igna
Engine number/code and VIN location?
Hello, I have a 2019 Ford Edge SEL Ecoboost. Where can I find the engine number/code? I have the VIN, but can't find the engine's code. Thanks in advance!
Share this post
Link to post
It’s a 2.0L ecoboost gtdi engine if that’s what you’re asking.
Share this post
Link to post
Hi akirby, what I need is the engine code, it should a combination of numbers or letters, I'm not sure. I don´t know where can I find it. Thanks!
Share this post
Link to post
The only code I know of is the code from the VIN position 8 which in this case should be “9”.
What is it used for?
Edited by akirby
Share this post
Link to post
Hi, I need to register my car in Spain, my country. In order to do it they ask me for a lot of tech data. One of the things they ask is the engine code. I'm not sure if US cars have a code printed on their engines. I'm confused. I've been talking with Ford US and they are going to mail me a tech sheet with a lot of information, but they guy didn't know about that "engine code", maybe the US cars don't have a code or serial for the engine? I'm confused.
I looked online for it and says:
Where is the engine number located?
The engine number is found on the body of the car's engine. Car manufacturers ensure that the number is clearly visible. It is imprinted on a metal sticker and placed in such a way that it is easy to see when you open the hood.
Do Ford cars have a number like this?
Thanks again!
Share this post
Link to post
I'm not familiar with your model, but the engine number is typically stamped on the engine block near the top just below the cylinder head - use a flashlight and search for yours.
The registration office needs it to confirm that the engine is original.
Share this post
Link to post
Thanks, I will try to find it there.
Share this post
Link to post
Thank you!
Share this post
Link to post
@igna
Engine Identification
For quick identification, refer to the safety certification decal.
  • The decal is located on the LH front door lock face panel.
Engine Code Information Label
The engine code information label, located on the front side of the valve cover, contains the following:
Item Description
1 Engine part number
2 Engine plant (Cleveland)
3 Engine displacement
4 Engine configuration
5 Twin independent Variable Camshaft Timing (VCT)
6 Bar code
7 Bar code
8 Running number
9 Engine build date (DDMMYY)
10 Plant shift line
11 Derivative code
Share this post
Link to post
On 10/25/2021 at 8:38 PM, igna said:
"Hi, I need to register my car in Spain, my country."
Have you shipped your Edge from North America to Spain? That's interesting. I guess it wasn't too expensive then?
The model you have, the SEL and it's engine are not available on any of the European Edges over here- they are all diesels.
It'll be interesting to see how you get on and whether you have any problems getting spares and having the car serviced.
Share this post
Link to post
2 hours ago, WWWPerfA_ZN0W said:
@igna
Some countries check the engine number stamped on the block to verify that its the original, not a replacement, and not listed as stolen - I'm guessing this what the igna needs is for.
Share this post
Link to post
Thanks so much!
Share this post
Link to post
38 minutes ago, igna said:
Thanks so much!
You're welcome, but please do tell us if you've resolved the issue, and what it actually was that you needed.
Share this post
Link to post
21 hours ago, WWWPerfA_ZN0W said:
@igna
Item Description
6 Bar code
7 Bar code
8 Running number
10 Plant shift line
11 Derivative code
Thanks!
Share this post
Link to post
I finally got the engine number from the dealer. Thanks everybody for your help!
Share this post
Link to post
The shipment cost was around $1,000. The issue is the burocracy in Spain, a lot of paperwork, several fees... But it is worth since the car was almost new.
Share this post
Link to post
Correct, that's what they were asking about, an engine number stamped somewhere in the engine. Thanks!
Share this post
Link to post
Cool. That's not that much really considering the overall cost of the car. And you get quite a unique vehicle - big powerful engine and in left hand drive too!
Are there any mods you need to make to make it legal for Spanish roads....like fitting rear fog lamps?
Share this post
Link to post
Yes, that's the only modification, the rear fogl lamp. In Spain is enough with only one.
Share this post
Link to post
How did you install it and wire it?
Share this post
Link to post
So where can it be found on this engine?
Share this post
Link to post
They couldn't find any other way than this, not a nice solution, but enough to pass the inspection. I can remove it later.1635999788_IMG_0271copy.jpg.6926a079ee590514428e39b9d2cd71d5.jpg
Share this post
Link to post
I couldn't find it, the dealer gave me that number
Share this post
Link to post
Hello, first of all I would like to know if US regulations requires to stamp the VIN number on the chassis/frame/body. If so, does anyone know where can I find it in the Ford Edge 2010?
Thanks!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
