Random ABS Disable?
I have 2024 ST with just over 10 thousand miles. While on a trip I was driving with the adaptive cruise control engaged, when out of nowhere the system deactivated followed by a string of alerts in the message box on the dash: cruise control not available, ABS system disabled, traction control disabled and hill start assist not available. Three warning lights illuminated (ABS, Brake and Traction Control).  I pulled over and shut the vehicle off, waited a minute and restarted it. Everything went back to normal. About an hour later the same thing happened. The vehicle drives like normal when this happens. I drove to my hotel for the night and the next day all was well, for about 2 1/2 hours. It did it again and since the car drives like everything is ok, I finished my trip. I am still under warranty, and I have contacted the dealer for an appointment.  I also got a string of 3 messages on my Ford Pass App, multiple times. One of them alludes to the fact that the Anti-Lock Brake Module may have failed. Just curious if anyone has encountered this. I don't have a lot of faith in my dealer, and I think the more I know, the better off I am. Thanks so Much. Sorry for the dash pic upside down.
Edited by STBEAST
I got something similar recently on my 2016 Edge Sport. But it was during a U-turn. Turning the engine off then on got everything back working.
Checking for codes, I found a C0034:15-28 for Right Front Wheel Speed Sensor. Seems the something messed with the sensor reading during the turn and hence caused all the faults, ABS, ESP, etc. Since they all rely on the sensors to work correctly.
omar302 that's interesting because I thought about the same thing. With all these sensors on the new vehicles, all it would take is a small glitch in the system to cause confusion and chaos. This could easily trigger false alarms and warnings.  The fact that I could shut of the vehicle and re start it, would set everything back to normal tells me there is no major issue. Two common denominators, it was light rain, and I was using the adaptive cruise control when it happened. I haven't taken it back to the dealer yet, and I drove it the other day around town with no issues.
Interesting when you go on YouTube and see all the videos of new technology vehicles (pretty much all brands) experiencing electrical glitches.
The downside is when you take it back to the dealer, they tell you that they could not find an issue, and everything is fine.
Yes, your car IS a computer on wheels. The more things that are electronically controlled are also more things that can glitch. I used to work for a manufacturer of coffee brewers for convenience stores and the first thing we told customers with machine problems was to turn off and turn back on the machine.
Back when I worked in a SAAB dealership, some of the cars were plagued with
some strange happenings. One involved a certain area in Boston MA. The others,
random happening all over the US. The common denominator was they all started
after being towed back to the dealerships. No problem found!!
The problems were found to be not enough RF shielding. The Boston problem was found to be the
antennas for the radio and TV stations were located where the car conked out. The others
were found to be at "radio controlled" intersections. If the car was stopped there, it was towed from there.
But, if the light was green, the car only sputtered it's way through the intersection. These were the early
days of Bosch EFI.
So with all of the "computers" in all of the vehicles, "No problem found" will continue, So, it's best to
turn it off and restart and smile because you know more than a whole bunch of Technicians.
Because it's poor or not enough RF shielding and YOU got glitched!
DE KI6FG
I have had the exact same messages however when this happened, I lost power steering completely.  Not easy to steer this cars under manual power!
I determined after research that the problem was with this part
You could have the same issue.  In my case, this cable had come loose and fallen down on top of my driveshaft, which burned through the cable, requiring full cable replacement.  Maybe your connections on this cabe are coming loose?  Maybe your cable has fallen down like mine did, just that it has not burned through?  Maybe it is something different entirely.
You can find this cable behind the motor.  You have to look up between the back of the motor and the front of the transmission, above the driveshaft.
This is a known issue by Ford, documented in Ford paperwork.  It is covered under warranty.
Thanks for the information. I will check that cable for sure.
For some reason in the back of my mind, I thought about what garycrist had posted.
With all the technology around us -RF interference/radio waves/cell towers/Wi-Fi etc. all it would take is being in the right place at the wrong time. When these systems get interfered with, they get confused and go crazy. I feel like the dealer is going to tell me they couldn't find anything and everything is ok. Unless it happens again at which point I am driving it directly back to the dealer without shutting the car off so they can see what I am talking about. I will definitely give an update when I know more. Thanks for all the great info.
Ford has identified an issue where the ABS module software. It can cause cruise control to deactivate and trigger these specific warning lights. The fix requires  reprogramming the ABS module. (This is usually  covered under warranty.)
2nd possibility is a faulty wheel speed sensor. (If the car cannot "see" how fast a wheel is turning, it cannot safely operate ABS or cruise control.) Inspect the wiring to each sensor for damage. (Should pop a code.)
3rd is an ABS module Hardware Failure. Should pop a code.
