garycrist Posted February 28, 2025 Report Share Posted February 28, 2025 What I could hear, it sounds like a heat shield buzzing. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 28, 2025 Report Share Posted February 28, 2025 Honestly, not much to go on, but to me it sounds like some type of vacuum valve opening (or closing) and vibrating when moving. There are vacuum valves inside the cabin. Does it sound like the sound is emulating from inside or outside the cabin? About the only way I can think of isolating the sound would be to place a microphone around various places in the engine compartment and narrowing down when its loudest. Quote Link to comment Share on other sites More sharing options...
ZcO123 Posted April 5, 2025 Author Report Share Posted April 5, 2025 Back again after a different dealership having my Edge for just about a month. I THINK we have figured out the problem. I will paste the (quite long) write-up from the master mechanic - as it would be more helpful than anything I would try to explain. Hopefully it helps at least ONE person that may be experiencing a similar problem. 2020 Ford Edge ST with 17k miles on it, 100 visits to dealerships, ridiculous amounts of time without the car, $1000's wasted, "fixes" that ended up not being fixes, etc. The master mechanic found it to be the driveshaft installed improperly from the factory. Please read the write-up for more details. I appreciate all the messages with guesses at what this could be. After getting a new transmission and it essentially being a placebo-fix where we weren't hearing the noise for a short period, here is to hoping that this new, properly installed driveshaft resolves this FIVE YEAR problem we've been experiencing. Thanks again! 1 3 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 5, 2025 Report Share Posted April 5, 2025 I find it somewhat puzzling - the front bearing support bracket was mentioned as problematic - correcting the bracket with the old drive shaft still had the noise. A new driveshaft resulted in no more noise - so was it a problem driveshaft all along? 2 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted April 5, 2025 Report Share Posted April 5, 2025 The one positive thing I get out of what you pasted is you were so lucky to find a Ford Tech that was willing to give it all he could to try a figure this out and fix it for you. Looks like he went the extra mile and gave it 100% to try and fix this issue. That in itself is a rare thing to find these days. What a nightmare to go through for you. The most interesting thing is that it only happened in sport mode. I had a 2021 Edge ST that was a nightmare from day one: I won't go into too much detail but- at about 1100 miles while out in the middle of nowhere a cooling hose came off (at the ptu cooler) causing overheat and leaving me stranded. Only to find from the dealer that there were three clamps not properly installed on the hoses from the factory. The car was never the same after that. It drove normal but the transmission developed a Slam sound randomly on acceleration from a stop. Multiple visits to the dealership and a lot of wasted time they changed some components of the transmission. The Slamming was gone but the shifting was always unpredictable and in sport mode a funny humming sound came from somewhere in the engine compartment area. In reverse there was a slight delay in response under acceleration. They drove the vehicle multiple times and said it was normal. BS. After two years and at 12000 miles (Jan 2023) I ended up trading it in for an identical 2024 St. After all the hell I had been through it wasn't a very smart decision on my part. Even though I had the extended warranty I never felt comfortable with the vehicle after an overheat. If I had been smart, I would have taken legal action and forced Ford to take the vehicle back under the California lemon law. The only reason I stuck with Ford is because I loved the Edge ST and knew it was the last year they were being made. I got the 8-year extended warranty hoping I never have to use it. I am at 6550 miles and only after driving both vehicles I notice there is a big difference in the transmission between my old 2021 and the 2024. 1 1 Quote Link to comment Share on other sites More sharing options...
ZcO123 Posted April 5, 2025 Author Report Share Posted April 5, 2025 44 minutes ago, STBEAST said: The one positive thing I get out of what you pasted is you were so lucky to find a Ford Tech that was willing to give it all he could to try a figure this out and fix it for you. Looks like he went the extra mile and gave it 100% to try and fix this issue. That in itself is a rare thing to find these days. What a nightmare to go through for you. The most interesting thing is that it only happened in sport mode. We were beyond lucky to have this master mechanic work on this problem for us over the last month. He said it was the hardest thing he has ever had to figure out and resolve in his career. Also, we don't really ever put the car in sport-mode, but the noise was still present. Putting the car in sport-mode seemed to be a "cheat" to allow the mechanics to hear the noise better (and at all) as the noise didn't occur 100% of the time when hitting 2100 RPM. So it is false that it ONLY happened in sport-mode. The mechanic just forced the issue as it seemed to occur more often in sport-mode during his tests and stuck with that mode throughout the testing. 2 1 Quote Link to comment Share on other sites More sharing options...
