Everything posted by 1004ron
When backing out my garage this morning I notice one of my headlights was orange. Surprised - I assumed that they would just die, not first change color. Anyone have recommendations on replacements and is the LED version a viable option? LED's typically blind oncoming traffic and unless that's no longer an issue I'll consider them.
Shimmy, shake, jiggle, when >50 mph and accelarating - RESOLVED
1004ron replied to 1004ron's topic in All Wheel Drive (AWD)
One more thing - do I need an inner tie rod tool and if so, which one do you recommend? I have a tool for separating the outer tie rods. -
It seems to be just a little worse - at the onset I've tried a lower gear but no change - it can get pretty severe and directly proportional to the torque applied when in the speed range (55 to 65 mph). If I'm steady at around 60 mph and accelerate the shake will start - can actually see the hood shake left to right. After noticing the wear on the inboard edge of the two front tires (see below linked thread) I'm suspecting its tie rods, so this weekend I'll get my wife to assist in jostling the steering wheel while I try to asses which tie rod it is (inner, outer, left, right) I will change both sides but if it's the outer I'll do both outers, unless I find a rubber boot was the root cause I'll rethink the need to do both sides. Now, I'm leaning towards going with Motorcraft unless someone can recommend anything better. In about 15K miles I'll be installing new tires and need this resolved by then. -
Heated and Cooled Seats
1004ron replied to Wedgeamatic's topic in Interior, A.C., Heat, Interior Trim
Please add your Location and Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ -
Not sure if its different on your model/year but if its the 3.5L with internal coolant pump then search the forum for the coolant change recommendations - later M/Y's may have addressed the issue?.
I'm not sure how they arrived at that recommendation, but my OBDLink MX+ BT works flawlessly with Windows FORScan and FORScanLite. I use the same adapter for my wife's BMW X5 and my BMW K1600. This adapter has very good reviews on a number of sites. OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows -
Brake Pedal Goes to the Floor!!!
1004ron replied to makaveli3004's topic in Brakes, Chassis & Suspension
What model? Please add your Model & Year to your profile signature - Settings - Ford Edge Forum -
Fuel Gauge seems to go down quickly after fill up
1004ron replied to Camhr82's topic in 2017-2018 Edge & MKX
No that's not empty. The gauge and remaining miles should only be considered a rough estimate. -
Did you run it empty before adding the 60L ? For the heated and cooled seats try a forum search. -
Welcome. You may have to take it to a reputable mechanic that actually diagnoses it and tells you what's wrong and explains why it needs a new engine, IF that what's needed. If its mobile you could get it scanned for fault codes at a place like AutoZone, or get yourself an OBDII dongle and the free app Forscan to read the codes. "or can anybody tell me why this is happening?" - with the limited information you've provided there's no way someone could tell you what's happening.
- 1 reply
- 1
That is standard practice for all manufacturers - they won't touch a "grey import".
What happened to adaptive steering?
1004ron replied to Wubster100's topic in 2019-Current Edge & Nautilius
Thanks @omar302 Yes, I have the Adaptive Steering - I definitely like the feel / function but also something I could live without. -
Can't remember if my 2017 Sport has this - will check when I get home. -
If I relied on the oil life monitor I'd be changing the oil at around 10K miles, which is twice the mileage I change it at using good brand full synthetic. If I were you I'd change the oil when the oil life monitor is around 50%. Water under the bride but I take the attached photos at each oil change to keep with my Xcel spreadsheet. I don't know, but doubt that Forscan would have that history.
What scanner are you using?
@doubleg2582 What sensors did you buy?
Buying these sensors from Amazon or eBay is hit and miss - sometimes you get lucky. Never heard of multiple ways to set it to learn mode - could you describe the method you used with the hazard button.
I also prefer to trigger them with the car set to relearn rather than wait for them to auto-relearn. Ford TPMS Reset Tool Tire Pressure Sensor Training Activation Transmitter
Welcome. What sensors did you buy and from who/where? If the sensors are good the car will auto relearn the new sensor ID's. There is a procedure to put the vehicle inn relearn mode and use a cheap trigger devices to activate each sensor as needed.
