1004ron
    145
Everything posted by 1004ron
  1. Because it is only a recommendation by Ford, not a specification, there may be some gain using the higher octane, but using lower octane will not damage the engine and will not be a factor in any possible warranty claim. This model engines manufacturing defect is totally unrelated to the fuel used.
  2. Recommended is very different to "specifies" - main reason being that using anything less than the recommended cannot be a factor when deciding a warranty claim.
  3. A bad alternator will not prevent a START as long as the battery has sufficient charge.
  4. My work associate had his replaced by a good indy shop, who bought the new long block from Ford and it came to around $4,500 for the whole job, with no help from Ford. I suggest that we merge this with the existing thread on the issue.
  5. I can't explain the part numbers, but can confirm the new part is working - I've only filled up once and no spluttering at idle, and just scanned it and confirm no codes. It had got progressively worse and would skip a beat when idling whenever the tank was above 3/4. If I ever need this part again, I'll buy only the Bosch valve.
  6. You posted in the wrong section and don't say what V6 model and year. Please add your location and Model/Year to your signature - Settings - Ford Edge Forum
  7. Forum Help & Site Suggestions - Ford Edge Forum Forum Help & Site Suggestions STOP - This section is reserved for topics on how to use this site. DO NOT use this forum for Ford Edge discussion.
  8. I've traveled through Indiana a few times, but have seen more of those buggy's in Pennsylvanian, but never at a Coffee or fast-food drive through.
  9. @enigma-2 ours isn't similar to that. The grill badge and camera are directly in front of the latch and it cannot be seen even using a flashlight. The attached photos will give you an idea where to prod with a long screwdriver - I was able to get it open, but had the benefit of seeing the exact location of the latch. One of those inspection cameras would help a lot.
  10. If the charge warning is coming on when the AC compressor is on, then check the aux belt tension.
  11. If the jump start battery is good and the jumper cables good and well connected to the cars battery connectors, then you need to look for a bad connection, Batt-Neg to chassis, Chassis to Engine, Batt-Pos to main fuse box and to the starter main terminal.
  12. Yesterday the service manager told me that the most common cause of this code is the evap valve that I replaced, but they have seen it caused by a faulty device near the gas tank (forget what he called it).
  13. Found out that my Ford Premium Care has a $100 deductible, so bought a new replacement, installed and cleared the codes. I'll be gassing up late tomorrow after work and will see if I still have the hesitation at idle immediately after filling up.
  14. @ClemsonEE welcome and appreciate the feedback - one of the best 1st posts I've seen.
  15. I'm not familiar with your model so cant help locate the drain, but are you referring to the air conditioner evaporator drain? - just puzzled by the title "coolant" ......
  16. What do you mean by that ? - a wheel bearing going bad you might feel when rotating it, but can't understand how you moved it up and down. A wheel bearing would need to be very bad for it to cause a dropout of signal from the ABS sensor. It the shocks are bad and the wheel not well balanced it could be skipping and the sensor missing a beat.
  17. What model / engine? - please add that to your signature - Settings - Ford Edge Forum
  18. The typical method is to fill it, record the odometer, ride a reasonable distance fill it again recording the mileage and amount of gas it took to fill - come on, I'm sure you know how that's done.
  19. Is it a gauge accuracy issue, or have you checked the actual mpg?
  20. If you're out of warranty you could buy the valve on its own for $16 and use a heat gun to install it on the existing pipe. https://www.ebay.com/itm/224023795357
  21. @Cerberus Just checked mine and it has the same part number. If I suck on the valve with no power on it seems like its shut pretty tight, but the problem could be that it's not opening correctly.
  22. What video? I tried that, and still get the stutter at idle with a full tank. I've not cleared the code, and will only do that after my Dealership has scanned it as part of the warranty check. I'll soon have a warranty replacement from my Dealership and will report back once its installed. Not sure why the sales sites are reporting that the part number is for a 3.0L
  23. This is the latest version part number: Part Number: GL3Z9B325B https://parts.lakelandford.com/p/75109745/GL3Z9B325B.html Non-OEM https://www.amazon.com/Support-Bracket-Purge-Valve-2015-2017/dp/B08PDD9TNW/ref=sr_1_1?dchild=1&keywords=GL3Z9B325B&qid=1633295220&s=grocery&sr=1-1
  24. Not sure if they're suited for tuned models, but the ones I installed about a year ago haven't given any issues, but neither did the stock original plugs, and I haven't pulled one to take a look. Motorcraft SP-542 plug superseded by SP-578? - New Plug Installation DIY - 2.7L EcoBoost - Ford Edge Forum
