jmr061
Everything posted by jmr061
Audio Control Module Part Number
jmr061 replied to jeffcarl's topic in Audio, Backup, Navigation & SYNC
If you get lucky it won't need to be programmed. Since it is the same part # it may be from a same equipped and programmed vehicle. You can check the programming if you know the donor vin. -
Your vehicle came equipped from the factory with ACM part # FT4T-19C107-KD -
Adding aftermarket camera to 2012 Edge
jmr061 replied to vigness's topic in Audio, Backup, Navigation & SYNC
All you need to do is wire it to the display and enable it via programming. -
Update Your Gen2 Edge To The Latest Sync Version
jmr061 replied to Gadgetjq's topic in Audio, Backup, Navigation & SYNC
You can purchase short term access to the service manual via motorcraftservice.com and if you can't figure that out pay someone to look it up for you and send the info.- 43 replies
- sync update
- sync 3.4
Then you have SYNC which is good start. I can't find any kits for going from the 4" to 8" for the 11-14 Edge. I am thinking the APIM is buried in the center console then and any retrofit cable would have to be very long which is why no one may offer a kit. I can't find any info on where the APIM is located so you may have to check with a Ford dealer or get yourself a Ford service manual to find out.- 43 replies
- sync update
- sync 3.4
Thats not sync2, sync2 is MyFord Touch, but anyway...does your car currently have BT?- 43 replies
- sync update
- sync 3.4
Does your 14 even have base SYNC?- 43 replies
- sync update
- sync 3.4
Tirerack.com sells complete winter wheel packages. Great for someone who can swap their own wheels if that is the case with yourself. As stated summer tires in winter climate...bad idea. Can get yourself or someone else injured or killed. I waited until the first snow fall to swap the wheels on my ride this year. I have all season tires for non winter months. I drove those in the fresh snow in December, than swapped to the winter wheels and took a drive in the same snow. Night and day difference even just going from all-season to winter wheels.
What tires are on it? Summer performance, all weather, snow?
LIncoln MKX to Ford Edge Instrument Cluster Swap
jmr061 replied to onyxbfly's topic in Accessories & Modifications
If anyone is interested I pulled mine from my 16 Edge a couple months ago and went back to stock. It currently has custom firmware in it and I have some other custom firmware files for it. It was programmed for my 16 Sport. If anyone would be interested in it send me a PM for more details as this isn't the for sale section of the forum- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
Can't use Forscan bc I have a tune?
jmr061 replied to RidinDrty's topic in Accessories & Modifications
You should already have that info it is asking for. -
jmr061 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Turn the lane centering off (its on the left steering wheel buttons) and on and see if that icon follows it. -
2016 Ford Edge 302A Package Black Screen
jmr061 replied to Christopher N Bagge's topic in Audio, Backup, Navigation & SYNC
It is likely the APIM has gone bad. -
USB ports are powered by the SYNC system/APIM. When it shuts down, they shut down. No changing it.
WHAT the hey!!! Bluetooth issue with portable CD player
jmr061 replied to Bendmac's topic in Audio, Backup, Navigation & SYNC
SYNC3 doesn't support line in unfortunately -
I actually have that in my 16 Edge Sport but have yet to change oil since getting it. Last time I changed my oil, the OEM drain plug broke. The Ford dealer didn't have one and that plug was the only one my local auto parts store had.
The cubbyhole/pass-thru behind the console?
jmr061 replied to Jim W's topic in Interior, A.C., Heat, Interior Trim
sunglasses and flashlight -
Losing brake fluid - ABS module ?
jmr061 replied to Icewiley's topic in Brakes, Chassis & Suspension
Did they inspect it and then tell you that or just tell you that when you brought it up to them? If they didn't inspect it, they are just talking out of their ass. You keep having to add brake fluid....there is a leak somewhere. An inspection needs to be done. Now if they inspected it and determined the ABS module is where the leak is, either things need to be tightened up or the bad part needs to be replaced. Brakes are not something to mess around with. -
Adaptive headlights
jmr061 replied to Itsdjellz's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
SSM 48993 - 2020 Edge - Adaptive Headlamps - Selection Greyed Out In Instrument Panel Cluster (IPC) Some 2020 Edge vehicles equipped with adaptive headlamps may exhibit an IPC selection of adaptive headlamp that appears greyed out or is not able to be selected. This selection does not affect the operation of the adaptive headlamps. This is characteristic of the vehicle and no repairs should be attempted. APPLICABLE VEHICLES 2020 CAR: DQ CD539N EDGE -
Bluetooth not connecting
jmr061 replied to Starting to hate this car's topic in Audio, Backup, Navigation & SYNC
Sounds like it’s time for a replacement apim or upgrade to Sync3. -
I’ll say it one more time… Pay someone to program it properly.
