fishx65
Everything posted by fishx65
I have no problem running tires with plugs in them and have done so for many years. In your case, because the repair is so close to the shoulder, I would run that tire in the rear. Not sure if I'm correct but I would think a back tire blowing out is better then a front because of steering ability.
I've been using plugs for 30+ years and never had one fail but that may be a little to close to the sidewall. Take it in and see if they think a plug and patch will be OK. They will know more when the tire is dismounted from the rim. Horrible aim, you really should have hit that nail an inch to the left!
I just finished an application of Duragloss 111/601 on my 2011 after a thorough clay bar session. Applying this Duragloss product by hand is identical to applying Zaino Z-2. Same consistency and ease of application and it only took me about 1 tablespoon to do my entire Edge!!! I did try the Duragloss 105/601 combo last year but it was harder to apply and I did not get good durability through a tough Michigan winter. If the 111/601 combo comes even close to Zaino Z-2 in the durability department I'll be using it for a long time. Duragloss 111 plus the 601 bonding agent will set ya back around $20.00 which is about $10.00-$15.00 cheaper then the Z-1/ZFX Zaino combo. 111 has always been compared to Z-2 and I now understand why.
The foam engine cover on my 2011 made a really nice mouse nest!!!! Now it dampens sound and allows air flow!! I think they are around $80.00 from the dealership.
This issue has been ongoing for more then 10 years with Ford vehicles. My 2004 Taurus had both front door switches go bad and I went through a few cans of lube before I finally sold it. I would think most companies would address the problem rather then just ignore it all these years. Maybe they preordered 15 years worth of door latches they need to use up!!!!!
EBC Ultimax Slotted Rotors Installed!
fishx65 replied to jwallace410's topic in Brakes, Chassis & Suspension
Looks like some serious road rash on that rim! Proof that fast food is bad for your body and vehicle!!! -
Replacing headlight bulb
fishx65 replied to Denise Egan's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
H-9's in place of the H-11's make a huge difference in low beam brightness. Lots of info online about the slight mod you have to make to the H-9 for proper fitment. Just make sure to aim them properly after install. -
My 2011 (50,000 miles) has been that low for a long time. I just had them top it off a few weeks ago so I'll keep an eye on it. I have not seen or smelled any leaks which could be good or really really really bad. really really really bad = internal head gasket leak
Sweet, maybe the brain is still working OK!!!!! http://pdfsr.com/pdf/13n02-brake-booster-warranty-extension-2010-thru-2013-edge-and-mkx
Mac, I just had my 2011 in the shop and they told me how long the booster warranty was extended. My memory is starting to go at the ripe old age of 50 so I can't remember the exact mileage but I think it was 10 years/150,000 miles.
I never get those silly certificates but I can see how they could come in handy if you destroyed a really expensive tire. I think ya get lifetime balance, rotation and flat repair with any purchase from Discount Tire.
Xenon Depot kit troubles
fishx65 replied to mestguy182's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
If they are 35 watt, I would try them without the harness. If they are 55 watt, ya might want to look into a better harness with thicker gauge wiring. I had the same problem with a cheap ebay harness and rebuilding it to the proper length with 14 gauge wire completely solved the problem. Also keep in mind that some of these kits don't fire consistently when using the auto-on headlight feature. -
Rotors Don't Warp from heat or ceramic pads
fishx65 replied to dshamer's topic in Brakes, Chassis & Suspension
Very informative. I've been doing my own break jobs for 30+ years and have always had good luck (except that one time when I put some Taurus pads on backwards in the dark!!!). I always thought it was heat that caused rotors to warp but improperly installed rotors makes a lot more sense to me on street driven vehicles. I'm getting ready to do the brakes on my 2011. -
Installing double DIN Touch - just plug n play ?
fishx65 replied to CivicSi907's topic in Audio, Backup, Navigation & SYNC
Go to Crutchfield.com and enter your vehicle. That site will show you everything you need for the job. -
Should be really easy and well worth the effort. Just make sure you get the adapter harness so ya don't have to cut any factory wires and you could probably find a kit to retain your steering wheel controls if you like to use them. There should be lots of info online about switching these Ford Head units out. -
2008 Ford Edge rear shock removal/installation DIY Video
fishx65 replied to macbwt's topic in Brakes, Chassis & Suspension
Really enjoy your vids Mac and I'm sure they have proven very helpful to many do-it-yourselfers on here. I figured the back shocks were pretty easy and will probably be trying to soften my 2011's ride up with some Sensatracs soon. Have you noticed how much stiffer the ride is in your 2011 compared to the 08? Also, have you replaced the front struts and springs yet? -
I ordered one of these a few months ago and just ordered 2 more. They actually work really well and hold phones rock steady in any position. The thin piece of metal can either go between the battery and back cover or between phone and a case. The mount itself is rubberized and fits really well in my 2011. These things are super cheap and very cool!!! These come on the slow boat so count on at least 3 weeks. http://www.ebay.com/itm/Car-Magne...566e71dd35
Broken serpentine belt and PS belt at 7443 miles
fishx65 replied to greggmh123's topic in Owner Impressions
I had a 2013 Lincoln MKX split a belt around 15,000 miles because of a metal bur on one of the pulleys. Never actually saw it but that's what the dealership told me. -
Four 245/60/18 Yoko YK580's shipped to your door for $284.00 right now after $200.00 in rebates at Discount Tire Direct. $20.00 more then last year but still an awesome deal on some new skins if ya need some.
Took an SEL for a nice long ride this morning. Definitely rides a lot softer then my 2011 and I would even say softer then a 2014 MKX. Almost felt like I was in my 2010 again which is a good thing when it comes to plush ride quality. Another thing that I noticed right away was a lot more power assist with steering. This SEL had leather seats that were really really soft, almost like sitting on a leather couch. Not crazy about how the new Edge looks but she does ride a heck of a lot nicer then my teeth rattling 2011. I think this new Edge will attract the older crowed a little better then the outgoing model.
The light bars you're missing are the farthest thing from fog lights and will give you about ZERO lumens to help you see in the fog. They are just silly decorations. Maybe look at all the HID lighting threads to help you get some more light out the front. Unfortunately, the 2011+ Edges don't have any room, at least that I can find, for adding a good set of foggers down low.
I checked out a new SEL yesterday. Interior looks a lot cheaper then the current model. Love the new back end but the front looks pretty weak. Looks like they ripped the grille off a Taurus and stuck it on the Edge. Another thing I noticed is ya really gotta slam the doors hard to get them shut because of the new rubber seal design. As you can tell, I was not impressed at all with the new Edge. Didn't take it for a ride but wondering if it rides better/softer then the 11 to 14.
