omar302
    230
Everything posted by omar302
  1. Check this post, maybe you could try to clean the camera first.
  2. As Akirby stated go to another dealer, it should also be covered by the extended warranty for the MyFord Touch (APIM).
  3. Yes. GCC Frequency is scanning all, 0.1 & 0.2 FM. Both 2008 & 2011 cars.
  4. This is for my 2011 MKX with GCC Radio frequency: Audio Control Module ACM 727-01-01 92A0 C000 0022 ACM 727-01-02 0031 ACM 727-02-01 6596 ACM 727-03-01 1446 ACM 727-04-01 0103 0239 This is for my old car, 2008 Taurus with GCC frequency, the radio looks similar to 2008 Edge: Audio Control Module ACM 727-01-01 0040 50BB 68E3 ACM 727-01-02 0031 ACM 727-02-01 0132
  5. Although this is tried for 2011+ models, to enable European radio frequencies you need to change the As Built Data using ForScan in the ACM module using in block "727-04-01" in the first box, change the 2nd digit from "0" to "1".
  6. Your Edge most probably stalled & that would explain the Power Steering since it requires the engine to be running to provide steering assist.
  7. I can't help where to find suitable caps, but note that the MKX you pictures also has the plastic skin (chrome cladding).
  8. The 2011-2014 Edge (V6, not sure of the Eco) have normal hydraulic power assisted steering. It is generally hard/harder than other non-sport cars. The 2011+ Explorer has EPAS (Electrical Power Assisted Steering) & I is much lighter than the 2011-2014 Edge.
  9. I know, but when the brake lights illuminate, they have this kind of a glow that makes some think they are LEDs. That's my guess any way.
  10. I'd say it was probably a 2011-2014 Edge. Those have 2 bulbs for brake lights on each side (total 4), so the vehicle in question would have had the left bottom & right top bulbs not working.
  11. Congrats jmr061 on the new ride, hope you enjoy it to the fullest. So how does it compare to the 2016 Explorer Sport?
  12. I didn't put any link, but here are the links for the stock (regular) Rocker Moldings: Left Rocker Panel: http://www.tascaparts.com/oe-ford/at4z78101a05aa Right Rocker Panel: http://www.tascaparts.com/oe-ford/at4z78101a04aa End Cap 1: http://www.tascaparts.com/oe-ford/7t4z7810176aa End Cap 2: http://www.tascaparts.com/oe-ford/7t4z7810177aa
  13. Seeing that the regular Rocker Panel Moldings & Caps are the same for all 2007-2014 Edge & MKX, I'd say they should fit like what BigMoteZee did.
  14. engma-2, the Sport's shifter doesn't have +/- buttons on it. So you have to make sure the part number is correct.
  15. This talk about the valve covers reminded me that there was a TSB for 2011-2013 models that might experience engine oil migrating into the air intake, replacement of the valve cover is required to fix it. http://www.fordedgeforum.com/topic/17714-oil-in-throttle-body/
  16. D3S bulbs are real hid bulbs. Designed & built as hid bulbs only with the ignitor at the base. An H11 is a regular tungsten (halogen) bulb. Any hid H11 bulb is not a real hid bulb but an hid capsule fitted on an H11 base. In short, if you need oem hid, go for the D3S.
  17. There was a TSB for this sound, TSB 11-12-13 TSB 11-2-13__.pdf
  18. The rear wiper on the 2015+ Edge is different compared to the previous models. Looking at the Owners Manual, it looks like the same as the 2011+ Explorer.
  19. @WWWPerfA_ZN0W posted the procedure for the blower motor replacement in this thread.
  20. Mac, are both your Edges the same with regards to the towing package? (both have it/don't have it). I think this might be a major difference that could affect temp difference between both. Also, as per the Owners Manual, it is normal for the trans tempreture to increase after long drives:
  21. Just to chime in a bit, tried a Lexus ES350 with cooled seats & they are definitely worse than Ford's. Maybe Ford's problem with the backseat is that their bottom seat cools so good that drivers would compare the seat bottom to the back & expect the same cooling, naturally.
  22. I have noticed that lowering the seat gives more front leg room. It seems the seat moves up/down at an incline.
  23. 335 hp as per Lincoln, using 93 octane.
  24. There is a possibility that the HVAC module has DTC code, which if true, would make easy for the dealer to diagnose.
