Carnye Posted July 27, 2021 Report Share Posted July 27, 2021 I've got. 2013 Ford Edge 2.0 Ecoboost Limited. Month ago oil pressure light/P2196 would come on. Car would die. I replaced purge valve, oil pressure switch, didn't help. Firestone said it was battery, new battery. 4 weeks later, same thing happening. I can't find any videos of the 2.0 bc the purge valve on this car is under driver seat. Firestone can't duplicate the issue. I saw TSB 13-12-12 online that sounds like my issue. When it happens the CEL comes on, then after a day or 2 of it not happening the CEL turns off. When in park, it starts and runs fine. If I fill up with gas, it won't start for 2 to 3 cranks, then every couple of days I'll be at a red-light, the rpms will start to drop, it idles extremely rough and if I don't Rev it back up, the car will die and I'll be stuck in traffic. They are going to keep my car overnight and try to duplicate it again tomorrow, but please tell me someone here with the 2.0 Ecoboost 2013 Ford Edge 70k+miles has experienced this and knows what the fix is. Noone can figure it out. Thank you for your time and any help is appreciated. I'm desperate. 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted July 28, 2021 Report Share Posted July 28, 2021 what's the code? if there is a lit cel there is a code. Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 28, 2021 Report Share Posted July 28, 2021 What's the mileage? What's the service history, oil change interval, what oil and what oil filter? Quote Link to comment Share on other sites More sharing options...
Carnye Posted July 28, 2021 Author Report Share Posted July 28, 2021 (edited) Mileage is around 72k. Oil is usually 5w30, serviced regularly. Never had any issues other than the door ajar light, rear driver side. Wife doesn't know what brand they put in it when it's changed. It's changed every 3 to 4k miles. I can't read the code bc I don't have a port. Mechanic can't get it to replicate to pull a code. They've had it for 2 days. Last code I was able to get from it before they replaced the battery was the o2 bank sensor code, p2196 I think? But that hasn't popped up since battery was replaced. Just called the dealership. They can't even look at it until August 25th. That was the earliest appointment they had. Edited July 28, 2021 by Carnye 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 28, 2021 Report Share Posted July 28, 2021 I would get the codes read at Autozone and find an independent service shop that has a good reputation and reviews. Open the oil filler cap and look for any sign of sludge. 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted July 28, 2021 Report Share Posted July 28, 2021 1 hour ago, Carnye said: Mileage is around 72k. Oil is usually 5w30, serviced regularly. Never had any issues other than the door ajar light, rear driver side. Wife doesn't know what brand they put in it when it's changed. It's changed every 3 to 4k miles. I can't read the code bc I don't have a port. Mechanic can't get it to replicate to pull a code. They've had it for 2 days. Last code I was able to get from it before they replaced the battery was the o2 bank sensor code, p2196 I think? But that hasn't popped up since battery was replaced. Just called the dealership. They can't even look at it until August 25th. That was the earliest appointment they had. Find another shop, if the cel came on there will be a stored code even if it went off. 2 Quote Link to comment Share on other sites More sharing options...
Carnye Posted July 29, 2021 Author Report Share Posted July 29, 2021 I drove my wife's car today. When I put gas in the car, soon as I insert gas nozzle, I hear a hissing sound like it's relieving pressure. All the videos online show a purge valve under the hood. The 2 0 Ecoboost doesn't have that part. Think it's a fuel pressure sensor? Or do I need that spider leg looking assembly on the engine that includes the fuel purge valve? Bc I replaced what i thought was the purge valve under the driver seat. I just don't know why there is absolutely no info on the 2 0 Edge, only the V6 with purge valve under the hood. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 29, 2021 Report Share Posted July 29, 2021 have you checked codes? may need a new filler neck if the valves in it are bad. the canister vent valve is under the cabin, the purge valve is under the hood. i believe someone mentioned on this forum you can use a fusion 2.0 purge valve instead, but you do have to get the connectors off the old purge valve first. 2 Quote Link to comment Share on other sites More sharing options...
Carnye Posted July 30, 2021 Author Report Share Posted July 30, 2021 I can't find the part. Autozone, advanced, etc. I see the solenoid under the hood but I'm not understanding how its connected. The part # says it's for an F150. 9F945. When I removed 2 of the connectors that snap on/off. One of them spilled gas from the hose. I have a GMC Acadia that did this and the part looks similar. Why is this info so impossible to find? Looks nothing like the valve in all the youtube videos from this year model. I'm sure that hose isn't supposed to leak gas tho. I'll attach pictures. If I buy a new one, the hose that says flammable, is it reusable or do I need that part as well? In the photo the hose with the white plastic on the end is the hose that leaked gas. . Quote Link to comment Share on other sites More sharing options...
Carnye Posted July 30, 2021 Author Report Share Posted July 30, 2021 I ordered part bb5z-9g271-b, will be here next week. It kind of looked like gas vapors had accumulated under the engine cover bc the top of it looked wet in some spots. Was hard to tell what it was bc the purge valve made everything smell like gas. Fingers crossed this fixes my issue. 1 Quote Link to comment Share on other sites More sharing options...
