fishx65
Everything posted by fishx65
2011 Edge limited Driver door ajar issue
fishx65 replied to Racerb0y's topic in Recalls, TSBs & Warranty
I just received a notice about the front drivers side door latch on my 2011 SEL. Customer Satisfaction Program 19N09. Looks like it's covered to 120,000 miles or July 2020. -
Why did my Battery go dead overnight?
fishx65 replied to cleekoguy's topic in Accessories & Modifications
I usually get a lot more life out of 65 series batteries then 59. My 2011 came with a 59 but was also designed to take a 65. Needless to say there's a big ole 65 under the hood these days. -
Loud clicking when turning right at slow speeds
fishx65 replied to fishx65's topic in Brakes, Chassis & Suspension
Will do, Thanks!!!:) -
I'm gonna test it out better the next couple days and then post some more info. It's been a clickin for a long time. -
I did read about the Explorer CV Joint issues. Looks like they had a cheap fix: -
Not sure how much you're going to spend on 1 new COP but this Motorcraft kit comes with all 6 of them for $180.00. I know the COPs in this kit are the right ones for our 2011 3.5s. $180.00 is a pretty good deal for 6 of them and it's nice to install 3 new ones in the back while you have the upper intake off.
Dried blood on headliner
fishx65 replied to bubbadewsky's topic in Interior, A.C., Heat, Interior Trim
Steven Avery got out and purchased an Edge????:):) -
Has anyone added heated mirrors?
fishx65 replied to Bigdaddyhognts's topic in Accessories & Modifications
Not sure if this helps but I replaced the passenger mirror on my non heated 2008 Taurus with a heated version and it works. My guess would be that all Edges are wired for them. -
There's so much pad left on that one side that I'm guessing it's frozen. When I changed mine at around 60,000, one of my front pads was frozen and looked brand new. At that mileage I'd do a complete brake job front and rear. The rears wear out way faster then the fronts on my 2011. If you're doing it yourself, make sure to pull the pins and lube the crap out of them along with a little on the slides.
Nothing like living in a rust-belt. Make sure to cake that anti seize on there when ya put her back together!!!:):)
Make sure you go around and tap the rotor hard around the studs with the sledge toward the vehicle. Not to insult you, but some Ford rotors have a small allen screw holding the rotors on.
New headlights or new bulbs
fishx65 replied to Smokey1757's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
You can easily replace the H11 low beam bulb with a H9 and it makes a huge difference. Ya gotta shave off a little tab inside the H9's to make them fit. First thing I did when I owned my 2010. -
If you're still looking, Discount Tire Direct has a decent deal on the Continental LX20s (245/60/18 $144.00 per tire) today. Flash sale $100.00, DT Credit Card $40.00 and $70.00 Continental rebate. So $210.00 off is pretty good these days. They'll always match this same deal at your local Discount Tire store. Rebates are really easy to do online and I got the prepaid cards in about 6 days.
Transmission Flush, or simple drain and fill?
fishx65 replied to slides's topic in All Wheel Drive (AWD)
I wouldn't have a fluid exchange done but wouldn't hesitate to do a quick drain and refill once or twice. I'f I remember correctly, a drain gets about 5 quarts out.- 105 replies
- transmission drain and fill
- transmission flush
- (and 2 more)
Sure it's not a mouse? I had to do an insurance claim cuz speedy had his way with the hood liner and foam engine cover.
Went from stock Latitudes to Yokohama YK 580s to Continental LX 20s. The Yokos were junk but I wouldn't hesitate to go with the Latitudes again. I got just over 60,000 out of the stock Michelins. Got about 10,000 on the Continentals so far and they've been just fine.
Does it go forward when you put it in reverse? Sorry, couldn't resist.:):):)
2011 Headlights Suck
fishx65 replied to whiteedge's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
35 watt hids are super easy to install and make a tremendous difference in the 2011-2014s. My $40.00 DDM kit has been going strong for about 7 years. -
For what it's worth, the original Latitudes on my 2011 lasted around 60,000 and the Yoko YK580's I replaced them with only lasted around 38,000. I've never had good luck with Yokohama tires. Right now I'm sporting a set of Continental LX22's that seem really good so far but I've only had them for about 10,000. If Latitudes weren't so ridiculously priced I'd probably stick with them. Getting ready to throw a set of Continental Pro-Contacts on the old Taurus soon.
Rear Brakes Worn Out 20,000 miles Front Still Great. Why
fishx65 replied to tergos's topic in Brakes, Chassis & Suspension
I don't think it's uncommon for today's vehicles to wear out rear brakes before fronts but 20,000 miles seems crazy. I changed out the fronts and rears on my 2011 at 60,000 and the rears were definitely way more worn then the fronts. I'm sure pure city driving and driving habits can play a big part in brake wear. Do you drive like Speed Racer and never leave the City??:):) -
I also live in a rust-belt but haven't had a weld problem like your pics show. That's serious rust ya got there and is the reason I keep mine under-coated. I did have both sway bar links go bad and replace them with Moogs. My Edge is also a 2011 with around 100,000 miles.
2014 edge-anyone else replacing strut mounts quite often??
fishx65 replied to BTC2015's topic in Brakes, Chassis & Suspension
Not sure what brand you're using but Mac, along with others on this site, claim that Motorcraft strut mounts are the way to go. I'll be doing the struts on my 2011 eventually and will definitely stick with Motorcraft for the mounts regardless of the strut brand I use.
