    343
  1. Yes. Whether you listen to it or not it goes away after about 5 seconds.
  2. My screen is just a popup on top of the audio screen.
  3. When I’m listening to Sirius the text window just pops up then goes away. It doesn’t change to a different screen.
  4. Both of my sync 3 vehicles work just like your Mustang. It goes away within a few seconds. Try doing a soft reboot ( hold power and next track buttons simultaneously).
  5. He was talking about the seat backs for the driver and passenger not the rear seats. On some models Ford went with manual seatbaks but power everything else. Very strange.
  6. Worst case if you can’t find the fob have the known fobs reprogrammed.
  7. There should be a display mode showing the torque split. Remember you still have open differentials so if one wheel is spinning freely the other does nothing until traction co trol kicks in by braking the spinning wheel. Put both rears on ice and it won’t matter.
  8. It does not void the warranty but the dealer can tell if a tune was installed and if you have a failure that appears to be caused by the tune they can deny that specific warranty item. E.g. if the engine appears to have failed from overboosting the turbo and a tune had been installed they probably won’t cover it. But if the purge valve fails that’s still covered. They can tell if a tune was installed even if you remove it and return to stock.
  9. It means updating the engine and transmission management parameters. The most common change is to advance the engine timing to produce more power when using higher octane fuel. It can also change the fuel map to be more precise, change tranny shift parameters, etc. On Ecoboost vehicles it can also change the boost settings.
  10. ST Line was added to North America a couple of years ago.
  11. https://www.tirerack.com/tires/TireSearchResults.jsp?tireIndex=2&autoMake=Lincoln&autoYear=2016&autoModel=MKX+FWD&autoModClar=&width=265%2F&ratio=40&diameter=21&sortCode=61028&skipOver=true&minSpeedRating=H&minLoadRating=S
  12. Actually edge ST launches in AWD under hard throttle. The problem is the trans, PTU and driveshaft have to be protected by limiting torque in lower gears whereas the X5 and other longitudinal setups have much more robust drivetrains that don’t require as much torque management.
  13. Yes it's the chip shortage. Edge and Nautilus are obviously not a priority for Ford so the factory has been shutdown for most of the year. I'd say wait and order a 2022.
  14. 07/30/2021 - 2022MY Order Bank Open Date 08/12/2021 - 2022MY Scheduling Begins 09/20/2021 - 2022MY Job #1 Date
  15. Compare the engine specs to a 1997 4.0L Explorer.
  16. That could cause issues with the variable cam timing which uses engine oil. It's more complicated than just fuel economy.
  17. If you need to add 10 km/h, press the gas pedal then hit set again.
  18. Not sure how that would work if an inspection is required. Can any dealer do the inspection even if you're not buying it from them?
  19. It’s probably a different plan name. Check with Ford.
  20. Not true. It just requires an inspection. I’ve never heard of anyone unhappy with a Ford ESP repair. I’ve heard many horror stories about non Ford warranties.
  21. I'm pretty sure Brits are only allowed to go offroad in a Land Rover......
  22. The only extended warranty worth purchasing is the Ford ESP and I'm 99% sure that us covered. You can see the list of parts covered at the Ford ESP website.
