Perblue
    23
Everything posted by Perblue
  1. Yes it can be done by sucking out the fill hole or unbolting the cooler attached to it. Then fill it. Unfortunately that price is probably about right as the factory ford fluid is 80-100 for a liter of it and then your standard 1 hour minimum charge for labour.
  2. Try rotating the tires and see if it still does it with the back on the front.
  3. My problems didn't but no idea. Did you try the stuff in that post? You could also see if you sync version is up to date for your vehicle and update it if not. Update Ford SYNC® & Navigation Maps | Ford Owner Support
  4. That would more than likely be the camera itself. 2 times my camera acted up, both different, both times it was the camera.
  5. Ok that is odd. Maybe this thread will help Rearview camera doesn't come on - Audio, Backup, Navigation & SYNC - Ford Edge Forum
  6. Nope, there were none in my 2013. What does your screen show when you put it in reverse?
  7. The camera is either dead or has a bad wire some where.
  8. I haven't read or heard of anyone doing this. Unfortunately I think if you do it you'll be the guinea pig for it. If you do it let us know.
  9. LOL I've used anti seize on a lot of stuff but never considered that at all!
  10. Where the heck do you live? I'd like to see pictures of this excessive rust, you should see what hubs look like after a Canadian winter or 2. I doubt it's anything to worry about and your shop is trying to scare you.
  11. Use the same as you would hand washing your car with lots of soap and cloths.
  12. Maybe from the increased load from the AC, otherwise they should only be a coincidence. Check your oil level, low can affect vvt also if you are losing oil into the exhaust it can throw a p0420 code, and coolant level, possible infamous head gasket issue. If it's good, then likely vvt solenoid or timing issue. Slim chance it's spark plugs also.
  13. You mean your 2010? Then yes. If it is a 2020 then it has a 2.0l or 2.7l.
  14. I haven't had any issues myself, including getting a turbo fixed on warranty next month.
  15. Did you clean up the ground? A green ground is a bad ground. You may have to test your voltages at the sensors and start moving harness around and see if there is a spot that makes it fluctuate. You're welcome.
  16. Normally a sensor reading too high of voltage means there is a bad ground, it could be a bare wire that's ended up chafed leading from the sensor or one of the main grounds on the car. Yours is likely doing it intermittently from the vibrations of driving around. They are a pita to track but sounds like you need to make sure the main grounds are not corroded or frayed and then follow the grounds for the associated sensors down the harness looking for anything that looks even the slightest suspicious. I once found one right at the base of a connector for a maf sensor, first time I looked at it I thought it was good, the next time I looked at it I finally seen the only 2 strands in the wire were actually still connected. Redid the wire, high voltage went away.
  17. My mistake was thinking it was 60k miles or 3 years, but being a 2020 it still could have been under 3/36k.
  18. You have over 60k miles on it? It was built before december 2019, I know some are? Otherwise pretty safe to figure you'd have some factory warranty on it.
  19. Using your warranty would have saved you money and possibly time also.
  20. @WWWPerfA_ZN0W Unfortunately mine has a build date of nov 2018 so even if I brought this up to them they would probably out right ignore it since mine is outside the build dates listed. LOL it definitely is, now we are back home it's much better with the 10 hour drive back done. Was just waiting to hear rod knock the entire way back though from a spun bearing, but it didn't though. I may drain the oil to see how it looks out of the pan to see if there is anything in it or not before it gets to the dealership.
  21. Topped up fluids for a 10 hour road trip to manitoba, unbeknownst to me during that drive I blew 4 liters of oil out the tail pipe. Threw codes for emissions inefficiency during the drive, other wise things seemed fine, slight of a short stutter with an hour left of driving then smoothed out, figured it was maybe some water in the tank due to our recent cold temps. Filled up at destination, added gas line antifreeze to it. Hit 120kph and Edge killed power and and oil light came on. Checked oil and none on dipstick, took 4 liters to top it up, not sure how it managed to run or why it didn't make a heck of a racket while running. Drove it back home after the holiday, only lost a liter on the way home, checked it regularly during the drive. The vehicle goes into ford to be looked at on the 13th, sounds like turbos will be replaced but not engine, however they do have to inspect it first. Planning to drive it until drivetain warranty is done in a year or motor blows up(new motor from ford if this happens), then will be joining the 3.0L club. Found one from a 2019 mkz for 2200 CAD shipped with 4100 kms on it. Needless to say it was a stressful holiday.
  22. This is pretty standard with extended warranties unless you paid for a 0 deductible, which isn't always an option depending on milage. Either you pay the deductible if the problem is covered under the warranty, none wear and tear items, and it starts the claim or you end up paying the diag fee if it is wear and tear items not covered by the warranty. I'm sure they were just making sure you were aware that it isn't totally free no matter what. Granted I have been looked at like that too since I bought my 2019, but I'm giving your dealership the benefit of the doubt.
  23. I changed my RDU fluid at 5000 kms and came out silver and still has flakes in it at 60,000, I'll be changing it again soon. Ford claimed it's from the housing. I'm just happy I did the first one early, can't see that much flake being good in there long term.
  24. Not overly, a few miles at least per trip. If the distance covered was the issue it would have problems in weeks, maybe a few months, not over a year. Also the battery would then still take a charge from a charger instead of not charging at all.
