todd92
Everything posted by todd92
I don't know if this is real or a rendition, but is seems plausible. I think the current center stack is the weakest part of the current car. This would be nice upgrade, very BMW like.
Tire sizes and Actual tire surface contact patch width?
todd92 replied to Edgingage's topic in Wheels & Tires
The wider winter tire will make no difference on ice. If your driving conditions are so bad that a winter tire is not providing adequate traction, you need studs or chains.- 25 replies
- contact patch
- tire width
Mobil 1 oil rebate program
todd92 replied to mrmikesdeuce's topic in Dealership & Vendor Experiences
Mobil 1 in WalMart is $22.99 for 5 quarts, with the often available $10 per jug rebate makes it $12.99 per 5 quarts, cheaper than the Kirkland oil on sale....available in MANY more viscosity grades. -
This logic is just plain wrong. It is not so simple as wider tire = bigger contact patch = more traction in all conditions. It's a complicated relationship that involves changing the contact patch size, shape and pressure. You are trying to increase friction on ice. A wider contact patch will not make ANY difference. You have 2 choice. Winter tires with a softer rubber compound and many sipes to increase the coefficient of friction. If this is not satisfactory for your driving conditions, then the only effective alternative is studded tires or chains.- 25 replies
- contact patch
- tire width
3.4 is a fail. The appearance is a downgrade and it's laggy. I don't see any worthwhile new features. What was Ford thinking.
$270? You're not getting 'free' shipping. A quality H6 AGM battery from Advance Auto is $159 with the always available 20% off codes. I routinely get 7+ years out of batteries, so the fact that you've gotten 2 or 3 out of a very expensive battery isn't very impressive.
Sorry, you read your manual correctly. I have an 18 and a 19. Looked at the wrong owners manual. 18 oil capacity is 5.7. 19 oil capacity is 5.5. Did the oil pan change?
Manual says 5.7 quarts. Dealer rounds up to the nearest quart on invoice. Did you bother checking to see if it is overfilled on the dipstick? If overfilled by 0.3 quart, not likely to cause an issue, but dealer ought to be notified if that is the case, because it would be sloppy workmanship. There isn't 'room' for additional oil, hence there is a max and a min level on the dipstick. Overfilled oil does not spike oil pressure. If overfilled enough the crankshaft splashes in it, causing frothing of the oil. Frothing causes problems whether or not the engine is revved higher.
Brake Rotor replacement suggestions?
todd92 replied to shumax's topic in Brakes, Chassis & Suspension
I have had very good luck with Centric rotors. -
2019 Ford Edge Titanium Paint Cracking and Peeling
todd92 replied to TitaniumRob's topic in Exterior & Body
What you describe would be 100% covered under warranty. Why would you call Ford? Just take it to a dealer (one with a good paint shop). -
Heated and Cooled Seats
todd92 replied to Wedgeamatic's topic in Interior, A.C., Heat, Interior Trim
I currently own a 2018 and a 2019 Edge with cooled seats and they both work exactly the same. -
They are definitely cooled (from the TED) not just ventilated. Mine work fine in my 2015 F-150, my 2018 Edge and my 2019 Edge. The only change I'm aware of over the years is Ford did something to the TED's fan/ducting, because I can hear it in the Edge's but not in the F-150. F-150 forums have lots of complaints about the cooling not working, or the seatback even getting hot. I must be lucky, mine works fine. I had a 2015 Lincoln MKC and it neither heated nor cooled well, but I always attributed that to the thicker seat padding? -
There is no need for a catch can, they are a gimmick. Synthetic is more heat resistant and does not break down. It is not more resistant to carbon build-up. GF-6 oil is what you want to use. Does not matter synthetic or semi. 5000 miles is a short OCI and decent oil will work fine with such a short interval. If you are getting carbon it would be in the intake tract and on the backside of the intake valves, not 'on the turbos'.
You heard wrong. All oils are compatible with each other. Also, if you are going to change your oil every 5000 miles, full synthetic is not necessary.
Ouch
76,000 miles and transmission starting to act up? Change transmission fluid.
A tune does very little for NA engines nor will all the other stuff you're considering throwing at it.
Need help new owner keyless entry/keys
todd92 replied to Itsdjellz's topic in Alarms, Keyless Entry, Locks & Remote Start
So the card with the code is not in the folder with the manual? -
How did you end up with a 2019 that's missing a key and the Owners Manual? -
There is a card in the Owners Manual pouch with the code. -
If you switch tire sizes, you must calculate the new recommended pressure vs this door jamb sticker number according to this guide. As the load rating goes up, the required tire pressure goes down. Tire Inflation.pdf
Do this! ?
I'm partial to the Detroit 6V71. THE CRACKERBOX
No car needs a catch can.
Numerous posters saying they have the same/similar symptoms with 8F35 equipped Edge's. I was just saying mine has been flawless.
