jmr061
    26
Everything posted by jmr061
  1. If you get lucky it won't need to be programmed. Since it is the same part # it may be from a same equipped and programmed vehicle. You can check the programming if you know the donor vin.
  2. Your vehicle came equipped from the factory with ACM part # FT4T-19C107-KD
  3. All you need to do is wire it to the display and enable it via programming.
  4. You can purchase short term access to the service manual via motorcraftservice.com and if you can't figure that out pay someone to look it up for you and send the info.
  5. Then you have SYNC which is good start. I can't find any kits for going from the 4" to 8" for the 11-14 Edge. I am thinking the APIM is buried in the center console then and any retrofit cable would have to be very long which is why no one may offer a kit. I can't find any info on where the APIM is located so you may have to check with a Ford dealer or get yourself a Ford service manual to find out.
  6. Thats not sync2, sync2 is MyFord Touch, but anyway...does your car currently have BT?
  7. Tirerack.com sells complete winter wheel packages. Great for someone who can swap their own wheels if that is the case with yourself. As stated summer tires in winter climate...bad idea. Can get yourself or someone else injured or killed. I waited until the first snow fall to swap the wheels on my ride this year. I have all season tires for non winter months. I drove those in the fresh snow in December, than swapped to the winter wheels and took a drive in the same snow. Night and day difference even just going from all-season to winter wheels.
  8. What tires are on it? Summer performance, all weather, snow?
  9. Did you plug an antenna into the TPMS module in the back side of the vehicle? If you did you may have unplugged it or damaged the wiring going to it.
  10. If anyone is interested I pulled mine from my 16 Edge a couple months ago and went back to stock. It currently has custom firmware in it and I have some other custom firmware files for it. It was programmed for my 16 Sport. If anyone would be interested in it send me a PM for more details as this isn't the for sale section of the forum
  11. You should already have that info it is asking for.
  12. Turn the lane centering off (its on the left steering wheel buttons) and on and see if that icon follows it.
  13. USB ports are powered by the SYNC system/APIM. When it shuts down, they shut down. No changing it.
  14. I have a 16 which I am going to guess will be the same as an 18 and it doesn't have the nice pop in clips like the 19. Frankly it was a pain to put back on after taking it off. Its a piss poor design.
  15. I actually have that in my 16 Edge Sport but have yet to change oil since getting it. Last time I changed my oil, the OEM drain plug broke. The Ford dealer didn't have one and that plug was the only one my local auto parts store had.
  16. Did they inspect it and then tell you that or just tell you that when you brought it up to them? If they didn't inspect it, they are just talking out of their ass. You keep having to add brake fluid....there is a leak somewhere. An inspection needs to be done. Now if they inspected it and determined the ABS module is where the leak is, either things need to be tightened up or the bad part needs to be replaced. Brakes are not something to mess around with.
  17. SSM 48993 - 2020 Edge - Adaptive Headlamps - Selection Greyed Out In Instrument Panel Cluster (IPC) Some 2020 Edge vehicles equipped with adaptive headlamps may exhibit an IPC selection of adaptive headlamp that appears greyed out or is not able to be selected. This selection does not affect the operation of the adaptive headlamps. This is characteristic of the vehicle and no repairs should be attempted. APPLICABLE VEHICLES 2020 CAR: DQ CD539N EDGE
  18. Sounds like it’s time for a replacement apim or upgrade to Sync3.
  19. I’ll say it one more time… Pay someone to program it properly.
