1004ron
    168
Everything posted by 1004ron
  1. 1004ron
    Delivered!
    They were original install on my wife's 2015 Mustang, and we installed another set at 51K miles because they served us well and were well priced with a $50 rebate. Could have got another 2 to 3K miles out of them but wanted good tread depth for the winter.
  2. Just got back from the Ford collision centre where I waited just short of an hour for them to install the new light. Park Lamp - Ford (FT4Z-13200-H) $296.72
  3. 1004ron
    IDS/Scan tool?
    BAFX Products Bluetooth Diagnostic OBDII Reader/Scanner for Android Devices That's not going to work with the Foscam full Windows version which is the only version capable of writing changes.
  4. 1004ron
    IDS/Scan tool?
    I bought the same one on Amazon and it works with my wife's Mustang and my Edge.
  5. Thanks for the feedback, and based on that I'll not bother with switchbacks for my front turn signals.
  6. It looks like the 7440 switchbacks have a separate wire to power the white LED's while the turn signals are not on - I'm not too keen on that arrangement, and not sure that it will actually work on the Edge due to the low voltage/intensity when the turn signal is not on. http://store.ijdmtoy.com/No-Hyper-Flash-7440-LED-Light-Bulbs-p/20-101.htm http://store.ijdmtoy.com/Single-Filament-7440-LED-Switchback-Installation-a/597.htm
  7. 1004ron
    20170823 170811
    I just cant find the thread in which you posted this - damn new forum software - I'm looking for the switchbacks
  8. I just installed the below eBay switchbacks in my wife's 2015 Mustang, and wondering if they are the correct ones for my 2017 Sport - can anyone confirm this for me? https://www.ebay.com/itm/7444-7443-Switchback-LED-Bulbs-WHITE-AMBER-Dual-Color-Turn-Signal-Lamp-Light/192443860151?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  9. Hopefully this light bar you plan on installing is legal - there's a couple of vehicles on my morning commute that blind all oncoming drivers with their light bars.
  10. Yes, snow and slush build-up does kick it off Cruise Control. The Adaptive Cruise and lane guidance works in most weather condition, day or night, but not snow.
  11. My wife's 2015 Mustang is that colour - one of my favourites "blues".
  12. That doesn't sound like a noisy lifter - I'd get it to the dealership service center ASAP and have it addressed under warranty. I have the same model, it it does not make any noise - you could add your model/engine to your profile.
  13. No such video comes up in a search - what's the title? Any chance of responding to the questions previously posted?
  14. Unlikely that its normal. What engine? What's the mileage? What's the service history, when last was the oil and oil filter changed? What oil and oil filter have you been using? If not OEM oil filter it might not have an anti-runback valve. Any sign of sludge when viewing into the oil fill cap? It could be an oil pressure problem causing the valve lifters to make a noise.
  15. I'm not sure which item/component you're referring to. Bear in mind that I didn't check for error codes seeing as I knew exactly what the cause was - check @WWWPerfA_ZN0W for the likely cause of your error code.
  16. Here's a photo - I'll try find a better one. It gets in the way of the fill plug, so I unplug it when filling. The brass device is the temp sensor.
  17. When I turned on the ignition after I did a lube service, which included the PTU, I got this warning light, .......... because I forgot to connect the PTU temperature sensor.
  18. Just got a call from my dealership that the replacement has been approved, its ordered, and once it arrives we'll schedule a time and date for the +- 1.5 hour install while I wait.
  19. Had mine at the dealerships collision centre, same place that installed the new one on the passenger side early last year - he took photos and will get back to me when he hears back from Ford Corp.
  20. Not easy to capture with a cell phone. Trying to see if this is a common issue or not. Concern is that the electrics/electronics would be corroded.
  21. Do you have water trapped in front signature lights? Last year my passenger side signature light was replaced under warranty because it had water trapped in the lens, now my drivers side has the same issue. The passenger side is still good. I'm at 33K miles and 21 months, so intend get it to my dealership to start the process of replacement, but just wondered if others are experiencing this.
  22. The only thing that I'm not happy with on my 2017 Sports is the backrest heating and cooling that does not work and Ford haven't resolved. It's so good that's the only gripe I have, and its minor.
