lildisco
Everything posted by lildisco
My Mom's 2012 Fusion & our '16 Edge had these issues. Found a different lug nut set on ebay/Amazon & haven't looked back. I used a torque stick & they still messed up. What a way to continue to get money from people.
Common problem, but not anything I'd never buy another Ford issue. Easiest thing to do is to get a set of splash gaurds on the front to help keep debris out of there...
I think I've seen mine spike 19 & settle to around 17, but if you're going to get a tune, the higher the psi doesn't necessarily mean a better tune. Many different factors come into play with a tune other than boost. Load based tuning is what I use my CX7 & has served me pretty well with temperature changes, air density changes, etc. Soley using psi to tune can give you issues if you're not careful.
Most drilled rotors aren't going to give you more stopping power. The heat dissipation is going to be better with a quality blank rotor than most drilled rotors. You're better off getting a good blank rotor & decent set of pads. I'm a huge fan of Centric Premium Blanks (many auto x's & road races with no warpage). Pads, i usually go with hawk pads. HPS's are good, but you'll get a lof of brake dust. If you're fine with that, they're a really good pad. PowerStop also makes a decent ceramic pad that i had no complaints with either.
Never cut 1 in 1/2 at the bushing, but it'd imagine that its some sort of mechanism that allows that bolt to swivel a little bit as you usually need an allen key to remove it.
No GPS No Audio - APIM Question
lildisco replied to alanaround's topic in Audio, Backup, Navigation & SYNC
Change battery & check if problem is fixed. With everything being sensitive to battery voltage, that's where i would start. Yes, the vehicle is running, but doesn't mean that the battery can support running electronics. There's also a parameter in forscan than resets the battery parameters. Meaning, when the battery is replaced, you reset this so the ecu knows you have a new battery & it changes the charging parameters & whatnot. -
All gas isn't created equal. Look for top tier gas stations. Make sure your current on oil changes. How many miles are on the car? If higher, closer to 100,000,id change your plugs. Actually, I'd change them out anyways because you don't know how the other person drove. Another thing would be to try resetting the ecu. Just disconnect the negative battery cable for about 10 minutes. Hook it up then let it idle for a few minutes & then drive like normal. The ecu is a learning ecu. If it hasn't been reset since you bought it, it probably has thousands of miles learned from the previous owner(s). Once it learns your driving style, shift points, etc., you should she a few more mpg's. Especially if you're all highway & drive UNDER 70 - 75 mph. Biggest thing is driving style. Medium to hard accelerations are going to be in boost. Boost = more fuel = bag mpg's. Crusing above 70-75 is going to be in boost. But if you cover the basics as i said or stated above, you should see some sort of improvement
RDS on the instrument panel right screen?
lildisco replied to omar302's topic in 2015+ Edge & MKX Generation II
It could be a HD Radio thing. I've never heard 1 in my area. I know that they're around, just i live so far from a major city that i don't think i get good reception. -
My 2.0 doesn't sound nearly as loud as that, but to each their own. It usually goes away after a few seconds. I know that when the oil is lower than the full hole, it makes the noises like what you have. Has nothing to do with the Turbo. You only have 1 turbo btw. The only twin turbo edge is the ST & the 2nd gen Sports. You have a twin scroll turbo. Completely different than a twin turbo set up. The only time the turbo really spools up is when you're making boost & you have to be driving to do that. It kinda 'free wheels' when you're not spooling up the turbo making boost, especially at idle. I know multiple people with 2.0's, 2.3's, 6.0's & 7.3's, etc., with turbo's & have never heard of the turbo(s) spooling up at idle or startup. I have heard them kinda air themselves down after the engine is off & that's only been with the 7.3's & 6.0's, never with a 4 cylinder turbo.
Has the car sat overnight? The 2.0 Ecoboost takes some time to get all the oil back to pan. Also, unless they changed it... The full line is the 2nd hole, not the top of lines on the dipstick
Better off to check the oil level after the car has sat overnight. Bet you're a little low.
2.0L 2 Line Catch Can Install?? Anyone??
lildisco replied to Reptar's topic in Accessories & Modifications
Basically, you're going to cut/splice or add into the line going from the engine block to the intake manifold. You basically want to put it in between the engine block & intake manifold. The length of the lines going to the catch can doesn't really matter, so that you can mount it anywhere you have the space. The purpose of the 3 line system is to also catch blow by during boost & vacuum. -
This may be helpful: Clicky Clicky -
Your paint code should be on the sticker on the drivers side door
Several of us have been waiting since 2016 or earlier for map updates. They haven't come. Only way would be through a Ford Dealer or through here: https://ford.navigation.com/home/en_US/FordNA/USD
2015 Edge Brake Questions. Electronic e-brake etc...
lildisco replied to mhaynes's topic in Brakes, Chassis & Suspension
If you're interested in my brake swap, here's what i did: Clicky Clicky Car is doing fine, swapped out the rear rotors with the same style that are on the front, Centric Premium Rotors. From Centric's website: Centric premium rotors utilize an Electrocoating finish that provides long lasting corrosion protection. E-coating is a superior electro-statically applied finish designed to withstand 400 hours of salt water exposure without rusting. Phosphate finishes utilized by other manufacturers provide only minimal protection from the elements; these finishes are generally only effective for the shipping and storage portion of a rotor’s life. The addition of heat and moisture eliminates the effectiveness of phosphate finishes resulting in immediate corrosion once installed in the vehicle. -
If those pic are of the rear caliper, I'm so glad i painted mine. I've changed all 4 corners out on my '16 SEL & didn't run into any problems. Went with Centric Rotors with the special black coating to keep the rust & flaking down. -
Traction control can be disabled in the left side of your menu, i believe under settings. There's also a display on the instrument cluster that shows you how much power is being sent the rear wheels. I would also look to see what tires you have. If you have High Performance summer tires, then your winter traction will be next to nothing. My bet would have been traction control was going crazy because of the snow/ice under your car. There should have been a dash light indicator if abs/traction control was kicking in. If you have it, i would suggest reading the owners manual & get more familiar with your vehicle. If not available, you might be able to download a copy from fordowner.com
What’s this problem with loud sound on startup
lildisco replied to Rowdyone99's topic in 2.7L EcoBoost
I've had something similar with my 2.0 Ecoboost if the oil isn't to the full mark. It usually would only last for a few seconds. The oil mark on the 2.0 Ecoboost is the top hole, not the line. Not sure if the 2.7 is similar or not -
lildisco replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
XTRA, that's horrible. I don't know what to say, except that i hope that everyone affected is evacuated safely. Property can be replaced. On a much lighter note, i reluctantly swapped over to my winter wheels today after several counties decided to coat the roads with salt like there's an endless supply ? Also added a good'ol coat of fluid film on the underbody. Ran out of fluid film & had to order more. Will get the doors, hinges & other areas later in the week.
