IWRBB
Everything posted by IWRBB
Install complete of replacement head unit
IWRBB replied to Lifeisabeach's topic in Audio, Backup, Navigation & SYNC
So can you use sync voice commands to access the USB drive? Meaning, if you have it selected as a source, can you tell it play track "x" or play album "x"? Can you use Sync voice commands to select it as a source or do you have to go through the head unit screens for that? Same question for the card slot in the headunit. Does voice commands work on those files? -
You have Sync? Nothing is 100% plug and play if you want to keep your steering wheel control and voice control stuff. You need additional hardware for that. The idatalink Maestro will allow you to keep your Sync functions and steering wheel controls with the aftermarket head unit. http://maestro.idatalink.com/
Ford's oil pressures gauges are the same way.. More than 3 psi and it's "normal". Less than 3 psi and you get no reading. Lame.
It's coming in the cowl area if it made a nest at the cabin air filter. Pull the wipers/arms and the plastic cowl cover. At that point you should see evidence of them. Inspect the cowl cover for warpage, incorrect installation or missing fasteners. Edit: I'd put down traps to keep them out. They will ruin the value of the vehicle once they stink it up to high hell by crapping and pissing in your air ducts.
Nothing on the gauge is cold. It will slowly work it's way up from nothing to "normal" as the engine warms up. It can go from 170 to 220+ and still not move from "normal". Once it gets too hot- it'll move towards the red overheat mark. I don't have a shop manual, but someone could look it up and figure out what temps the gauge will respond to over an overheat condition, I'm just guessing at the 220 number.
It's effectively a 3 position gauge. 1) Cold 2)normal temps to *almost* overheating, and 3)overheating. It'll need to be overheating before that gauge ever moves higher than your picture shows. Fords have been like this for at least the last 30 years. They think customers are too stupid to handle information from an actual gauge that shows the actual temperatures, and for 95% of drivers- they are totally correct.
In what junkyard did you find an Edge in Cincinnati? U-pull-n-pay hasn't had one yet according to the inventory on their website. Need to pick up rubber mats for teh console and have been waiting for some to show up in the yards. We have a 2010 Sport in the same color- fantastic paint color. Edit: There's not much in the way of performance parts. Intakes and exhaust will net nothing. Best bet is to leave it alone and pocket the savings.
Nothing is plugged in, stereo is fine. We were planning to drive it and just about fired it up the day before, but then took another vehicle- so maybe we left a door open or something? I thought the lights automatically cutoff after a certain period of time though.
Did you check the lights in the vanity mirrors in the sunvisors? I've seen those stay on- my F150 will do it if the visor is flipped all the way forward towards the glass and the door for the mirror hangs open just enough for the light to come on. Oddly enough, our 2010 Edge drained it's battery about a week ago. Not sure what caused it either. Charged it back up and all is good so far. Will keep an eye on it though.
Car-part.com is the junkyard search engine. I've bought an airbox off there before- it's hit or miss with the communication from certain yards, but that is to be expected.
sun roof closing problem
IWRBB replied to lpgao's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
If you guys don't want to be without your vehicle while a sunroof is fixed, I'd recommend NOT buying a vehicle with a big ass moonroof next time around. We own extra vehicles that we can drive if the Edge had to be fixed, so I figured I'd take a chance with the BAMR on ours. So far, so good. I cleaned and lubed it when we got it used, and we rarely open the glass. Typically we just open the shade for the light/view. Baby girl in the back seat likes to look through the roof while we drive. -
Shock and Struts: help needed with parts choice
IWRBB replied to Wiktor Rawdanowicz's topic in Brakes, Chassis & Suspension
We put a KYB mount on our 08 Taurus when the strut failed early. Didn't have it too much longer after that, but it worked fine while we had it. You list looks good, other than the end links as mentioned above. It'll ride like new. -
If you can get OEM Motorcraft struts, definitely go that way. Otherwise, KYBs or Monroes will be OK. Also, definitely replace the upper mounts you listed as SM5755. At the mileage you have, while you are in there doing the front struts, I'd do the lower control arms (Moog 24000-05268242), which will come with new bushings and ball joints. I'd also replace the sway bar end links (Moog 29007-05459404) - it's easy and cheap. -
Just drill the case, tap it and put in plugs to drain and fill it. Change it at every other oil change. People do it all the time on differential cases for gear oil cooling systems. I bought a 2WD Edge because of this thread! Well, I had a vague knowledge of the problem as not uncommon on the Taurus, but this thread reminded me, no AWD for the Edge!
We have a 2010, glare sucks. Polarized shades or not. I'm 6'3, wife is 5'6, we both notice it. Just the nature of the beast. At least the dash isn't ugly as sin like the 11-14s are.
You are going to have to hit up a junkyard where you can pull the parts yourself. They are OK with you buying the smallest part of an assembly, or buying the whole car.
If you do all that, then go ahead and paint it. Rust converter should be top coated. That's pretty bad for a 2014, but it could have seen the winter of 2013, 2014, and 2015 before you got it. 3 years in Michigan, depending on where, can easily case the rust you are seeing. Most of it looks to be on heavy pieces of steel- the subframe, control arm, strut bodies, so it's really all just "surface rust" when you consider how much steel is left. Rust on the thin body panels is way more of an issue- the bottoms of doors/hood/liftgate, wheel wells, rockers and floor pans are what you need to really keep an eye on.
Car suddenly won't start - My DIY Mission to resolve
IWRBB replied to mrtm2016's topic in 2007 Edge & MKX
I think he's talking about the plastic rivets in the wheel well liner- which he probably removed to do the alternator and belt.- 25 replies
- fuel pump
- electrical
(and 7 more)
Confused about unever rear brake pad wear
IWRBB replied to wlepse's topic in Brakes, Chassis & Suspension
Unless your caliper has pistons on both sides of the rotor (typically only found on higher end sports cars), the pad on the piston side will always wear out first. It will typically show tapered wear as well, more at the front, less at the back. If it's *really* uneven, yea you have a problem. If one looks at 20% more worn than the other, I'd call that normal. Edit: Greasing the slides is a good idea when the tires are rotated. -
Ebay Black Ford Edge Grill installation
IWRBB replied to 3500cc's topic in Accessories & Modifications
From what I've seen with grills like that- you cut out the OEM plastic grill very carefully until the billet one fits. Then you drill mounting tabs into the OEM grill shell. Aint no going back with that type of modification. -
Compass module location and questions
IWRBB replied to ChucklesMcHaHa's topic in Audio, Backup, Navigation & SYNC
It's definitely in the mirror. I've also unplugged the connection to the mirror and only had a "compass not found" warning when the key was turned on. Everything else was fine. -
That's the problem, you can't keep an eye on it. It's behind the timing cover. The A/C in our 2010 does just fine.
I'm in the area too. Up near Mason and West Chester. Candy Red 2010 sport with a black painted grille, 20" chrome wheels- not the 22" polished. Definitely the only one in town that looks like that. Main issue with the 3.5 is the water pump is in the timing cover. If it fails, it can leak water into the oil and trash the engine. Not common, but it happens. Reminds me, I need to get the coolant flushed.
