Check charging system warning
my 2012 edge
could be the terminals are not secured properly, either on the battery or the alternator. but it may be in the early throes of alternator failure (worst case scenario).
was it acting up before you put in the new battery?  what prompted the change?
Did you let the BMS relearn the new battery?  Easy way is to unplug every aftermarket device, shut the engine off, lock the vehicle, and walk away for 8+ hours.  During that time, the PCM will test the charging characteristics of the new battery.  Otherwise it will use the old profile from the previous battery, which may not properly charge the new one.
10 minutes ago, my 2012 edge said:
Yes it was acting up the battery died it was 3 years old. Hiw do you rest the bms? Is locking the vehicle overnight enough?
yes. follow my instructions in the post above.  should work.  on the offchance that it does not, the dealer may have to manually reset the BMS thru software, OR you can do it yourself with Forscan for Windows + Extended License.
Do you have a fuse you can pull for the remote start?  If not, it is what it is, I guess.
  • 7 months later...
What was weird for me this week is other than "No Key Detected", I never got any indication of a battery failure/low voltage either before or during my week long issue with a bad battery.
no check engine light, code, alternator charging idiot light, nothing.  There was no way that I could find to see any voltage display on any screen in my Limited.
Until the battery went dead, I had zero issues or warning.  Not cool at 11:15 pm after a long shift at work.
Only  after I removed the dead battery and switched it out for an  rv battery that I had did I get a motor symbol on the dash.
I also have an issue with "Check Charging System Warning" light in 2012 Ford Edge Limited. I replaced the battery and altenator. The light still comes on, but it doesn't shut off like it did before new altenator. Most of the time it seems to come on when the air compressor comes on. Sometimes it's on for a second and others for a few minutes. I have no aftermarket additions and have left it untouched and locked for days. I'll try the forscan because I prefer to DIY.
If the charge warning is coming on when the AC compressor is on, then check the aux belt tension.
  • 3 years later...
2013 fordd edge. "Check charging system" warning came on yesterday but my car was running/starting fine.  In my way home today my radio went off and it read " battery saver   system shut down."
Everything shut down. I couldn't even turn on my flashers but my car was still running.  I shut it off for about 5 minutes &everything came right back. I drove it maybe another 2 miles and same thing happens.  I got it a little closer to home but she went down again but then was jerking real bad. I parked it. I'm thinking the alternator at first, now I'm thinking battery or battery cables. 😐
Welcome to the forum Cynthia.  Start with the easy stuff first.  In this case, the battery.  If you can get it out, take it somewhere and have it checked (Autozone, O'Reilly's, etc.).  Also, if you can get a code reader, see if any codes are stored.  I'm guessing there will be some.  Let us know what you find out there, and we can go from there.
I have this issue right now with my 2014 Ford Edge. Alternator replaced in Sept 2023. Kept throwing “Check Charging System” …. Dealership replaced alternator and did all other routine maintenance.
 It wasn’t a daily driver from Sept 23 to June. And since then the light comes on and off. Well, Monday everything shut down. Car wouldn’t start. Was jumped. Advance said alternator and battery were allegedly fine. But maybe starter. Took to dealership, they report back just needs new battery. Battery replaced, 5 miles later same error. Go back to dealership. They “reset” everything. Same error again.
Seems this is a known issue on this forum and others. But I’ve been to two dealerships without success. Anyone know what I need to specifically tell them when I take it back?
No “aftermarket” anything, but vehicle does have remote start and seat warmers. I mention seat warmers only because they were also “fixed” in September 23.
thanks!!!
  • 6 months later...
Having same issue as Cynthia Ogle and GinaVN with our 2014 Ford Edge. Error popped up around the end of last year and after changing the battery we were told to monitor. In March, the car shut down while driving. Replaced the alternator then. We were in the clear for about a month or two without an error message and then it this week the car shut down again while driving. Our mechanic said to bring it to the dealer since it seemed like software issue. The dealer, in their wisdom, said the best first step is to replace the alternator and battery again before taking any other troubleshooting steps. Did y'all ever figure out what fixed this?
From the forums I've seen, this is the short list of other things to check:
- Battery cable ring sensors
- Battery cable grounds (corrosion on engine block)
- Reset BMS
- Remote Start Fuse
- AUX Belt tension
Thank you!
I have a 2014 Ford Edge with the 3.5. My check charging system light comes on about 30 seconds after I start the car. It stays on the entire time the car is running. I have a brand new AGM battery, a new aftermarket alternator ( puts out between 14-14.2 volts) and a new ring voltage sensor on the negative side of the battery. When I got the car used it had an aftermarket Alpine stereo which I replaced with a stock unit and I also have an aftermarket remote start. I'm at a loss as to my next step other than taking it in to have it scanned. Any thoughts ?
I'd first suspect the compatibility with the ring voltage sensor and the new AGM battery.
I Googled and the AI found if they the combo isn't compatible, or if the ring voltage sensor is defective, it can set a gen light.
If you have an old lead acid battery, I'd try substitute the AGM with it and see if you still get the light.
I switched my 2017 Sport to AGM and used Forscan to configure it for the new battery type and size and also reset the battery life monitor - mine is working faultlessly.
Not sure if it's the same for a 2014 but expect it is.
Jerru stop in at a place like AutoZone and they can test the battery and charging system free of charge.
Also scan for codes.
