1004ron
    168
Everything posted by 1004ron
  1. That oil pressure light ON is a bad sign. You've changed the oil twice, that's good, but more important is the service history, and what you're describing could be the evidence of poor maintenance. It may be to late, but the only option is to get an oil pressure gauge on it and confirm where the normal operating pressure is at - a few things could cause low pressure, such as sludge, fouled oil pump suction strainer, bad bearings, .........
  2. You're right, the new replacement rotors did the same and I stuck it out longer than I should have and now have solid high carbon rotors and very happy with them.
  3. What are you using to scan for codes? - I ask because I've Learn'd the hard way that not all OBDII adapters and apps are capable - I use Forscan for that now. You can also use Forscan to display live data, and view the throttle pedal position, throttle demand, and throttle position feedback, and this may shed light on what's wrong, but I'd start with scanning for codes with suitable equipment.
  4. IMG_2009.HEIC Change your iPhone camera setting to "Most compatible" and it will save photos in "jpg" not "HEIC".
  5. https://www.fordedgeforum.com/topic/30312-8f35-fluid-change-tips/?tab=comments#comment-223013
  6. @Haz this time the service manager didn't ask for the old parts, like he did when I changed the front brake hoses. Yeah, it would be nice to get Reward points. They sure do submit it, because CarFax is no longer showing this overdue.
  7. If you need more information than what can be found in the post linked (six above your post), then it might be best to explain what part of the process you need more info on.
  8. Can't overfill if its trickling out the fill hole. Is that a typo? - shouldn't it be 75w140 or does the 2019 use 75W90?
  9. How much did you put in? Safest is to fill until it trickles out the fill hole. There's numerous reports of errors in the listed quantity.
  10. Not easy to overfill if the if the fill hole is open.
  11. Yes. Fill the PTU's until the oil trickles out the fill hole.
  12. If its displaying signs of low oil pressure only when its warm, then it may be a badly worn engine, but the only way you'll know is by using an oil pressure gauge. What's the service history? Could be the result of poor maintenance.
  13. Because of my lack of confidence in the Sync3 routing and that my 5 year Sirius Traffic has expired, and I've recently been using Waze with a cable, I'm now ready to get a wireless Carplay device. I'm looking at the OTTOCAST Wireless CarPlay Adapter 2022 which is $85 on Amazon with the $30 coupon. Would appreciate advice on what device to get, and where to get it.
  14. I was off-track thinking of "Engine Air Intake Temperature".
