    273
  1. Welcome to the community! Tell us more about your Edge & ownership experience, maybe we or the Ford rep onsite can help. I assume you have already tried searching the forum for the info you need?
  2. Damned sorry to hear about the red Edge, man! Glad you are safe, with us, and you got into another Edge. Best wishes.
  3. And are these lights retro-fittable to the 2007-2010 Edge? I'm sure I asked the question somewhere already, but what the hey
  4. 35W or 55W kit? Relay/harness direct to battery? BCM could need resetting/replacing.
  5. Welcome, and congrats on your '13 acquisition (despite the wheels). What turned you on to the Edge?
  6. Dealerships What's there to figure out? Code says there's a problem with the converter. Do they intend to open it up and replace the elements? Put in a new one already! well, to be fair, there could be other problems upstream (like leaky injectors/gaskets) causing the problem and that should be fixed also along with the new CC. Regardless, shouldn't have turned you away.
  7. Welcome to the community, Lu, and hope you will end up selecting the Edge as your next ride. The only thing I can say is the Limited is more comfort & entertainment centric, while the Sport is driving-centric with stiffer suspension & handling.
  8. Welcome to the forum, Matt, nice lookin' Edge you got there AWD or FWD? I thought HID wasn't approved for Canadian vehicles, so you seem to be the victim of misleading advertising. OEM HID setups are completely different from halogen setups, you can't just swap bulbs in & out. Aftermarket HID, yes, but not OEM. You should be concerned with enjoying the Edge TOO much! Seriously, the best known issues for this gen of Edge have been the "door ajar" warning, the sticking BAMR, failing brake booster, and the defective throttle body. The 22" wheels are prone to all kinds of issues, but not the smaller sizes. Check the battery to see when it was manufactured. If anywhere near 3 years of age or more, be prepared to replace soon.
  9. Walmart might still take it back, esp if you didn't pay in cash, no? Spray the electronics cleaner & work the door lock manually a few times. If anything works, these 2 things do most often. Besides, they do have a SA or TSB on using some device at the dealership to clean out/reset the switch. Probably not free, but way less expensive than having them replace it. Much cheaper to replace it yourself following the instructions on this forum.
  10. Have seen a couple of people, including Dingo, use the HPS pads, but Dingo hasn't been on here in like forever. I would venture to say that factory rotors are just fine. I'd be more concerned with sticking calipers & slide pins than the rotors to be honest. NAPA has lifetime warranty on their Ultra Premium rotors if you are looking to go that route.
  11. Well, it would be nice to know if they are evaluating the Edge for this problem (haven't seen it reported on the MKX oddly enough). My point is that Ford has a timeline for whatever they do (production, marketing, service advisories, etc). So a delay from first report to actual action is understandable. But if problems are being reported, and they have issued an advisory for other models, why not push up the priority for the Edge? Why are most dealers so unaware of the issue with the throttle body? Why do dealers not have a tool that allows THEM to do the diagnostic (say, by putting the PCM in "engineering mode" to capture this data)? Have an interim action advisory that the customer can take to the dealer, while the final solution is sorted out. This affects realtime drivability, and is certainly not just an annoying "ambient light color" issue.
  12. Relatively quick (5 minute) install of Weathertech window visors (dark smoke). http://www.fordedgeforum.com/topic/12367-rain-water/?do=findComment&comment=119032
  13. Installed the Weathertechs today. The fit is very tight, so you have to be cautious during installation not to scratch up your paint etc. For the fronts, I inserted the rear portion first into the channel, angled so that the front portion of the "boomerang" cleared the mirror. Keep a grip on both ends at all times to prevent it from wandering. Once the rear and middle portions are inserted, carefully work in the front portion (be patient). The bottom edge will come to rest on the weatherstrip. The rear windows were much easier to do, no mirrors to deal with CAREFULLY work your windows up to the newly installed visors and make sure there is no interference. If there is, keep a slight outward pressure on the visor so the window gets past that initial resistance. Close all the way, slowly & carefully. Leave the windows closed for some time to let the arrangement settle into the final position.
  14. If you want to DIY the door latch issue, try spraying electronics cleaner liberally into the latch area. It will clean up any gunk on the switch, and hopefully the problem, until you can get it replaced (if you need to).
  15. Could be a Body Control Module (BCM) issue, causing a power drain that kills even a new battery. Assuming their diagnosis of the charging system is correct. The new battery could be a dud or underpowered. Is the WalMart battery a type 59 or 65 or ... Specs?
  16. The very least that should be done is to update the PCM programming to allow the TB to be caught in the act of failure, and issue an alert to all owners (2011+ ?) to have their PCM updated immediately. The people who may have experienced this problem are not necessarily restricted to this forum, and may not be aware of the solution. Being proactive now could put Ford in a very defensible position should a serious incident occur as a result of this flaw. If we are going to rely on computers to tell us the problem, let's get the programming right in the first place (Windows updates, anyone?).
  17. Welcome, glad to have you and your '13 Edge on board Lucky, being so close to Jared! What's your experience been like with the Edge so far?
  18. Did you get an Autocheck/Carfax history? To see if there have been any collisions? How much repainting? Have them check struts & motor mounts while they have it.
