Everything posted by onyxbfly
I would suggest deleting your phones bluestooth connection (This unto itself doesn't have an impact on whether or not carplay/ siri will work But i often find it best to start with a clean baseline while diagnosing and troubleshooting things. Especially if it takes all of two seconds to repair your phone) I also see that you have a 2016. Depending on your build date you will need to purchase a newer USB hub that plays nice with iPhone. Google these part numbers... GJ7Z-19A387-B (White USB Port LED's - Lincoln Default) HC3Z-19A387-B (Blue USB Port LED's - Ford Default) If you don't require a new USB hub then continue below: Go into settings/ general/ carplay/ sync 3 and select forget this car. I don't think you're set up/ configured properly. Deleting it will force you to go through all of the connection prompts upon connecting your iPhone via USB. Once you're connected properly you can simply say hey siri and in theory she should work! HTH Good Luck!
Thanks for sharing your thoughts on the pressure washer. I will check out the reviews. I definitely love the idea of not having to haul out the full size pressure washer for small jobs! Thanks once again!
Clunk when baking out of a parking spot (FIXED: SSM 49769)
onyxbfly replied to Outlook214's topic in Edge ST
Sounds like a possible lemon law/ dealer buy back is in order. Dealers don't like either term, but at the point its not an issue with what they like, its an issue of doing right by you. I think you might be eligible. I suggest looking into the local laws in your area. I know you said you're located in the south, but it would be helpful if your included your location. We might have a forum member who can point you in the right direction of a reputable shop that can give you a second opinion. Or someone may have experience with dealer buy backs / lemon law issues in your area. I don't know if this option is available to you or not. My brother recently had some warranty work done at a Lincoln dealership. He said it was one of the best warranty repair experiences hes ever had with his 2015 sport. -
What a great find! Never knew something like this existed. How's the battery life? Maybe I'll get this for my brother for Christmas and I can finally get my pressure washer back!
That is very odd. Perhaps the Powertrain Control ECM needs to be properly calibrated with the correct firmware for your VIN. It very well may be a programming issue. Unless you know what you're doing I wouldn't suggest making any power train modifications using FORScan or any other OEM or aftermarket programmer. I would suggest taking it back to wherever you had the work done and tell them your issue/ concern. It should be a relatively simple fix.
Congrats and welcome to the forum! Great Pic! I would definitely get that framed!
You do not need to fully disconnect the battery. The negative terminal can be a pain to get to. You only need to disconnect the positive lead.
His ST is so fast that it flipped his avatar! That's what happens when you put the s(POR)t back into the ST!!
Omar posted an excerpt from the owners manual. Here is a direct link for the post that is earlier inthis thread.
Locking Out Higher Gears without being in Sport Mode
onyxbfly replied to chipdog4's topic in Accessories & Modifications
Have you checked to see if there are any TSBs for your transmission? I know that the STs came from the factory with some transmission bugs that were sorted out with a few firmware updates. You have the same transmission and from what I understand the issues were not exclusive to the ST. -
Thanks to everyone for painting a broader picture of the inner workings on how the Intelligent Oil Life Monitor system works. I now understand why it can not be changed to a set interval.
Unfortunately it is not an option on any Ford that I have seen from 2015+ Took the words right out of my mouth. I completely get where you're coming from. I was under the impression that the dealer would have to prove that your mod voided the warranty. More importantly your warranty is only voided as far as that particular mod is concerned. You add a rear view camera and your PTU goes out....Your rear view camera doesn't have anything to do with your PTU and thus they can't void your warranty for it. This is one of those times where Ford dropped the ball.... I wonder if Ford would say my turn signal indicator warranty is voided because I increased the number of flashes to 7 as opposed to 3 or 4 whatever it ships from the factory. Not changing your oil is considered failing to maintain your vehicle properly. I wonder what Ford would say to someone if they changed their oil once a year or 10k miles and their engine died. I am good friends with an Amsoil distributor. He says that their oil is good for 10k miles with the use of their filter. I asked him over pool and drinks if Amsoil would cover the repair if an engine died during the 10k mile period due to insufficient oil. You're going to burn some oil during the course of 10K miles. He looked me dead in the eye and said they're supposed to honor it but they would fight you tooth and nail and you would probably spend more fighting it then getting it repaired. I'm pretty sure that Ford would think along those lines.....Maybe Ford knows something we don't.....Maybe their oil is good for 10k. Personally I won't be the test dummy. Sounds a lot like their lifetime PTU fluid.....
How so? I would like to change it to a lower interval. The factory default is 1 year or 10K miles. I drive between locations for work. Some high way but a epic shit ton local streets and or stop and go etc. I prefer to err on the side of caution and change between 3-5K miles.
Would anyone know if you can change the oil change reminder via FORScan?
Couple FMIC questions before I pull the trigger.
onyxbfly replied to MrBelugaBiscuit's topic in 2.7L EcoBoost
I believe that @Perblue has the UP FMIC on his ST. Maybe he can tell you if there is any fitment concerns on installing it on a ST. -
2012 Edge 4in to 8in upgrade
onyxbfly replied to ddixon91's topic in Audio, Backup, Navigation & SYNC
What trim level is your edge? IIRC if its an S/ SE then you will not be able to upgrade. I forget the reason off the top of my head. -
Ultimate Performance intercooler install tips/guide
Reach out to @snmjim and @Special_K! They will sort you out!- 1 reply
LIncoln MKX to Ford Edge Instrument Cluster Swap
onyxbfly replied to onyxbfly's topic in Accessories & Modifications
It's odd because I had the chimes but now I do not. I never had the overspeed chime.- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
Here we go! It's about to go down!
Update Your Gen2 Edge To The Latest Sync Version
onyxbfly replied to Gadgetjq's topic in Audio, Backup, Navigation & SYNC
Exactly why I haven't fooled around with it. I don't know the last time, I listened to public radio and even when I do its via carplay or android auto.- 43 replies
- sync update
- sync 3.4
Sweet! I was walking one of my coworkers through it this weekend! He was having troubles with the the names of the files corresponding with the autoinstall.lst.... Then he asked if I would do it for him.... I asked him what if i was wasn't available to do it for him again in the future.....give a man a fish... eat for a day kinda thought.... I remoted into his PC and brought up the website and walked him through it... He was done in a hour and half..... He then had the audacity to ask why didn't I tell him about the website.... I didn't have any first hand experience with it. He asked what If he bricked his APIM.... I told him he would have brought lunch and a case of beer and I would sort him out. Luckily that didn't happen! But when I left for work this morning there was a case of Shiner's on my steps! To answer your question I have not upgraded the firmware for the APIM. I have the tools, just never got around to it! Lets see what the weekend brings!- 43 replies
- sync update
- sync 3.4
Sync 2 to Sync 3 Upgrade
onyxbfly replied to Totally_Ripped's topic in Audio, Backup, Navigation & SYNC
I did more than a few!