Justin Israelson Posted April 10, 2023 Report Share Posted April 10, 2023 Hello Did this fix your issue? Thank you Quote Link to comment Share on other sites More sharing options...
inkslinginmofo77 Posted August 5, 2023 Report Share Posted August 5, 2023 (edited) On 7/27/2021 at 4:23 PM, Carnye said: I've got. 2013 Ford Edge 2.0 Ecoboost Limited. Month ago oil pressure light/P2196 would come on. Car would die. I replaced purge valve, oil pressure switch, didn't help. Firestone said it was battery, new battery. 4 weeks later, same thing happening. I can't find any videos of the 2.0 bc the purge valve on this car is under driver seat. Firestone can't duplicate the issue. I saw TSB 13-12-12 online that sounds like my issue. When it happens the CEL comes on, then after a day or 2 of it not happening the CEL turns off. When in park, it starts and runs fine. If I fill up with gas, it won't start for 2 to 3 cranks, then every couple of days I'll be at a red-light, the rpms will start to drop, it idles extremely rough and if I don't Rev it back up, the car will die and I'll be stuck in traffic. They are going to keep my car overnight and try to duplicate it again tomorrow, but please tell me someone here with the 2.0 Ecoboost 2013 Ford Edge 70k+miles has experienced this and knows what the fix is. Noone can figure it out. Thank you for your time and any help is appreciated. I'm desperate. I had this issue. Hard to start after gas fill ups at times. Rpm’s jump erratically at times, stalls, loss of power etc. Went through 6 different purge valves. Most shops use aftermarket brands so I took a shot in the dark and went to a ford dealer and bought a ford OEM purge valve to make sure it was factory and I haven’t had a problem since. Make sure yer using a FACTORY oem purge valve. Something to do with latency and PWM signal. But since using motorcraft OEM ford purge valve it has completely went away. Not venting tank vapors efficiently back into engine can flood or starve it depending on how well it works with the engines ecm. So OEM. Make sure it’s whats in there! hope it helps. Edited August 5, 2023 by inkslinginmofo77 1 Quote Link to comment Share on other sites More sharing options...
KPTCarn Posted December 25, 2025 Report Share Posted December 25, 2025 Never did get this fixed. Still trying different mechanics. The car will drive fine then the CEL comes on, then goes off, then when it comes back ona 2nd time during the same drive thats when the problem starts. The engine will slowly die if i dont give it gas. Canister/Vent, purge valve assembly, oil pressure switch, etc have all been replaced multiple times. Havent met one person that could figure this out. Purge valve assembly was an OEM Ford part, didnt fix it. After years of trying, i think its time to junk it and at least get $500 for it. Cant believe nobody could ever diagnose the problem. Quote Link to comment Share on other sites More sharing options...
1004ron Posted December 25, 2025 Report Share Posted December 25, 2025 @KPTCarn Welcome. You will be better off finding a reputable qualified mechanic. What fault codes were stored? Please add you Model and Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
KPTCarn Posted January 2 Report Share Posted January 2 Know any reputable mechanics in the southeast? I've had this vehicle at a Ford Dealership for months and roughly 5 different mechanics at 5 different shops. None of them can figure it out, they all dial in on the purge valve, replace it and the next day it still happens. I'll ask for the exact codes on the most recent scan but it appears I have the 1 Ford Edge that no mechanic on this earth can diagnose properly. I love the models but after this I don't think I'll ever buy another one. When the dealership kept it for 6 months and still couldn't find the issue, that was enough to scare me away from another Ford. Just figured id give it one last go before I have it crushed. 1 Quote Link to comment Share on other sites More sharing options...
Oldandintheway Posted January 3 Report Share Posted January 3 This is a shot in the dark, but if you bought this used, is there any chance there is a catch can installed somewhere? It could be overfilled, then burns off a bit and then gets filled again Again, a shot in the dark, but you never know. Quote Link to comment Share on other sites More sharing options...
STBEAST Posted January 3 Report Share Posted January 3 Interesting that when you replaced the battery in 2021 the problem went away for 4 weeks. Seems like that might offer some insight on the issue. What is sadder is that a factory authorized Ford dealership cannot figure out what is going on. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 26 Report Share Posted May 26 (edited) As you've changed the EVAP Valve, another thing that can cause the engine stalling at idle (unless you press the gas pedal) is the low-pressure fuel pump or sensor. If the sensor reads fuel pressure incorrectly or the fuel pump in the gas tank is getting weak and can't deliver enough fuel to the high-pressure pump on the engine idle, the engine starts to die. Giving it gas forces the system to command more fuel pressure, keeping it alive temporarily. Should throw a P0087 or P0191. An outside chance could be related to a dirty throttle body. The throttle body internal motor gets dirty and fails to maintain the correct idle gap for airflow when your foot is off the pedal, choking out the engine. Look for a P2111 or P2112 codes. . Edited May 26 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Jim thurber Posted yesterday at 01:34 PM Report Share Posted yesterday at 01:34 PM I have a 2016 2.0 cohost with similar codes purge valve was bad, but I took the cheap root and spliced in a new valve with existing assembly because hoses located in awkward places. Code went away for a while, but just stays on after clearing. same problem with rough start after filling gas tank, i heard the cheap amazon products might fail quickly. Run evap diag with with my scanner. No issue found. might test evap purge valve again. dont want to just change parts. could be a small split in a hose Quote Link to comment Share on other sites More sharing options...
1004ron Posted yesterday at 02:46 PM Report Share Posted yesterday at 02:46 PM @Jim thurber it's widely reported that most, if not all, 3rd party evap valves do not last as long as the OEM. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 4 hours ago Report Share Posted 4 hours ago Thats pretty much true of all parts. Get OEM whenever possible. Buy once, cry once. Quote Link to comment Share on other sites More sharing options...
