Everything posted by onyxbfly
Today's cars with all of their modern gadgetry and features require much more of a strenuous demand than say vehicles made 15-20 years ago. IMO aftermarket batteries tend to last longer than their OEM equivalents. I can get 5+ years out of an aftermarket battery and ~3 out of an OEM battery. Manufacturers cut corners wherever and however they can. They're not concerned with how long our batteries last. They're considered a consumable item. People will get them replaced at dealerships under warranty and move on if its not satisfactory or not convenient to go to the stealership. My brother had some crazy experiences.... IPC lit up like a Christmas tree on a few occasions... Random DTCs and CELs. Random starting issues.... Took it to the stealership and they took the entire day to test the battery.... Yeah you read that right! They took the entire day to "test the battery" They replaced it under warranty.... all of the issues went away... It happened again and he replaced with the largest aftermarket battery he could find. His edge has been rock solid for close to two years now! The stealership replaced my battery in April 19..... Seems like its starting to fail.... Guess I'll be shopping for a battery sooner than later.....
SiriusXM Traffic expires soon
onyxbfly replied to 1004ron's topic in Audio, Backup, Navigation & SYNC
I never used it.... How does it compare to Waze and other apps that are available? -
Check for a loose ground strap.
Not only is ODDLink MX+ one of the best devices for FORScan but its an essential part of any automobiles owners tool kit! Turn your iPhone, Android device, or Windows PC into a professional-grade diagnostic scan tool Recommended adapter for FORScan, Torque, BimmerCode, Dashcommand, AlfaOBD, Carista and many more Enhanced OEM support for Ford, GM, Mazda, Nissan/Infinity, Toyota/Lexus/Scion, Honda, Hyundai, Kia Clear Check Engine Light and get more live parameters (ABS, SRS, TPMS, etc) than any other scanner Over-voltage and battery drain protection, firmware updates https://www.obdlink.com/products/obdlink-mxp/
How old is your battery? When was the last time it was replaced? I would suggest getting the battery and charging system tested. It sounds almost as if your battery is on its way out. I would disconnect the negative battery terminal and leave it disconnected for about 30 minutes. Do as Omar suggested. Connect the battery and clear any DTC and then check again. I've seen low/ bad batteries cause all kinds of mayhem on modern cars...our rides in particular are pretty prone to throw all kinda errors/faults check engine lights with a dying battery/ loose ground strap. HTH
I found the following two videos to be very informative:
Welcome to the forum! Excellent color! If I were to ever get a blue edge, I would prefer blue denim over the performance blue on the STs! Glad to hear that Ford is bringing the color back albeit with a different name.
2015 Sport HID replacement?
onyxbfly replied to hyperc32's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
In addition to what Omar and WWWPerf mentioned above. Assuming that you are not the original owner. If you think/ believe that your edge was originally equipped with HID, I would suggest going to a dealership and having them run the VIN and ask them to print you a build sheet. That would be the final word on whether or not you have factory HIDs. Your build sheet will be beneficial because it will tell you what options and features your particular model came equipped from the factory. Or you can go to the parts department (or call) and ask for a replacement HID bulb. Hopefully the counter clerk is serious about their job, and will ask for your VIN to double check...... Most owners want to upgrade from halogen to Hid. I can't imagine the original owner wanting to downgrade factory HID to halogens. -
Livernois, BCB, Unleashed, ZFG will tune your ST
You may be better served by posting your question in the HPTuner Forum. Even if you do not get a answer in a edge specific topic, you will definitely get a lot of answers if you ask about tuning 2.7 eco-boost engines. HTH
Update Your Gen2 Edge To The Latest Sync Version
onyxbfly replied to Gadgetjq's topic in Audio, Backup, Navigation & SYNC
Unfortunately not. If you're located in the USA the you have a MFT2 system. If you're interested in SYNC 3 then you would need to replace the screen and APIM, GPS antennae, USB hub and you need a harness/ interface for the new USB hub since it will not be compatible with your preexisting hardware.- 43 replies
- sync update
- sync 3.4
Welcome to the forum. Yes the ST wheels will fit your SEL.
One would think that living in a major city there would be more offerings....I live in Philly and have friends, and family up and down the coast. Even if it was just a issue of securing the purchase and sorting shipping out later etc. Thanks for the suggestion. Volvo and Jaguar wheels fit as well!
I always check offer up, let-go, Craigslist etc for good deals like yours. In my area the trend seems to be to have items priced $5-$50 off of retail with no tax. Sometimes you can luck up and get some goodies if you're in the market for that particular item. Oftentimes its more miss than hit. I'm sure you can agree there are tons of stuff that are priced ridiculously low but it doesn't matter if your simply not interested in it! I've yet to see any desirable setups available in my area. If you ever decide to sell, I'll double your investment.
I get where you're coming from with some items being hoarded and some items are ridiculously expensive. But I don't think that applies here.... This particular setup has always been in the $2k-$4K price range depending on the configuration.
You made a excellent choice. I haven't heard any negative things about Torrie! If and when you out grow your Unleashed tune, you can shop tuners that use SCT!
Cold Air Intake Edge ST & Sport 2.7EB
onyxbfly replied to Xtra's topic in Accessories & Modifications
That's what she said...... -
Livernois uses the mycalibrator exclusively. Unleashed Tuning uses SCT or HPTuners. ZFG uses HPTuners BCB uses HPTuners or SCT Tuning by James uses SCT Not all tunes are created equal etc. Some prefer using a device that they can use between tuners. Some have their preferred tuner and prefer brand loyalty etc. It will ultimately boil down what mods you have/ want. If your not planning on doing any mods apart from the run of the mill mods then Livernois will rock your world. I believe that the second and third fastest edge used LMS when they ran. (basically traction mods, a thermostat) On some forums some say Unleashed feels faster (butt dyno) than LMS. YMMV On the flip side of the equation, the worlds fastest edge which incidentally is also the worlds most modded edge uses ZFG. Unleashed BCB and ZFG and Tuning by James will tune your car specifically, meaning that your tune is made exclusively for your car and the mods you have. If you're going to go with with larger turbos, catless down pipes, meth, or anything that is not off the shelf, then you're going to want to go with a tuner that will run logs and makes incremental adjustments accordingly. LMS doesn't seem to play nice with mods that they can't tune by dyno. One member lost their motor and other members on other forums etc. Not saying that LMS is bad, quite the contrary. They're good at what they do. If you want to blaze your own path and define your vision of the sport in our edge sports then you should select a tuner that will grow with you and tune accordingly. HTH
I wonder if those parts can be retrofitted to NA edges.....
One of my favorite wheel sets ever!
Omar is located in the Middle East if I'm not mistaken.
