akirby Posted June 25, 2014 Report Share Posted June 25, 2014 I don't see any oil. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 25, 2014 Report Share Posted June 25, 2014 Towards the back, above/behind the stamped letters/numbers. I was thinking maybe residue from previous service/leak, but wasn't sure. Quote Link to comment Share on other sites More sharing options...
akirby Posted June 25, 2014 Report Share Posted June 25, 2014 Sorry my eyes aren't that good. Quote Link to comment Share on other sites More sharing options...
1102adam Posted June 26, 2014 Author Report Share Posted June 26, 2014 Thanks guys, I am thinking where it was in garage so long. They spilled some stuff. First oil change about 900 miles away. I am at about 4200 miles now . Quote Link to comment Share on other sites More sharing options...
carguy75 Posted February 10, 2015 Report Share Posted February 10, 2015 (edited) Hope that's not black looking fluid? Did you smell it? Black would be more typical of the PTU overflowing its' vent. Otherwise, there is no overflow as such for the transmission fluid. It can leak at the trans-PTU seal though. I would suggest getting some engine degreaser and cleaning off that area to make sure you get a "clean" sample if it happens again. When was the last oil change? Sure hope it's not engine oil, WAY WAY too early. I have a similar black oily residue on my passenger side. However, I look at the PTU and it looks dry in the area except some old residue on the block. Where is the PTU vent? Edited February 10, 2015 by carguy75 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 10, 2015 Report Share Posted February 10, 2015 (edited) It's a tube that sits on top of the PTU (power takeoff unit, AWD vehicles only) to allow expansion room for the PTU fluid during normal operation. Except that sometimes the fluid gets so heated that it spills out the tube. Ford has this issue on some models with the RDU (rear differential unit, AWD only) as well. Both have a TSB of replacing the vent with a longer tube to keep the fluid contained. Edited February 10, 2015 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
carguy75 Posted February 11, 2015 Report Share Posted February 11, 2015 (edited) It's a tube that sits on top of the PTU (power takeoff unit, AWD vehicles only) to allow expansion room for the PTU fluid during normal operation. Except that sometimes the fluid gets so heated that it spills out the tube. Ford has this issue on some models with the RDU (rear differential unit, AWD only) as well. Both have a TSB of replacing the vent with a longer tube to keep the fluid contained. Thank you. I have just bought a loaded 2011 Edge SEL AWD with 22000 a few days ago, and just noticed that it leaves a oil spot on my garage floor near the front passenger side under the pulley/radiator area. I will take it to the dealer next week to address it, and look at the rear near the transmission since I noticed some oily residue near the PTU/rear engine area when I crawled underneath it for a more in-dept inspection. Not a good start to my new relationship with my Ford Edge or the dealership I bought the car from. Luckily, I bought an extended full comprehesive 36 month warranty to buff the remaining Ford powertrain warranty considering a Ford service guy told me over the phone that the fluid on the floor could be coming from the power steering pump,transmission cooler, or ac condenser which are not covered by the power train warranty. Edited February 11, 2015 by carguy75 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 11, 2015 Report Share Posted February 11, 2015 Hopefully this will be the only trouble spot for a while! PTU fluid is generally dark brown in color, and may have a stink to it. Power steering hoses can leak, not sured that's completely covered under warranty. Transmission cooler problems are rare, I do remember a forum member having an issue with that. AC condenser, not really. Quote Link to comment Share on other sites More sharing options...
carguy75 Posted February 22, 2015 Report Share Posted February 22, 2015 (edited) My leaks turns out to be from a faulty AC condenser/transmission cooler per Ford service shop tech. The Ford service tech said that the AC condenser and transmission cooler are the same unit or inseparable, therefore if one fails then both have to be replaced. Edited February 22, 2015 by carguy75 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 22, 2015 Report Share Posted February 22, 2015 Under warranty, I hope? Quote Link to comment Share on other sites More sharing options...
carguy75 Posted February 22, 2015 Report Share Posted February 22, 2015 (edited) Yes, thankfully I bought a comprehensive warranty with zero deductible soon after buying the Edge through my bank since I got the car so cheap with low miles. We got a "good" deal on the Edge, however I am rethinking about buying cars from non-make specific dealers due to the surprises that always pop-up from these discount dealerships. If I did not buy the extended warranty I would be very very pissed about the situation since Ford's powertrain warranty do not help with the current issue, now I am just a little crossed and will not buy a car from that dealership again. Next used car I buy will be a Certified pre-owned. I got burned too many times with these cheap dealerships with cars that needed repairs that seemed like they were covered up instead of fixed before it was sold. FYI, my Edge had a very small leak that dripped slowly. I did not notice a leak on the black dealer parking lot, but it started to show on my light gray concrete garage floor after about a day or so. I decided to just keep the car due to the fact that I already paid for the extended warranty which will fix any problems in addition to the Ford powertrain warranty. Edited February 22, 2015 by carguy75 1 Quote Link to comment Share on other sites More sharing options...
luckychance Posted July 8, 2015 Report Share Posted July 8, 2015 hi, is the ptu found only on awd vehicles? i have noticed a leak coming from that area as well and some threads have suggested the ptu but mine is a fwd. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 8, 2015 Report Share Posted July 8, 2015 Correct, the PTU is an AWD-only thing. If you have a leak in that area, it could be an input shaft seal, or even power steering line. Can you tell what color the fluid is and what it smells like? Check the trans/power steering fluid levels? Quote Link to comment Share on other sites More sharing options...
brian1 Posted Friday at 01:33 PM Report Share Posted Friday at 01:33 PM I just had a problem with a Ford Edge. I'm a mechanic, what I fixed was AC. I gave it a test drive then all of a sudden low oil pressure light came on and then I heard a bunch of ticking and knocking from under the hood. I came on these forms just to make sure I wasn't missing anything. But with your concern, yes there can be a soft ticking that is from your lifters/fuel injectors. If you're hearing loud ticking/ knocking do not drive anymore and have a professional or somebody that knows what the hell they're talking about check your vehicle out. If you live in AZ I'm willing to look at it. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 18 hours ago Report Share Posted 18 hours ago On 8/14/2026 at 9:33 AM, brian1 said: I just had a problem with a Ford Edge. I'm a mechanic, what I fixed was AC. I gave it a test drive then all of a sudden low oil pressure light came on and then I heard a bunch of ticking and knocking from under the hood. I came on these forms just to make sure I wasn't missing anything. But with your concern, yes there can be a soft ticking that is from your lifters/fuel injectors. If you're hearing loud ticking/ knocking do not drive anymore and have a professional or somebody that knows what the hell they're talking about check your vehicle out. If you live in AZ I'm willing to look at it. Welcome. What work did you do on the AC and how do believe that work was related to the low oil pressure event? What rates do you charge? Quote Link to comment Share on other sites More sharing options...
edjunior Posted 7 hours ago Report Share Posted 7 hours ago Also Brian, first, welcome to the forum. Also, in case you didn't notice, you responded to a post that is 11 years old. Not necessarily a bad thing, just note it in case you don't get a response from the poster. Quote Link to comment Share on other sites More sharing options...
