Everything posted by macbwt
LU now sporting some Centric slotted rotors and Akebono brake pads.
MACT introduces the family and reviews Ford Edge parts.
Ford Edge #2 hits 250,000 miles.
It is official. LU passed 250,000 miles on the 15th of Sept 2018 on the way to the MACT Group Meeting. Now on to 300,000
The MACT group meeting video in Rochelle Illinois 15 Sept 2018. See ya all next year.
MACT LIve with the Canadian!!!
Nothing for total engine hours available.
Three Edges total miles approximately 641,000 miles. But who is counting.
Buy a new throttle body. A fix like that may or may not work and has a higher probability of failure.
I am less than 600 miles from reaching 250,000 miles on my SECOND Ford Edge!!! I will review the current Edge and make a video of all it took to get there a second time and then sum up the differences between the Gen 1 and the Gen 1.5.
- 668 replies
- 2011 Ford Edge
- Limiited
(and 4 more)
Front end shaking during right sweeper curve
macbwt replied to EdgeMG13's topic in Brakes, Chassis & Suspension
Ball joints are worn. Replace the whole lower control arm on both sides. -
The MACT Ford Edge group meeting is on the 15th of September. This is the largest gather yet of Ford Edge/MKX owners!!!
I Know at least one person that discovered a coolant issue through oil testing and this saved his engine.
May eventually replace the valve cover on BB as the new valve cover on LU is proving to have quenched the oil usage in LU.
- 668 replies
- 2011 Ford Edge
- Limiited
(and 4 more)
Stick with your plan as the only other real solution is to replace the sub frame. $$$$
The B PIDS
- 1 reply
- mact
- mact ford edge
(and 4 more)
This is a start to the series covering every PID (parameter ID) in the Forscan App and what they do to help. This is a sectioned series. I started out with some rather annoying sound but have figured it out and the 3rd series on should sound a lot better. Hope this helps some of you.
- 1 reply
- mact
- mact ford edge
(and 4 more)
250,000 miles for the second time in a second Edge!! LU is actually not showing the age and wear that the Orange Crush did at this point. Could it be I have dialed in the Maintenance better? Folks will be able to see LU at the MACT meeting the 15th of Sept in Rochelle Illinois. Going to be a great meeting and lots of folks. 2nd Annual meeting and about 15 or more Ford Edges on hand.
Tone ring inspection video for those days when you have nothing else to do and want to know are my axles and tone rings good after 250,000 miles on the OE axles? Lets check them out.
Figured why not make a quick tip video while installing the new harmonically balanced Centric slotted rotors and Aekbono brake pads. Yep LU is stepping up to some neat brakes. Here is the brake tip.
LU received some new Centric Slotted and Harmonically balanced Rotors with Akbono pads. So far the first 400 miles are doing well and under extremely wet raining conditions. I am satisfied with the results. I am also having some great reduced oil consumption. The new valve cover is performing well.
Strut mounts and struts. Strut bearing is bad.
So far no leaks and not seeing any oil usage, but only have about 80hrs on the oil