ZcO123 Posted April 5, 2025 Author Report Share Posted April 5, 2025 1 hour ago, 1004ron said: I find it somewhat puzzling - the front bearing support bracket was mentioned as problematic - correcting the bracket with the old drive shaft still had the noise. A new driveshaft resulted in no more noise - so was it a problem driveshaft all along? I might get this wrong with what was explained, but we were told that the incorrect install from factory with the bracket and the driveshaft caused for the driveshaft to contort a little bit due to misaligning the bolts. The bolts were able to fit perfectly into place with the bracket on the new driveshaft. I apologize for my ignorance as this is like a different language for me. 3 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted July 1 Report Share Posted July 1 On 3/24/2022 at 12:43 PM, ZcO123 said: 2020 Ford Edge ST with around 8k miles on it. Developed a bee-buzzing noise at around 5k miles that occurs around 2k RPM under acceleration. Lasts for about a second, but you can hold the noise if you keep steady at the RPM the noise occurs prior to gear shifts. Dealerships can’t figure it out and won’t do anything. Have had the car in several times with nothing being done/replaced to resolve the issue. Any ideas, friends? Short video clip of the noise: https://streamable.com/gw7dhv My 40,000 mile 2022 ST-Line just started making this exact same noise. Kinda sounds like a bee buzzing when it shifts from 1-2 and 2-3. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted July 1 Report Share Posted July 1 Where exactly do you think the noise is coming from? Transmission, Rear Diff, Engine? So many possibilities Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 1 Report Share Posted July 1 (edited) On Auto Surgeon, they wrote that on a 2020 Ford Edge ST, with a 2.7L engine, this exact problem specifically occurs around 2,000 RPM under acceleration. They wrote that this is a well-documented symptom. It is typically caused by exhaust system resonance or a loose factory heat shield. "The 2.7L EcoBoost engine and its specific exhaust configuration are highly prone to vibrating at this precise RPM frequency, transferring vibrations into components underneath the vehicle or near the firewall." . Edited July 1 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted July 2 Report Share Posted July 2 I have never encountered this buzzing but it's sounding like the issue is an exhaust drone Quote Link to comment Share on other sites More sharing options...
RedRod27 Posted July 15 Report Share Posted July 15 (edited) I’m new here but I think you’re on the right track with the Auto Surgeon post. I bought my 2020 Ford Edge ST a couple years ago and it was great until last year when it started buzzing and rattling on mild acceleration at about 2000 rpm. My local Ford dealer was expert at finding root cause - a baffle plate inside the OEM exhaust resonator which is part of the unitary dual exhaust SYS on the ST. Dealer replaced my entire exhaust after of the cat, even though the massive ten-foot exhaust is $1200. (!) …this was done under warranty so whew what a relief. It did take a couple months to come in at the dealer due to back orders. But it solved the problem entirely! Edited July 15 by 1004ron Quote Link to comment Share on other sites More sharing options...
31bullitt16 Posted 15 hours ago Report Share Posted 15 hours ago Is there a production date range this issue effects or is it random? Any TSB’s? Quote Link to comment Share on other sites More sharing options...
STBEAST Posted 14 hours ago Report Share Posted 14 hours ago (edited) It is the exhaust resonator. Same thing happened to me on my 2021 ST about 11K. Warranty knows this is an issue. I doubt there are any TSBs as Ford probably wishes this is another nightmare they don't need. Edited 14 hours ago by STBEAST 1 Quote Link to comment Share on other sites More sharing options...
