Happy truckin'!
Mineral gray, right? Welcome to the forum, Mark, and congrats on the '12 EB! Hope you log many troublefree miles with it, and share your experiences along the way
Welcome, congrats on your '14 SEL, and looks like Ford knew just when you'd run out of patience Hope to see pics of it soon. If you can, have the Edge prepped/detailed by a trusted/reputable shop, don't let the dealer do it for you. The Edge will stay pristine that much longer.
Maybe look on EBay, get it installed at the dealership and have Ford reimburse?
Bah humbug! Sorry to see you had to find out the hard way. Any possibility of recovering cost? Maybe if you dispute the charge for the seal replacement at least (if on credit card)?
A couple of videos put up by a Ford tech on youtube: Intake Manifold Removal: Spark Plug Replacement:
Well, there you go! That should keep the drivetrain safe, though obviously handling & response is compromised until the problem is fixed.
- 30 replies
- donut
- spare tire
2012 Edge Sport, My impressions not very good so far.
WWWPerfA_ZN0W replied to Diesel350's topic in Owner Impressions
Maybe he meant a bolt in the steering rack? -
Reports of PTU/trans related problems & possible fixes: http://repairpal.com/transmission-red-or-power-transfer-unit-ptu-brown-fluid-leaks-at-axle-area-255 A DIY How To on another forum: http://www.myfordfreestyle.com/forums/viewtopic.php?f=12&t=5140 Some insight into the (potential) leaks: http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/?do=findComment&comment=89270
I dunno, could be electrical (alternator/solenoid), could be a bearing ... I have a similar sound coming from the engine compartment, on occasion, especially audible at lower speeds while accelerating uphill. So far unresolved.
I agree with your general line of thinking, but Ford's maintenance intervals esp regarding the transmission leave something to be desired. I am simply curious to see if the spare tire would be a non-issue even with the PTU issues that are known to happen. Any stats we can look at (for any make/model)?
- 30 replies
- donut
- spare tire
Can you isolate where the sound is coming from? If from the cargo area, it is likely the fuel pump (Ford is known to generally accept it as normal behavior).
Welcome to the forum, and concur with statements above.
Change color of TEXT on Illuminated door sills.
WWWPerfA_ZN0W replied to CinnamonEdge's topic in Exterior & Body
Pics pics pics, kind sir! -
If AWD is disabled during this time, or there is enough tolerance built into the PTU to handle it, I can see that happening. If AWD is NOT disengaged, however, and the PTU is marginal, I wonder if it would still be safe.
- 30 replies
- donut
- spare tire
Gotta do what's right for you, still, saddened by your experience with the EB Edge. Good luck with the Sorento
Welcome to the forum, sorry to hear about these issues! Do you have FWD or AWD? If AWD, I would suspect the PTU (low on fluid, fluid worn out, gears worn out etc). How does the transmission fluid look (red & clearish, no burnt smell, fill level)? I would have an auto parts store pull codes to see if there are any relevant service bulletins that might apply.
A 3% allowance is built into the AWD system, so if you are outside that, time to get the tire fixed/replaced pronto.
- 30 replies
- donut
- spare tire
You have a FWD, right, no need to worry about the PTU, that is used only in the AWD models
You are right to be wary of the single coil issue, it could very well turn into a PCM issue. But could it cause jerkiness? Sure. Why it started after trans replacement, I do not know.
- 16 replies
- trans
- transmisson
(and 3 more)
Just might be time to do that!
No pic Are you looking for aesthetic modifications, or for performance modifications? Tinting, adding LED lights, plastidipping chrome & wheels, are good and relatively easy starts to modding. Performancewise, you can add H&R lowering springs (or go air suspension), a K&N intake, a tune for the ECU, and catback exhaust. First thing to do mechanically, would be the mundane ones: change spark plugs, PCV valve, air filter, oil/oil filter, transmission fluid and PTU fluid. PTU fluid is not so easy, but there is a writeup on adding a drain plug for that purpose.
Yeah, it's pretty bad. Worse than before. I guess they figured nobody scrolls to the bottom, so everything is up top.
