Everything posted by omar302
omar302 replied to omar302's topic in Recalls, TSBs & Warranty
Is you Edge's build date within the range included in the extended warranty? Does the owner letter you have specifically mentiones your vehicle VIN? If yes then it should be covered. Checking my MKX's VIN on the Ford ETIS currently shows no outstanding field service action while it usually showed the 13N02, so I'd say there system is not acting correctly now, hopefully they will sort it out soon. You can also try to contact the Ford Service rep on forum, maybe they can help. -
I also agree with you Nick. I tried adding HID a couple of time previously, even on projector based headlights, and although the 1st impressions were always like "wow, much brighter" they never gave the same level of "useful" illumination (light on the road I use) as factory HID or even as halogen mods (H9 bulbs in H11 housings, 9005 in 9006 housing or HIR/9011 in 9012/9005/9006 housings), and worst of all, any non-factory HID mods caused considerable glare/blinding to others drivers, which I also suffer from others. The blinding/glare, in my opinion, is so bad that I think there should be more action from authorities regarding vehicles with blinding headlights.
Center flow through console
omar302 replied to Tjm623's topic in Interior, A.C., Heat, Interior Trim
I agree. Also the driver's dead pedal (foot rest) is short on the 2015+. It feels like newer Fords are designed less for big people. -
Bumper covers are not the same. 2007-2015 MKX has the license plate on the bumper while the 2007-2014 Edge on the rear hatch.
Looking for HACKS for my 2012 Ford Edge Limited
omar302 replied to MissAbunDance's topic in Welcome Forum!
For the camera, it usually means you need a new camera. Usually ~ $100/- & several members here changed it & posted very helpful how to with pictures. For the Nav, if yo have "Information" on the top right corner of the 8" dash display, then you don't have Nav or something messed up in the screen & most probably only a dealer will be able to fix it. If it tells something that the SD Card is not compatible, it would probably be because the MyFord Touch system was updated to a newer version that is not compatible with an old SD Card. Check what version is written on the card, I believe A7 is the latest & also make sure you update MyFord Touch to the latest verion. -
The "Fixed" guidelines are supposed to be there. If they are not coming, usually means the camera module need calibration/programming. A simple step any dealer should do easily or use the latest ForScan software.
I`d agree it is a dangerous situation, in my case it wasn't a sudden failure. It came slowly. There is an extended warranty for 2010-2013 models. http://www.fordedgeforum.com/topic/13888-13n02-extended-warranty-coverage-on-brake-booster/
Check this post, maybe you could try to clean the camera first.
Navigation removed after Sync2-V3.8 update
omar302 replied to Homer's topic in Audio, Backup, Navigation & SYNC
As Akirby stated go to another dealer, it should also be covered by the extended warranty for the MyFord Touch (APIM). -
Log ASM (audio stereo)modul Ford EDGE 2007-2010
omar302 replied to EDST777's topic in Audio, Backup, Navigation & SYNC
Yes. GCC Frequency is scanning all, 0.1 & 0.2 FM. Both 2008 & 2011 cars. -
This is for my 2011 MKX with GCC Radio frequency: Audio Control Module ACM 727-01-01 92A0 C000 0022 ACM 727-01-02 0031 ACM 727-02-01 6596 ACM 727-03-01 1446 ACM 727-04-01 0103 0239 This is for my old car, 2008 Taurus with GCC frequency, the radio looks similar to 2008 Edge: Audio Control Module ACM 727-01-01 0040 50BB 68E3 ACM 727-01-02 0031 ACM 727-02-01 0132 -
Although this is tried for 2011+ models, to enable European radio frequencies you need to change the As Built Data using ForScan in the ACM module using in block "727-04-01" in the first box, change the 2nd digit from "0" to "1". -
Your Edge most probably stalled & that would explain the Power Steering since it requires the engine to be running to provide steering assist.
- 5 replies
- power steering
- stalling
(and 2 more)
To find the central cups on wheels 20" 2008 without plastic skins.
omar302 replied to EDST777's topic in Wheels & Tires
I can't help where to find suitable caps, but note that the MKX you pictures also has the plastic skin (chrome cladding). -
2013 Edge AWD difficulty steering while parking
omar302 replied to Elmopilot's topic in Welcome Forum!
The 2011-2014 Edge (V6, not sure of the Eco) have normal hydraulic power assisted steering. It is generally hard/harder than other non-sport cars. The 2011+ Explorer has EPAS (Electrical Power Assisted Steering) & I is much lighter than the 2011-2014 Edge. -
Weird brake lights.
omar302 replied to enigma-2's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I know, but when the brake lights illuminate, they have this kind of a glow that makes some think they are LEDs. That's my guess any way. -
Weird brake lights.
I'd say it was probably a 2011-2014 Edge. Those have 2 bulbs for brake lights on each side (total 4), so the vehicle in question would have had the left bottom & right top bulbs not working. -
Congrats jmr061 on the new ride, hope you enjoy it to the fullest. So how does it compare to the 2016 Explorer Sport?
I didn't put any link, but here are the links for the stock (regular) Rocker Moldings: Left Rocker Panel: http://www.tascaparts.com/oe-ford/at4z78101a05aa Right Rocker Panel: http://www.tascaparts.com/oe-ford/at4z78101a04aa End Cap 1: http://www.tascaparts.com/oe-ford/7t4z7810176aa End Cap 2: http://www.tascaparts.com/oe-ford/7t4z7810177aa
Seeing that the regular Rocker Panel Moldings & Caps are the same for all 2007-2014 Edge & MKX, I'd say they should fit like what BigMoteZee did.
engma-2, the Sport's shifter doesn't have +/- buttons on it. So you have to make sure the part number is correct.
This talk about the valve covers reminded me that there was a TSB for 2011-2013 models that might experience engine oil migrating into the air intake, replacement of the valve cover is required to fix it. http://www.fordedgeforum.com/topic/17714-oil-in-throttle-body/
