I believe there are aftermarket installs for the Gen 1 Edge that maybe you could see if it works for you. http://www.fordedgeforum.com/topic/2016-thinking-of-replacing-my-edges-navigation-system-with-aftermarket/ http://www.fordedgeforum.com/topic/3564-aftermarket-audio-wiring-harness-recommendations/ http://www.fordedgeforum.com/topic/7415-edge-mid-range-touchscreen-stereo-upgrade-top-to-bottom/ http://www.fordedgeforum.com/topic/1604-stereo-upgrade/ http://www.fordedgeforum.com/topic/10959-08-edge-build-log
New 2012 Edge Sport Owner + Looking to mod, need help
WWWPerfA_ZN0W replied to rocketace1's topic in 2012 Edge & MKX
Congrats on your Edge and welcome to the forum! CAI won't really do much for performance, at least by itself, but can really improve the looks. I assume you have the 3.7L? You could probably add a CAI, bigger TB, dual catbacks ALONG WITH (most importantly) a custom tune (e.g. from Unleashed Tuning in FL torrie@unleashedtuning.com). THEN you would get that SPORTy feeling you so desire :D -
2012 Ford Edge EcoBoost Poor Gas Mileage
WWWPerfA_ZN0W replied to fordedge12's topic in EcoBoost Mod & Tech
Do you have active shutters on your Edge, traxiii? -
Adaptive Cruise Sensor Blocked Message Problem
WWWPerfA_ZN0W replied to Susie Q's topic in Buying, Leasing & Ordering
Is it consistent as to when & where this happens? Could be weather or electronic interference. May also need re-aiming/re-alignment. Finally, the sensor itself may be faulty. Supposedly there is a TSB for this, but I have not been able to locate one yet. -
Nice! Welcome to the forum, and good luck with your (wife's) Edge. These vehicles are great for road trips; log some miles and tell us what you think!
Engine is toast...(What other will fit my 2007 Edge Sel)
WWWPerfA_ZN0W replied to marine12001's topic in 2007 Edge & MKX
Could be an intake gasket failure or oil cooler failure as well, just to add to the confusion ... http://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil -
Probably should replace the TSS and OSS in pairs, to avoid the dreaded ODO Error that crops up later on in the service life. Any trouble with shifting or does it feel like there is a misfire? Wheel speed sensors are also known to go bad from time to time. And BTW, try cleaning the MAF sensor with MAF cleaner to see if that makes any difference. It can cause symptoms like a slipping gear or hesitation or power loss etc.
Just follow the instructions on the can. It can be used in the fuel tank or the induction system. Remember to change out your oil & filter within the 500-1000 miles following such service. Luckily we don't have to worry about GDI in the 2011 MYs.
Looking forward to some pics/vids of your new switchbacks! As far as the reverse bulbs, Dingo's are still the hardest to beat. BUT I finally found a cheapo LED pair http://www.ebay.com/itm/231207767969?item=231207767969 that actually lights up the area behind the Edge well enough to see I wouldn't count on the lumen rating though, as with any of these LED products.
http://contentinfo.autozone.com/znetcs/rebate/en_US/883.pdf $10 gas card for 4-5, $20 for 6+. Luckily most of us Edge/MKX owners need 6 For the 3.5L V6 http://www.autozone.com/autozone/parts/Autolite-Double-Plat-Spark-Plug/_/N-jq6fpZ8gctd?itemIdentifier=438165_0_0_ http://www.autozone.com/autozone/parts/Autolite-XP-Iridium-Spark-Plug/_/N-jq6fpZ8gctd?itemIdentifier=896895_0_0_ For the 3.7L V6 and 2.0L EB http://www.autozone.com/autozone/parts/Autolite-XP-Iridium-Spark-Plug/_/N-k6n11Z8gctd?itemIdentifier=227553_0_0_ Additional savings if ordering online: http://www.autozone.com/autozone/landing/page.jsp?name=autozone-savings
Awesome! Might want to run some Listerine spray through the vents for 30 min with heat on max (I know, summertime, right?) to keep the bad stuff out. Hopefully you won't need to foam the evaporator core as well.
Welcome to the community, and congrats on your '07 SEL! I also picked one up with around 75K on the clock For some reason, the View New Content did not pick up this topic, so apologize for the delay in responding. What kind of repairs are you looking at?
http://www.leftlanenews.com/ford-recalls-100k-vehicles-over-various-defects.html These vehicles were built with a driveshaft that is prone to failure, causing potential loss of power while driving or a rollaway when parked. The issue affects approximately 92,000 vehicles, including the 2013-2014 Ford Taurus, Police Interceptor and Flex; the 2013-2014 Lincoln MKS and MKT; the 2012-2014 Ford Edge, and the 2012-2014 Lincoln MKX. Check your VIN at owner.ford.com to see if your vehicle is involved.
I assume your AC is running all the time, that and your radiator fans, arabski? Does the Sport come with an upgraded engine cooling package (like a towing package here in the US) to handle the higher ambients? And yes, a 15 gallon tank IS a joke with those mpgs for sure. Now if your avg was 20+, not TOO bad A lower temp thermostat MAY help, people here in hot climates claim the engine runs cooler. Also, a tune that accomodates your particular conditions could help max your mpgs.
Detaling the 2011 Edge
WWWPerfA_ZN0W replied to PrinzII's topic in Appearance - Detailing, Wash & Wax
The heat's been nuts here (except after the rains), but glad I'm not anywhere near AZ! Automatic touchless carwash is my friend -
The Official Ford Customer Service “Out of the Office” Thread
WWWPerfA_ZN0W replied to FordService's topic in Welcome Forum!
Happy 4th to you, Tricia! Hope to see you happy & recovered by Monday -
WWWPerfA_ZN0W replied to omar302's topic in Recalls, TSBs & Warranty
Since the brake booster works off engine vacuum, you should get a hard pedal if the engine is not operating. -
Looks amazing!
Any update, Prinzll? Sorry, don't have exp with BOTH of them. I did have ProACTs (at mechanic's recommendation for my SHO), quiet, not dusty, but horrible stopping power. They may have updated the formulation since then though. -
Just bought a New 2013 SEL with 205A and Appearance Pack!
WWWPerfA_ZN0W replied to traxiii's topic in Welcome Forum!
How did I miss this??? Welcome to the forum, and great choice for your new ride! Sounds like you got a great deal too, well done Looking forward to some pix hint, hint. -
Time for a trip to Canada, me thinks. Just push it on the train by yourself
C'mon, Ford! Get it on the early morning train to mindawyn!
The usual way to check for warpage is to use a dial indicator and check for runout. If there is excessive variation, say over 0.003", the rotor is consider warped and should be turned on a lathe. The lug nuts need to be torqued properly (not overtightened) to prevent warped rotors. Maybe your brake pads need to be re-seated/shimmed on the right side? During sudden braking, they would give themselves away as they would not be able to seat properly at once.
Towards the back, above/behind the stamped letters/numbers. I was thinking maybe residue from previous service/leak, but wasn't sure.
