fishx65
    24
Everything posted by fishx65
  1. My dealer handed me a new one for my 2011 when it was still under warranty a few years ago but I have not put it on yet. It's kinda sad that the part Ford uses to advertise their name brand is a piece of corroding junk. I'll take a better look at the old emblem when I swap it out to see if there's any way to prevent these from peeling and corroding.
  2. Go sit in the corner and hang your head in shame!!!!! The 2016 MKX's are really nice!!!!!
  3. I don't have the key problem but I do get the dinging problem from time to time in my 11 SEL. Very random so not to worried about it.
  4. I put a film of caliper grease on the slides and ears because it's the way I've always done it. I almost wonder if greasing the slides is a good idea because of the sand and dirt attraction factor. It wouldn't take much time to clean them up once per year so I'll probably just make that my game plan.
  5. Did you guys notice any strange wear on your front pads when you changed them? I just did mine today and the inside pads on the fronts were almost gone but the outsides were OK. The drivers side outer pad looked brand new. Thought it was kinda strange because nothing was seized when I disassembled them and the pistons went in just fine. I ended up having the rear rotors turned but went with new ones up front. Mac, thanks again for the info on how to remove the rear sound dampeners cuz it probably saved me some stripped bolts.
  6. Another great vid Mac and great job figuring out the problem!!!! I also just watched your rear brake vid and it really helped me get prepared for doing the rear brakes on my 2011 next week. I've done brakes on all my vehicles for years but never had to deal with the screw in pistons on the rear calipers. Gonna be a heck of a lot easier then dealing with the drum style parking brakes!!!!!!!
  7. I once had a set of Firestone Turenza's balanced 3 or 4 times before the shop figured out that 3 of the tires were out of round. In your case, I would assume they've already checked for this.
  8. 115,000 on the original brakes sounds amazing. Did you just steer around everything and never use the brake pedal??? Factory brakes are still kickin on my 2011 but I'm gonna change them out in the spring even if they still have a decent amount of pad left. Road salt does bad things to brakes but I'm hoping to get away with just pads and rotors.
  9. Search Ford Edge door panel removal on youtube. There's a couple vids on there that should help. The Rockfords you ordered should sound just fine and about a billion times better then the factory toys.
  10. Good to see ya back Dingo!!! If I remember correctly, you used to run DDM hids in your Edge. How do you feel these compare to a 35 or 55/5000 set of Hids???? I'm still running the same 35/5000 DDM kit I installed 4 years ago.
  11. fishx65
    What is this
    My best guess would be a broken part from a golf cart or ATV primary clutch. Probably nothing to do with your Edge.
  12. I've had a 35/5000 DDM kit in my 2011 Edge for 4 years now. Other then 1 bad ballast that they replaced under the lifetime warranty they have been perfect. Nice thing about going with a 35 watt kit is that you can run it as a true Plug-N-Play without wiring in a harness. I did build a harness for mine. A good 35 watt kit installed properly is way way brighter then the stock bulbs and the beam pattern stays about the same. Still the best mod I've ever done to the old Edge!!!
  13. Been watching this thread over on Hidplanet: https://www.hidplanet.com/forums/forum/general-discussion/leds/64558-testing-the-cn360-h4-led-headlight-bulb-philips-x-treme-ultinon-copy
  14. Just curious, How many miles did you get out of your stock tires? Michelin Latitudes 18" 245/60/18 2011 SEL FWD. Just changed them out at 61,000 and could have pushed it to about 70,000. I'm about 70/30 city/highway..
  15. I just had my YK580's installed a few days ago (2011 SEL). Stock Latitudes had 61,000 on them and were probably good for another 10,000 if I wanted to stretch it. Ride seems a little softer so far and they are nice and quite on the highway. Headed up north for a month of bow hunting tomorrow so I'm sure I'll get to test these out in the mud, rain, ice and snow. I rotate religiously at 7,000 so maybe I can reach the 60 grand mark before having to replace these.
  16. Pretty much any aftermarket replacement speakers are gonna sound a ton better then Fords plastic garbage. Like Carguy said, make sure the sensitivity is 90+ and you will be a happy camper.
  17. To me, the pics with the bug guard effect look a little smoother. On the 2010 and below I think I would stick with chrome or do a body color match.
  18. I've always had the best luck with Z-2 when it comes to winter protection but this year I'm trying the Duragloss 601/111 combo. Last year I went with DG 601/105 topped with Collinite 845 and was not thrilled with the durability compared to the Z. I'm in a nasty salt belt.
  19. Anyone else have a problem with low coolant level on their 3.5? I've had to add about an inch and a half 3 times in 60,000 miles. I know it's not much but I don't ever remember having to do this on any of the 15 previous Fords I've owned. No ground leaks and no coolant smell.
  20. I always throw looks into the equation when looking for a new vehicle. In my opinion, both the Edge and Santa Fe are good looking Sport utility vehicles. To me the Subaru looks like a station wagon and the Nissan is just plain odd looking.
  21. I think it's always a good idea to install a BEEFY dual relay waterproof harness when adding a hid kit regardless of the wattage. Not 100% sure but I would think it would allow the bulbs to reach full brightness quicker. Keep in mind that a harness needs to be well made with proper gauge wire cuz we don't want any meltdowns or fires.
  22. I'd just throw one of your new ballasts in there and see if that takes care of the problem first. Smart move buying two kits!!! Did you pay the extra $20.00 for their lifetime warranty???
  23. I just had to stick a plug in another nail hole yesterday. My old tires are like Swiss cheese but I'm almost done with them.
  24. A new factory bulb should not change the beam pattern or aim of your headlight. Maybe swap the bulbs and see if anything changes on the passenger side. Either way, it's probably a good idea to spend a little time getting the vertical adjustment right.
  25. Even though I plug mine I do agree that getting them patched from the inside is the smart thing to do. I never was that bright!!! Sometimes it does take the TPMS a while to reset but it will.
