Everything posted by mvan231
Welcome! I'm running a 2016 SEL 2.0 EcoBoost also in SE MI. Hope you are enoying the ride!
My 2016 was able to update via Wi-Fi
If you're hardwiring, you'll want it to be ignition switched or at least computer controlled like the cigarette lighter / power port is. there are some great fuse taps you can pick up at a parts store for pretty cheap. As for the fuse to use, I think you'll want to look into the Extended Power Module possibly. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O33761&countryCode=USA&languageCode=EN&marketCode=US&viewTech=IE&chapterTitleSelected=G1676239&subTitleSelected=G1820962&topicHRef=G1820963&div=f&variantid=4224&vFilteringEnabled=False&userMarket=USA I can't get into the AutoMate site right now, but depending on your location, you could access it via Michigan Education Library: https://mel.org/welcome I attached the fuses export from the Owners manual for your reference: Fuses.pdf
Sounds like a rough situation. Hopefully after drying things out it'll all be fine and well for you
I love the '16 we just got. It's been a great adjustment into the crossover world for me since I owned a Fusion prior to. I explain the Edge as a taller version of the Fusion (since they are based on the same platform). It's a great vehicle and I really enjoy it. Heated steering wheel is a great feature for sure! I don't know of anyone who has said they don't like having it
That is terrible news! Flooding can cause some serious problems in the immediate or long-term future. I'd double check with your insurance company about the flooding and see if they can cover any possibly future damages but its probably a tough situation since nothing bad happened (as far as you know)
grease Grease Dripping Out of Rear Hatch (2016 Edge SEL)
mvan231 replied to mvan231's topic in Exterior & Body
I was wondering if it was something like a rust preventative or the like. Sounds like you're probably spot on. Thanks for the good advice on that! -
2016 Edge SEL: I'm curious if anyone has had issues with grease "dripping" out of their hatch door from the vent/drain holes at the bottom of the door. I noticed an odd colored spot on my rear bumper cover this morning and when I touched it, realized it was grease. It is amber colored and I noticed some droplets or drips of the same substance on the drain hole at the bottom of the hatch. This was only on the passenger side of the door strangely.
This is quite interesting. I may have to take mine in to get it checked out as I have a similar issue but mine only seems to be when throttle is wide open and accelerating it hesitates and seems like slipping. I'll have to try FORScan and also bring up to the dealer. Still covered under powertrain warranty, so hopefully all will be covered if it is a mechanical issue
I posted some schematics about this same issue in a different thread. https://www.fordedgeforum.com/topic/12832-cooling-fan-problems/?page=2 If you need more schematics, let me know and I can see about it.
That is quite interesting that it isn't in the diagram. Do you have photos of the unit? I wonder if you apply direct power to the fan motor power if it will spin. Could be that the cooling fan module itself is dead
Have you captured any wiring diagrams to start diving into the power and ground of the circuit itself? I looked them up and it looks like this isn't a typical relay controlling a high current circuit like a blower motor relay circuit would be. Apparently the module has a relay, but there is no direct method to power the fans. Which relay were you checking? I don't see a relay for cooling fans in the underhood fuse panel diagram.
Thanks for letting us know about this. I will definitely keep this in mind on my 2016
2015 Edge Sport 2.7 Ecoboost - Code P1450 - Purge valve
mvan231 replied to druegeme's topic in 2.7L EcoBoost
I had a similar set of faults on my Fusion when I still had it. Evap Purge Valve assembly is a usual culprit. Took me about an hour to change due to tight clearances around the disconnect areas, but after changing it, the light turned off. No need to clear the codes. -
Weathertech Front and Rear floor liners 15-19 Edge
mvan231 replied to Close to the edge's topic in Classifieds
What price are you selling for? -
click/tin sound from underneath when opening door
mvan231 replied to cv27's topic in Exterior & Body
I hear it sometimes on my 2016 in the same scenario, but it doesn't happen all the time -
Sounds like it could be a bad seal or possibly an issue with the door seams themselves. Have you investigated further?
mvan231 replied to ben senise's topic in Accessories & Modifications
It would be brilliant to generate some sort of manual including how-to setup, initial connections, CAN bus to use, etc. It would be a ton of work though. -
What engine do you have? This looks to me like the connection / quick disconnect (not actually very quick from my experience) for part of the evaporative emissions system. The Canister Purge Valve assembly has connections like this right in that same area
2016 Edge Transmission Hard Shifting
mvan231 replied to Maverick's topic in Recalls, TSBs & Warranty
Yeah, planetary gearsets are crazy! They work great, but they are very interesting to study -
Wow! That is pretty interesting actually. Crazy the kind of things that can be done with transmissions. Most people have no clue how they work either -
that really gives you the warm and fuzzy feeling about the algorithms inside the software, doesn't it? -
Unfortunately, the code is back. I'm seeing values between 0.1V and 0.9V for the downstream sensor. The upstream sensor only reads out A/F ratio and current. Current readings seem to fluctuate between 0.4A and -0.3A. Not it sure if this could mean the catalytic converter is going bad? I saw some other code pop up as pending. It was P013E which I saw online is a delayed response from the downstream sensor. P013E DTC info
