Moderator-
Try it at lower rpm and see if it behaves the same way.
Have you checked the cranking amps? Voltage means nothing.
I think it will shift automatically sometimes if you're near redline. I've heard conflicting reports. My 2000 Lincoln LS was the first Ford vehicle with Selectshift and it would never upshift on its own.
Does 20" compared to the 18" Wheels Make for a Smoother Ride?
akirby replied to luvford2's topic in Wheels & Tires
It's possible the tire pressure wasn't adjusted properly on one or both vehicles you drove. Theoretically everything else being equal the 18s should ride smoother due to the taller sidewall. However Ford has done a good job with tuning so the larger wheels aren't necessarily bad. Test drive a couple more just to be safe. -
There is a difference - whether you can feel it is up to you.
Just replaced cooling fan assembly, now fans won't shut off
akirby replied to bplemmons's topic in 2008 Edge & MKX
Seems like you need to use a Dorman. -
What are your credentials?
2015 Edge Sport DRL Question
akirby replied to tryton1000's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
That would make sense. -
Don't think it's mandated by law but most mfrs seem to be doing it including Audi and Chrysler. -
I had dinner in Danville a couple of times while visiting San Ramon for work. Had some great fried chicken at Revel Kitchen and Bar and some great food and wine at the Vine at Bridges. Welcome.
Intelligent access on 2015
akirby replied to Blk182atn7's topic in Alarms, Keyless Entry, Locks & Remote Start
The rear gate hands free is a separate option than intelligent access. However, that feature is only available on SEL and Titanium, not SE. Are you sure you have a SE and not a SEL.- 26 replies
- 2015
- intelligent access
If it's "all there" then why wouldn't they charge you for it?- 26 replies
- 2015
The handles may have the wiring but do you have the proximity sensors that detect the key?- 26 replies
- 2015
... Or doesn't work.......
Understood - just trying to explain how it works.
Heated and Cooled Seats
akirby replied to Wedgeamatic's topic in Interior, A.C., Heat, Interior Trim
It's also possible the dealers aren't installing it correctly. They had similar issues with the early PTU seal replacements. -
Like I said it could be a parts hold. It's also possible the others were ordered as dealer stock (priority 20+) - those get built first anyway. I wish Ford would treat retail (sold) orders differently and not make it part of the dealer's allocation. They've done that before on individual models.
Your order date and priority only matter within your dealer's allotment. Unless your dealer is simply too lazy to look it up, they either don't have allocation available or there are too many priority 10s with earlier order dates ahead of you from the same dealer. The other possibility is a parts hold.
There is no way that's a $3K repair. It's covered by the emissions warranty which is typically 80K miles.
Like I said either Apple has either tested certain apps and allows them (or blocks them) or there is a flag in the app that says whether it's safe for car use or its deciding based on how the app interacts with the screen. Eyes free was created specifically for car use. No auto mfr is going to allow you unrestricted Bluetooth access to Siri. If they did you wouldn't need Eyes Free. Because I guarantee you if someone gave Siri a command that asked for screen interaction and they looked at their phone and crashed they'd sue Apple and Ford in a heartbeat.
All edges are job 1 until job 2 comes around (if it comes). You're referring to the OK to buy that happens when the factory builds perfect vehicles 5 days in a row. Retail ( sold) orders aren't built until the ok to buy has been given so no problem putting in orders now.
akirby replied to exodus's topic in Audio, Backup, Navigation & SYNC
I would try the master reset first. -
Bsquare didn't write sync 3 so there's at least a chance they can follow through on it this time.....
They've already put out one repair kit. Why would you think they'll "take a knee"? This affects too many vehicles for them to ignore.
