What oil did you go with for the OC? -
TRS 9012 Kit
WWWPerfA_ZN0W replied to j45p3r's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
How about some daytime/nighttime pics -
Order my 2014 Edge a week ago... getting impatience
WWWPerfA_ZN0W replied to tbwarren's topic in Buying, Leasing & Ordering
Should never have had to come to this, but glad you found an answer. What did you end up going with? -
A. That's assuming perfect circumstances, which are becoming rarer every day. God forbid the weather be too sunny, rainy, windy, snowy ... B. There are two partners in a collision. Will the other person be observant and brake in time to help minimize the effect of an impending collision? Will the other vehicle have sufficient braking power and road grip to effect the driver's intentions? C. Maybe the only time the vehicle stalls will be the time the driver is killed. Try reversing that situation. Mechanical problems often give you time to correct, as they show symptoms over time. Fly-by-wire systems, not so much. Time to make it mandatory for Edge drivers to have a competent lawyer on retainer, update your last will & testament, and name your life insurance beneficiaries?
Ford Fusion owner from Wisco.. on the EDGE?
WWWPerfA_ZN0W replied to WiscoPat's topic in Welcome Forum!
Accident/Maintenance history? Carfax/Autocheck & OASIS report (Ford) are a must IMHO. Mostly highway driven, mixed, or city mostly? Do you have any warranty coming with it? There are a bunch of services due at the 150K mark, so unless EVERYTHING I mentioned checks out superclean, and unless you leave room in the annual budget for repairs (due to it being an older vehicle) I'd not buy the Edge at this time. -
That's the one, bookmarked & frequented -
Performance mods you would like to see for the Edge/MKX
WWWPerfA_ZN0W replied to WWWPerfA_ZN0W's topic in Mods & Tech
Congrats on the new Edge! Post up some pics I was quoted $8,000+ by the guys who turbo'd it for SEMA, hopefully you can get it done for less.- 32 replies
- Engine
- Suspension
(and 3 more)
Glad to see you reunited with your beautiful Edge, and at the shipping company for their thievery! Now you get to include the Edge in your video channel productions -
Usually, fuel injector cleaning service is around $130 if you want to get it done. What did they quote you & what do they do exactly (link?)? If you are not experiencing any driveability problems otherwise, I'd try running a fuel injector cleaner in the gas tank first. The next time you fill up, pour in the cleaner first, then put in the gas. Observe if there is any difference in gas mileage/throttle response after you use up that tank of gas. You'd be surprised how much this simple process helps. Troubleshoot & Clean Dirty Fuel Injectors A flush force-cleans the transmission system, and as a result any/all accumulated debris/metal shavings are forced loose and circulate out of the system. That's the theory anyway. Why take the chance something gets stuck somewhere & leads to major problems? Instead, do the worry free drain & fill method regularly. Any competent shop can do it, don't have to have the dealer do it. You can do it yourself if you are comfortable putting the front end up on jacks/ramps. How a Flush Works & Why It is Done It's your call when you want to do the d&f, but it wouldn't hurt, certainly, to do it now since you are past the 3 year mark.
Is the battery original to the car? Consider having it replaced. 2-3 years is max useful life OEM. The no-start issue may return without it. Good thing the warranty still applies Having fuel injectors cleaned as in a BG cleaning service is a good idea every couple of years. But if you run Fuel Injector cleaner (such as Techron or BG etc.) in the gas tank yearly (not too late now), you can avoid the cleaning service for a loooong time. Advise doing so within 500 miles or so of the next oil/filter change. No transmission flush is needed IF you drain & fill the trans 3 times (5 qts each time, so basically complete replacement) more frequently. So around 50,000 miles or 3 years, do the drain & fill. This will greatly extend the useful life of the transmission. Have the cooling system & brake system flushed tho at same interval at minimum.
Agreed. I don't know if there is a huge base of tuned Edge/MKXs or not, very rare to hear anything about these particular vehicles/transmissions. Do Fusions have the 6F50 on any trim level? However, there is a fairly substantial base of tuned SHOs running 400 AWHP (290 or so AWHP is stock) or more with no changes to the transmission (6F55). This is with a tuner with very close ties to Ford. Hence my comment about headroom differences.
That's exactly my point. The mfr will generally choose what meets their requirements, not the requirements of performance-minded drivers. In the case of the 6F55, though, there seems to be quite a bit more headroom than on the 6F50, should you choose to modify. The choice of engines really is irrelevant in the overall picture, NA or EB. Simply the mfr's choice how much they leave on the table for the owner to tinker with.
2016 Lincoln MKX spied in production form
WWWPerfA_ZN0W replied to blitz118's topic in Articles, News & Reviews
Let's try the links: -
My guess is product differentiation. Can't have the same trans in the Edge as in the Explorer/Flex. Why have we been limited so far?
The engine isn't the issue, it is what is attached to it that's the issue. You could probably get a few more ponies out of it with a tune, but would have a hard time putting it to the ground. Right now, you can squeeze out 25-35% out of a 3.5L EB TT with only a tune, but then the trans has proven to hold up to it. Not the case with the Edge AFAIK. The PTU is still the weak point, so maybe going with FWD might be better for performance-seekers. The amount of fluid in the PTU is just laughable, assuming it is even filled correctly at the factory.
I believe the 2.7L EB is reserved for the Sport? At least it's a V6 I don't think they are really building headroom into the powertrain for performance-izing the engine (due to trans limits), so it will be WYSIWYG, as with prior Edge iterations.
I bought mine off EBay a year and a half ago (manual liftgate). They started acting up again this year once the colder weather set in. I think I have a 2 year warranty limited lifetime warranty from the seller, let's see how a return/replacement goes http://www.ebay.com/itm/370924078321
