PrinzII
    29
Everything posted by PrinzII
  1. For those who have halogen lights, here are a couple of options.... a) Buy a HID kit with 9012 bulbs (TRS/Morimoto would be your best bet) Buy the HID headlight assemblies, D3S HID kit
  2. You may also shop for Audi D3S bulbs as they will fit the stock Edge D3S housing.
  3. Been researching this topic because I am considering a conversion (Changing the assembly to the stock HID assembly and adding a D3S Kit). The challenge is finding the D3S bulbs. The bulbs are not going to be cheap and I personally do not recommend going with Ebay or Amazon specials. Known brands (e.g. Phillips, Denso or Sylvania (Osram)) only.
  4. Been using 89 on both my 2008 and my 2011. Nary a problem.
  5. Hauling Yokohama YK580s to tire shop Pics of Yokohama YK580s on the Edge
  6. After it was discovered that I had a bad set of Pirelli Scorpion Verdes, Discount Tire suggested to me that I should give the Yokohama YK580s a try. Point blank, I should have went with these tires from the jump. The first thing I noticed was that these tires are as quiet as the stock Michelin Latitudes but more than $50 cheaper. Trust me, that is a huge compliment. I like the handling and road feel these tires have. I have never driven any tire on an Edge that possessed these qualities short of a performance tire. I have not had an opportunity to try the wet weather traction yet. I will let you guys know about these tires as the miles add up.
  7. Yep. Entire set. So far, the Yokos are riding like the Latitudes.
  8. Update: Pirellis are being replaced with Yokohama YK580s. Tech went with me for a test drive. Found vibration issues after replacing the faulty tire.
  9. You may want to consider a JL Audio Cleansweep for OEM integration. The back of the unit does not have those connections.
  10. Given that I have the MFT system, I have to keep the front end as is. With that said, did you take a look at the JL Audio C3 speakers? You might want to since you can use them as coax and component.
  11. Verdict is an out of round tire. Discount is replacing it.
  12. PrinzII
    Galaxy S4/S5
    My S5 has been acting pretty decently lately. Blitz: Your Note3 and my S5 share the same processor
  13. Currently: Still trying to get the vibration out.
  14. PrinzII
    Galaxy S4/S5
    However, the commonality is that both phones are on Kit Kat (Android 4.4.2) and before the phone firmware update, it worked fine. The S5 has only had one drop....period. Been consistently good otherwise.
  15. Monday: Went back to the dealer to report a rightward pull and vibration. They Force balanced the wheels and did some subframe adjustments. Still getting some vibration. Tuesday-Today: Routine driving
  16. PrinzII
    Galaxy S4/S5
    Got the S5 but the bluetooth connection dropped on it once today.
