my 2012 edge Posted December 17, 2020 Report Share Posted December 17, 2020 I get this warning when I start my 2012 edge. It goes away after I start driving. I put a new serpentine belt on and a brand new battery. Auto zone says the alt. Is good. When I drive the car I use the torque app to check batt voltage and it is usually 14 volts. Any idea why I keep getting this warning thanks Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 17, 2020 Report Share Posted December 17, 2020 could be the terminals are not secured properly, either on the battery or the alternator. but it may be in the early throes of alternator failure (worst case scenario). was it acting up before you put in the new battery? what prompted the change? Did you let the BMS relearn the new battery? Easy way is to unplug every aftermarket device, shut the engine off, lock the vehicle, and walk away for 8+ hours. During that time, the PCM will test the charging characteristics of the new battery. Otherwise it will use the old profile from the previous battery, which may not properly charge the new one. Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 17, 2020 Author Report Share Posted December 17, 2020 Yes it was acting up the battery died it was 3 years old. Hiw do you rest the bms? Is locking the vehicle overnight enough? Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 17, 2020 Author Report Share Posted December 17, 2020 I don't have any aftermarket things except remote start Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 17, 2020 Report Share Posted December 17, 2020 10 minutes ago, my 2012 edge said: Yes it was acting up the battery died it was 3 years old. Hiw do you rest the bms? Is locking the vehicle overnight enough? yes. follow my instructions in the post above. should work. on the offchance that it does not, the dealer may have to manually reset the BMS thru software, OR you can do it yourself with Forscan for Windows + Extended License. Do you have a fuse you can pull for the remote start? If not, it is what it is, I guess. Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 17, 2020 Author Report Share Posted December 17, 2020 I'll have to try pulling the fuse Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 17, 2020 Author Report Share Posted December 17, 2020 Whats forescan. For windows? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 17, 2020 Report Share Posted December 17, 2020 https://forscan.org/home.html https://forscan.org/download.html 1 Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted December 19, 2020 Author Report Share Posted December 19, 2020 Battery died thus morning. My mechanic said its the alternator 2 Quote Link to comment Share on other sites More sharing options...
14AWD3.5 Posted August 14, 2021 Report Share Posted August 14, 2021 What was weird for me this week is other than "No Key Detected", I never got any indication of a battery failure/low voltage either before or during my week long issue with a bad battery. no check engine light, code, alternator charging idiot light, nothing. There was no way that I could find to see any voltage display on any screen in my Limited. Until the battery went dead, I had zero issues or warning. Not cool at 11:15 pm after a long shift at work. Only after I removed the dead battery and switched it out for an rv battery that I had did I get a motor symbol on the dash. Quote Link to comment Share on other sites More sharing options...
Bertelle Posted October 9, 2021 Report Share Posted October 9, 2021 I also have an issue with "Check Charging System Warning" light in 2012 Ford Edge Limited. I replaced the battery and altenator. The light still comes on, but it doesn't shut off like it did before new altenator. Most of the time it seems to come on when the air compressor comes on. Sometimes it's on for a second and others for a few minutes. I have no aftermarket additions and have left it untouched and locked for days. I'll try the forscan because I prefer to DIY. Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 9, 2021 Report Share Posted October 9, 2021 29 minutes ago, Bertelle said: I also have an issue with "Check Charging System Warning" light in 2012 Ford Edge Limited. I replaced the battery and altenator. The light still comes on, but it doesn't shut off like it did before new altenator. Most of the time it seems to come on when the air compressor comes on. Sometimes it's on for a second and others for a few minutes. I have no aftermarket additions and have left it untouched and locked for days. I'll try the forscan because I prefer to DIY. If the charge warning is coming on when the AC compressor is on, then check the aux belt tension. Quote Link to comment Share on other sites More sharing options...
Bertelle Posted October 10, 2021 Report Share Posted October 10, 2021 Thanks for the info. I'll look into it 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 11, 2021 Report Share Posted October 11, 2021 Check the ends of the battery cable grounds. Bet you're going to find one corroded, probably on the engine block. Quote Link to comment Share on other sites More sharing options...
Cynthia Ogle Posted November 10, 2024 Report Share Posted November 10, 2024 2013 fordd edge. "Check charging system" warning came on yesterday but my car was running/starting fine. In my way home today my radio went off and it read " battery saver system shut down." Everything shut down. I couldn't even turn on my flashers but my car was still running. I shut it off for about 5 minutes &everything came right back. I drove it maybe another 2 miles and same thing happens. I got it a little closer to home but she went down again but then was jerking real bad. I parked it. I'm thinking the alternator at first, now I'm thinking battery or battery cables. 😐 Quote Link to comment Share on other sites More sharing options...
edjunior Posted November 10, 2024 Report Share Posted November 10, 2024 Welcome to the forum Cynthia. Start with the easy stuff first. In this case, the battery. If you can get it out, take it somewhere and have it checked (Autozone, O'Reilly's, etc.). Also, if you can get a code reader, see if any codes are stored. I'm guessing there will be some. Let us know what you find out there, and we can go from there. 2 Quote Link to comment Share on other sites More sharing options...
logan1234 Posted June 6 Report Share Posted June 6 Having same issue as Cynthia Ogle and GinaVN with our 2014 Ford Edge. Error popped up around the end of last year and after changing the battery we were told to monitor. In March, the car shut down while driving. Replaced the alternator then. We were in the clear for about a month or two without an error message and then it this week the car shut down again while driving. Our mechanic said to bring it to the dealer since it seemed like software issue. The dealer, in their wisdom, said the best first step is to replace the alternator and battery again before taking any other troubleshooting steps. Did y'all ever figure out what fixed this? From the forums I've seen, this is the short list of other things to check: - Battery cable ring sensors - Battery cable grounds (corrosion on engine block) - Reset BMS - Remote Start Fuse - AUX Belt tension Thank you! 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 21 Report Share Posted July 21 I'd first suspect the compatibility with the ring voltage sensor and the new AGM battery. I Googled and the AI found if they the combo isn't compatible, or if the ring voltage sensor is defective, it can set a gen light. If you have an old lead acid battery, I'd try substitute the AGM with it and see if you still get the light. Quote Link to comment Share on other sites More sharing options...
scotch Posted Tuesday at 08:09 PM Report Share Posted Tuesday at 08:09 PM I have a problem with a 2016 Ford Edge with the V6 3.5 SE It's actually my daughter's car, and she has been battling this charging light for about three years. Every time she has been over at our place, I checked the charge, and it reads 14.5 volts with the warning light on, and of course, the engine running. I bought a new OEM alternator and had a local garage fit it, still the same. I also asked the garage to check out the CCT. They said it could be the ECM, and so I asked them to change it, and that was done. And guess what, the fault is still there. im at a loss. Can anyone help me, please? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Wednesday at 12:22 AM Report Share Posted Wednesday at 12:22 AM You didn't mention whether you checked the BMD (battery Management System.) It's attached to the negative battery cable. It measures the battery's voltage, current, and temperature & tells the alternator how to charge the battery at the proper rate, Quote Link to comment Share on other sites More sharing options...
