All4spl Posted May 18, 2020 Report Share Posted May 18, 2020 Thanks, I found an easy cheaper way to get rid of the ANC, there are 3 mics in the Edge ST, 2 front one rear. I pulled the seal up on the rear top of the hatch opening and gently pulled down the headliner, its held up with magnets. Got enough room without doing anything else to squeeze my hand in there and popped off the plug to that mic, and the ANC is now off. Quote Link to comment Share on other sites More sharing options...
2FAST4U Posted May 18, 2020 Report Share Posted May 18, 2020 Do all the Edges have this?... or is it only on the ST's? Claude. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 18, 2020 Report Share Posted May 18, 2020 4 hours ago, 2FAST4U said: Do all the Edges have this?... or is it only on the ST's? Claude. On the 2015-2018 models, only the Sport had it. For 2019+ I'm not sure, but the order guide shows it only with the ST. Quote Link to comment Share on other sites More sharing options...
dajo2012 Posted May 18, 2020 Report Share Posted May 18, 2020 (edited) My 2020 does not seem to have it. I have never heard one with the piped in sound but all I hear is engine winding up a very pleasing sound to me. I would like to hear the ANC it if someone could post video. Edited May 18, 2020 by dajo2012 Quote Link to comment Share on other sites More sharing options...
akirby Posted May 18, 2020 Report Share Posted May 18, 2020 6 minutes ago, dajo2012 said: My 2020 does not seem to have it. I have never heard one with the piped in sound but all I hear is engine winding up a very pleasing sound to me. I would like to hear the ANC it if someone could post video. It was disabled sometime during the 2019 model year. Software updates will disable it on early build 2019s. Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted May 18, 2020 Report Share Posted May 18, 2020 A Car & Driver article mentioned the piped in sound for the ST noting it only happens when the 'sport' button is pressed. That kind of makes sense. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 18, 2020 Report Share Posted May 18, 2020 12 minutes ago, Gadgetjq said: A Car & Driver article mentioned the piped in sound for the ST noting it only happens when the 'sport' button is pressed. That kind of makes sense. Also true but that's what the software update disabled midway through the 2019 model year. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 18, 2020 Report Share Posted May 18, 2020 27 minutes ago, akirby said: Also true but that's what the software update disabled midway through the 2019 model year. Disabled completely or reduced? On my 2016 Sport, it is there but just a bit. Opening the driver's door (just to get the interior lights on) will disable it and the difference is noticable. But it no where as much or annoying as what I heard in reviews for the 2019 ST when it came out. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 19, 2020 Report Share Posted May 19, 2020 On 5/18/2020 at 4:31 PM, omar302 said: Disabled completely or reduced? On my 2016 Sport, it is there but just a bit. Opening the driver's door (just to get the interior lights on) will disable it and the difference is noticable. But it no where as much or annoying as what I heard in reviews for the 2019 ST when it came out. Reports were it was completely disabled but I don't think we ever got an official answer. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 23 hours ago Report Share Posted 23 hours ago (edited) On 9/1/2019 at 1:37 PM, 1004ron said: 9=FT present & CS: North American & ANC absent & USB present Wouldn't "9" be correct for my vehicle? On 9/1/2019 at 2:16 PM, Gadgetjq said: Think you're right, either 9 or A (ANC Present). Maybe make a choice based on what's already in that x slot. Be sure and note the original setting just in case you don't get the result you expect. I'm going to give this another try. Mine doesn't have a 9 or an A in this slot, but might experiment with it set to 9. This is what mine is currently set to as per the original As Built file: 727-01-01 10A0 F200 00D2 As can be seen in the attached photo, it does have front tweeters. 727-01-01 xxxx x*xx xxxx Front Tweeters (FT) & Chime Strategy (CS) & ANC (fake engine sound) & USB 0=FT absent & CS : North American & ANC absent & USB absent 8=FT present & CS: North American & ANC absent & USB absent 1=FT absent & CS : North American & ANC absent & USB present 9=FT present & CS: North American & ANC absent & USB present 2=FT absent & CS : North American & ANC present & USB absent A=FT present & CS: North American & ANC present & USB absent 3=FT absent & CS : North American & ANC present & USB present B=FT present & CS: North American & ANC present & USB present 4=FT absent & CS : CIMCA & ANC absent & USB absent C=FT present & CS: CIMCA & ANC absent & USB absent 5=FT absent & CS : CIMCA & ANC absent & USB present D=FT present & CS: CIMCA & ANC absent & USB present 6=FT absent & CS : CIMCA & ANC present & USB absent E=FT present & CS: CIMCA & ANC present & USB absent 7=FT absent & CS : CIMCA & ANC present & USB present F=FT present & CS: CIMCA & ANC present & USB present Edited 13 hours ago by 1004ron Quote Link to comment Share on other sites More sharing options...
omar302 Posted 8 hours ago Report Share Posted 8 hours ago 15 hours ago, 1004ron said: This is what mine is currently set to as per the original As Built file: 727-01-01 10A0 F200 00D2 This is my stock 2016 Sport with the Sony system: 727-01-01 90A0 F200 0052 Quote Link to comment Share on other sites More sharing options...
