Tightanium
Everything posted by Tightanium
  1. Tightanium
    Sold my Edge
    Even though I never put a wrench to my Edge, except for maintenance, It’s been nice using this forum to learn a lot about it. I just had an itch to upgrade my car. I hope it’s as reliable as the Edge as there are lots gadgets on this thing. I now have a 2025 Lincoln Aviator reserve 2.
  2. 9 years of driving mine. Only had to do maintenance. No broken parts. Runs like it did new. Still like everything about it. Been a great car.
  3. 70k on my 2016. Not a single problem.
  4. I finally did it. 54k on orange. Changed it to yellow. 5 drain and fills with distilled water. Then put in 1 gallon of yellow, drove around for awhile, drained it once more in a clean container, filled with one more gallon of yellow. It tested with just a bit more of antifreeze then water. So I’ll adjust that later. The first drain of antifreeze in clean container is now saved for top off as its real close to 50/50 mix now. Actually it’s got more water then antifreeze. Or I’ll use it in my F150 when I swap out the orange. I also changed the oil and PTU fluid. Just throwing that out there. I don’t know why but doing maintenance always puts a smile on my face when I drive it. ?
  5. This is the gauge you should use. Almost 100 hours of driving there.
  6. Isn’t the first little line left of 15 your real average mpg? I don’t really look at that gauge for mpg. I try using trip 2 as ave mpg. Sometimes I never reset 2 and after 4 or 5k Miles I’m at 19 mpg.
  7. I replaced OEM 19’s with OEM 20’s. I was tired of the silver rims.
  8. I’m always blown away when someone buys a 135000 mile car and expects no problems. Chances you take when you buy used.
  9. So if you don’t believe this will help you’re going to leave your coolant in way to long ? Atleast changing it makes me feel better weather it works or not. I’m not sure it will help either but why take the chance.
  10. I did this to mine while on the car. I think you have to remove the bumper to get the grill off.
  11. My 2016 Titanium has been flawless. No issues.
  12. A little OCD.? My 2016 is 1/8 inch off. Maybe the 2018 is different again.
  13. Ok I apologize. There were no 2018’s on the lot but several 2019’s. I could not see the outline on the 19’s but in my defense the 3 2016’s looked just like mine. And Omar’s. Maybe they changed that in 2018? You could pay more then $45k for on F150 and have this. Just saying. I guess that’s why it doesn’t bother me. I thought it was suppose to be there. My apologies.
  14. Mine doesn’t look any worse then omars pic. I’ll admit I don’t go around looking at all the vehicle dashes to see if they have an outline or not. It’s probably suppose to be like that. And I’m pretty sure Ford won’t do crap to fix your outline. Since you didn’t post a pic of your dash I’ll do you a favor. I’m scheduled for an oil change today at the dealership. I’m going to look at as many Edge dashes that I can and let you all know what I see.
  15. I can see mine. But it’s not a big deal to me. I thought it was normal.
  16. Tightanium
    Delivered!
    Mine have been good. I don’t feel mine are loud. Used them in deep snow ok. I might buy again.
  17. What do you mean the position of the valve?
  18. I did the Drive Bright hid conversion 2 weeks ago and all I can say is what a difference. I did the 5000k bulb. If you want a perfect match with the signature lights I think you should opt for the 6000k. Overall I’m super happy. Only thing is is I can hear a buzzing noise coming from one of the modules mostly when first turned on. You can’t hear it inside the car but it’s on both headlight harnesses. Anyone else have this ?
  19. 3 stage paint job. Can’t remember the name of it but first paint had something to do with the grill being plastic. 2nd paint was color. 3rd was clear coat with a little more hardener in it. I was afraid of rock chips. So far only one small one. I’m not a fan of painting grills because they do chip. But I just couldn’t take the silver anymore.
  20. I don’t blame you. I’m really using you to test some things. I’m going to send a pic just for fun.
  21. http://www.fordedgeforum.com/topic/10914-ptu-leak-failures/page-30 It will work. I used it on my 2016 Tightanium.
  22. My 2016 Tightanium does the same as yours. I thought it was normal.
