Have you checked the battery cable terminals, are they attached securely? Could be a short somewhere, possibly a faulty ignition cylinder. Is the battery spec'd for at least 600 CCAs? You must see some pretty high temps in NV, and if so, that will eat batteries for lunch. Def make sure you have a strong battery to start with.
You probably get a mileage deduction the size of some people's mortgages -
Any shifting issues or error messages relating to that? Seems to be a popular reason for battery drain.
Does the recent recall affect you, grumzy? That might just be the ticket to getting the power steering issue fixed. Since you have EPAS, I won't suggest the possibility of a fluid line leak either, as the dealer already warned of that LOL. http://www.leftlanenews.com/ford-recalls-452k-vehicles-to-fix-power-steering-overheating-88604.html#ixzz3bMTJnCKT Even if the Edge is not included, worth pointing this issue out to Ford and the dealer to see if it can be included.
It's been quiet on the 2.0EB front for a bit, mostly need to make sure the hoses are securely clamped on and the fuel pump/fuel control module is working properly. I am thinking that for the type of driving you'd be doing (mostly highway), it could be a very economical choice. Only thing I MIGHT advise looking into for other people would be an ESP, but you'd wear out a 7 year warranty in what, a year and a half??? Nothing wrong with sticking with the trusty V6, who knows you might even get a better deal on it! -
Just got the keys to my 2015 Ford Edge Titanium
WWWPerfA_ZN0W replied to kaushen79's topic in Welcome Forum!
Do they provide an engine cover with the V6? -
Reported many times over the years, and especially in the rear. Slide pins and caliper pistons. I am not sure how often people are flushing their brake fluid, but it needs to be done every 30-35000 miles even if rotors and pads are fine. Brake fluid does get "dirty" and can compromise piston function. Rust threats do not go away even with "lifetime" fluid.
Save the gummi bears and french fries for me. The rest you can toss! Should also clean off the MAF while you are addressing the throttle body. When the rpms drop, do you have any accesories running at the time? I know that if the HVAC is on/compressor is on, sometimes this will happen. The other possibility is you have a small vacuum leak somewhere. -
Problem with door ajar sensor
WWWPerfA_ZN0W replied to TORQUERULES's topic in Audio, Backup, Navigation & SYNC
Pretty sad the issue is continually "postponed". OTOH, we do have DIY solutions for replacement, so there IS a bright spot -
Wife's got the goods on you, mac! So don't try anything too "smart" -
Here's the story behind the post: http://www.fordedgeforum.com/topic/18051-great-dealer-jc-lewis-in-savannah-ga/
2012 Edge Sport, My impressions not very good so far.
WWWPerfA_ZN0W replied to Diesel350's topic in Owner Impressions
Do you have the 22" wheels on your Sport, Diesel? I have heard that the firmer ride can provide additional feedback in the cabin, including vibration. If you have AWD, the driveshaft is a possibility as akirby said. In which case, I would take a look at PTU & RDU fluid levels & condition. Wheel bearings were pointed out earlier as a likely suspect, did you have a chance to verify them? As far as alignment goes, sometimes the subframe has to be adjusted a bit for that last bit of perfection. -
FS - 2011-2014 Weathertech Front, Rear, and Cargo Liner
WWWPerfA_ZN0W replied to bullitt#193's topic in Classifieds
Congrats!- 3 replies
- Weathertech
- floor mats
(and 2 more)
Driver floor is SOAKING WET
WWWPerfA_ZN0W replied to Blue_Edge15's topic in Interior, A.C., Heat, Interior Trim
Sealer just means some sort of water-resistant product they will use to protect the steering gear mounting bolts. No seals involved. Long ago Ford had recalls on Taurus vehicles for similar problems with subframe bolts. Fortunately did not have the pleasure of having this part fail on me To: All Ford and Lincoln - Mercury Dealers Subject: Safety Recall 98S36 - Certain 1986 - 1995 Taurus and Sable and 1988 - 1994 Continental Vehicles - Sub-Frame Rear Plate Nut Replacement AFFECTED VEHICLES Certain 1986-1995 Taurus and Sable and 1988-1994 Continental vehicles that were originally sold or are currently registered in the following U.S. states and Canadian Provinces: U.S. States: Connecticut Delaware District of Columbia Illinois Indiana Iowa Kansas Kentucky Maine Maryland Massachusetts Michigan Minnesota Missouri Nebraska New Hampshire New Jersey New York Ohio Pennsylvania Rhode Island Vermont Virginia West Virginia Wisconsin Canadian Provinces: Manitoba New Brunswick Newfoundland Nova Scotia Ontario Prince Edward Island Quebec REASONS FOR RECALL The body mounts on the rear corners of the sub-frame that support the engine and transmission may separate. This can occur if the lower retainer plate of the mount or the retaining plate nut becomes severely corroded from long term exposure to road salts and retention of moisture in the mounts. This corrosion can weaken the retainer plate of the mount or the retaining plate nut severely enough to allow the bolt head to pull through the washer or out of the nut. Should both rear mounts separate, the rear of the sub-frame will drop and steering may suddenly become difficult. This could result in an accident. SERVICE ACTION To correct this condition, dealers will replace the attaching bolts, plate nuts and the reinforcement plates on the bottom of the sub-frame rear body mounts, on all affected vehicles.- 480 replies
- missing floor grommet
- new Ford owner
- (and 3 more)
Congrats on your '15 Titanium, Conrad, and welcome to the forum! -
ON gives you one additional wiper movement after you turn wipers off. http://www.youtube.com/watch?v=yp1jKjBacHk
Great Dealer JC Lewis in Savannah GA
WWWPerfA_ZN0W replied to losthawaiian's topic in Dealership & Vendor Experiences
Knock on wood! Hard to believe you had to go to #3 to hit the jackpot! Good on the dealer to make it right -
NHTSA probes 2014 Ford Edge Sport 22-inch alloy wheels
WWWPerfA_ZN0W replied to Diesel350's topic in Recalls, TSBs & Warranty
Wow, and to think alloy wheels are supposed to be lightweight AND strong! -
New 2015 Ford Edge Titanium Owner from Regina, SK Canada
WWWPerfA_ZN0W replied to Jay-Ar Linsangan's topic in Welcome Forum!
Welcome & congrats on the '15 Titanium, Jay-Ar, sure is a beaut! -
Welcome, Rick, congrats on the '13 SEL! Here's to many many years of good service from your new ride What color did you pick?
I'm sure the OC will be well into the 300's by then -
The power points are ALWAYS ON. The OM for the 2007 & 2011 both state that nothing active should be left plugged in too long when engine is not running, otherwise the battery runs the risk of being discharged.
Haven't checked for overlap in labor between the two processes, but if there isn't much, then doing it separately should work fine. If you can determine what seems to be causing the majority of the movement, I'd take care of that first. Maybe your trusted mechanic can help with that determination?
