    272
  1. '11+ is smaller, at 63.4 mm, '07-'10 are the 70.6 mm hubs.
  2. Saddened. But, as long as MG Productions are in full swing, I can forgive you
  3. Welcome to the community, Saxman_T, nice lookin' Edge! Interesting, you and macbwt are 2 of the highest "grossing" drivers on the forum, and both have enjoyed crossing paths with a deer. I guess it was bound to happen! Glad to see the lemonade
  4. Andrew? Adam? Anthony? August? Alex? I'm no good at guessing games
  5. I do believe diagnostics costs are your responsibility, as they have to be reimbursed for their time. Now, it is up to the dealership to waive such costs, on a voluntary basis. Since the issues were not covered by the FSA, the ball isn't in Ford's court either. Again, it is up to Ford to determine whether they pay or not on such an incident, as a courtesy to their customer. It IS a risk we run when taking our vehicles in for service. Sorry
  6. Sorry to hear about the TB, mac, hope you get a good deal on an Edge!
  7. Not at all, just a possibility derived from across the vehicle spectrum.
  8. Tricia is our official Ford CSR, forum name FordService. You can contact her for assistance as needed, PM probably works faster. Make 4 more posts in the test forum to get to the min 5 post requirement to use the PM feature. Crystal is on other forums, I believe, BlueOval/Flex etc?
  9. Wouldn't worry about it unless it is very easy to hear under any condition. Most likely culprits are improperly attached fuel tank straps or loose/missing baffles internal to the tank. They should have checked the straps at the dealer though.
  10. What trim/engine do you have in the Edge? Based on the 2007 FSM: Could be a bad actuator, a wiring problem, or a faulty SJB (bad to worst possibilities). Testing wiring/circuits requires Ford-specific probe connectors. If it is an actuator, you will still need to remove the door trim panel and window regulator/motor to get to it. Near as I can tell, the part numbers for the actuator/latch are: BT4Z7821812A (Right) BT4Z7821813A (Left)
  11. Parts roulette is the name of the game unfortunately. It all depends on who you talk to at the store, their depth of knowledge/experience. Sometimes you get tricked even with OEM. I do hope the COPs for the TB work out
  12. Could be a bad throttle position sensor or throttle body. How many miles do you have on your Edge, and what is the maintenance history?
  13. I am sure a Ford dealer in Germany could do it for you, they may need to talk to HQ to find out how, but they should be able to do it.
  14. In the U.S., it's a federal requirement, so even if it could be turned off with IDS, no one would do it. You will have to install the sensors on the new wheels, sorry Should get new band sensors, EBay is a good place to get good prices on them.
  15. Glad to hear of such good service! Care to name dealer & location?
  16. Sounds like a deal is to be had on the 3.5!
  17. Try PM'ing FordService (Ford National Customer Service rep on this forum). You will need to tally 5 posts first to use the PM facility. Search & find a "Test Forum" thread (or go here). Put some dummy entries in. Done!
  18. I have experienced my vehicle's tires having a slow leak due to 1] puncture 2] seal bead break or 3] rust on the rim itself.
