanks guys!
From my experience, it's best to go by the tire. I have the Michelons on my Edge. MAX cold PSI is 44. So When they are cold, I fill between 38 and 40 PSI. I find the shape of the tire is best at this rating, it sits nicely on the ground, and the ride is better than lower pressures. I do not drive super aggressively, and I have about 37,000 on the car with a pretty generous amount of tread left (original tires). Make sure to Rotate regularly.
Please ..what fuel type recommended for Edge 2013
NatG replied to EdgeLimit13's topic in Owner Impressions
I ran a few tanks with higher octane. Some improvement in engine response: nothing really worthy of keeping up with premium gas, but it's there. Mileage, on the other hand, didn't seem any better. Seemed to go down a bit, but that might have had to do with giving the car more gas to feel the difference. -
Great looking car. Good luck with the new ride!
Wow, that's cheap. May order this today. Thanks Dingo!
I would think maybe the PTU in the AWD system. Does the sound go away at a particular speed?
Nice with the brakes, Dingo... ...I'm jealous of your no-prop hood.
I'm not taking sides with the SHO versus Mustang here. The Mustang is a lighter sports car designed for speed, where as the Taurus SHO starts as a family sedan and becomes a straight-line-fast Sedan. However, with a decent tune, I'd bet you can close that horsepower gap quickly and have a stronger motor than the 5.0 hands down. And a tune that would probably cost less than $1000 at that. But power to weight is the key, that Mustang will go faster with less power. Period. I like the SHO, ALOT, my friend has one and it's fun for its size. But even the Charger Hemi ties the SHO when both are stock, and those are both full size sedans with AWD (available in the Charge, standard on SHO). Throw a V8 with Similar power in a smaller car and you're leaving the SHO in the rear-view mirror. And the warranty is a valid point, KingMike.
I'm with Brock. My brother's car was totalled and it never reflected that in Carfax. And when I say totalled, I don't mean "too much damaged to justify repair costs" (which I am sure is true), the car was a wreck. Then my friend's car was destroyed in flooding, for giggles we looked it up: NOTHING noting the water damage, and the car has a new owner. Buyer Beware. If you buy used, take it to a trusted body shop.
2200 mile roud?! Hope you got a coffee maker in that Edge.
Yeah, I have the Michelin's on mine. Great tire. Works great in the weather, too.
JL Audio Stealthbox Finally Here
NatG replied to Brock79's topic in Audio, Backup, Navigation & SYNC
I don't think he "lives on the forum." Obviously he frequents it, but his knowledge comes from experience and I've found his advice to be helpful. -
Check the front passenger seat. If you have leather, it moves just a bit without a passenger seated. And I may make a rattle noise. You can test it by putting you arm on it to steady it while driving on a bumpy but empty street.
Left turn by a chance? Even brand new, it sould be wheel alignment, could be a new tire. My Edge is great, but if I pull a sharp left with medium throttle it seems to vibrate a bit. Nothing alarming. Though I think it really only does it when the weather is wet.
With my 2011 V6 AWD limited, mixed driving lands me around 22mpg (combined). Occasionally I take a 2.5 hour trip for work, and even going 75 I'll pull around 25mpg (If I slow it down, it's a bit higher). But the "Average" will always be reduced with local driving. There are so many variables in what effects mileage: altitude, season (winter, spring, etc), load, speed, tire pressure, and some other factors. I'd even imagine that getting certain content packages might effect aerodynamics and weight to some degree. I think it's easy to lose sight that this is a 4200lbs car with alot of ground clearance given the drive. For me, the mileage was much better than my previous vehicle (Nissan Xterra).
I can't say the lack of a light in the glove box bothers me. The map lights are located in such a way that they illuminate the box, anyway. Not that I have much in my glove box: a can of cleaner for the interior, and gloves (how unexpected). On the occasion I want to store something securely, though, it does bother me that the Edge does not have a locking glove box.
I've actually found Dingo to be rather helpful, and would be interested in seeing a post where he is wrong. I'm not saying he's never wrong, but he seems to generally be on point. He corrected something I posted once, and I didn't take it to heart. With almost 1500 posts to Dingo's credit, I'd go as far to say that he's a good contributor to the board. -
"No Key Detected" and Car Won't Start
NatG replied to Shockwavesix's topic in Alarms, Keyless Entry, Locks & Remote Start
Dingo, great find. I've wanted to get something for my Key-Fob. -
New owner 2010 Edge SEL, but starting to wonder if I made a mistake.
NatG replied to JoeR's topic in Welcome Forum!
Regarding the AC issue, I'd suggest you write Ford and present your case. I think they'd give you a grace period to get that work completed. You should have the Microphone inspected or replaced ASAP. -
Is that home made, Dingo? Really nice install.
If aesthetics is your main goal, go with with the recommendation of Exodus. Personally, I purchased a cargo blanket from HomeDepot for $25. I never have anything wet in the car, but I do move alot of relatively large items and it protects the interior very well. You can also use the blanket to wrap more sensitive items (mirrors for example).
