Replaced Fuel Pump, 2019 still staggers when accelerating
Hello all,
I replaced the fuel pump this morning on my 2019 Edge SEL, with the 2.0, it is running better but still staggers and jerks when accelerating. It’s not throwing any codes, no engine light or anything. I replaced the coil packs at 70,000, plugs, MAS and air filters 3 months ago. It has 103,000 miles on it.
any suggestions for what I can look at to correct this issue?
all advice and help is appreciated.
6 hours ago, mrjhansc said:
Hello all,
What are you using to scan for codes?
3 hours ago, WWWPerfA_ZN0W said:
was the transmission programming updated? have you serviced the fluid?
The last time the transmission was serviced was at 62,000 miles, about 3 years ago, the torque converter went out and Ford wasn't too pleased that it had to cover the rebuild on the extended warranty. If there were an issue with the programming wouldn't that throw a code of some sort?
Most recently I used an ANCEL AD310 OBDII/EOBD+CAN scanner. I ran through it several cycles, no codes in the queue and nothing pulls up under new codes. Not even a check engine light or the dreaded wrench light.
I recommend that you use Forscan - yes, I've had other reputable scanners show no codes only to find that there was stored codes using Forscan.
The symptoms you describe there's bound to be codes stored.
  • Thanks 1
I will take a look with one of those, thank you.
I think it only does OBD-II codes, and not PCM or other modules. I used one like it, Torque on my cell phone, but not until I used Forscan on a laptop did I get the maturing/pending codes or eventually the ones that set the powertrain fault.
Mine went from slightly jerky (like the TSB...under 35 mph, I was setting up an appointment to get it programmed, if it met the criteria, on my own dime) to a whole slew of various solenoid and friction codes, some are E which is used for 5-8th, some are the frctions used for other gears, and that is how it was behaving, freewheeling above 4th gear unless I slowed down.
The p0771 from OBD-II was the only one I ever saw on just a code reader (it was 110 degrees outside and I was dying so I just took camera shots of the screen):
  • Thanks 1
10 hours ago, garycrist said:
Why did you replace the plugs to begin with? Did it jerk/stagger before the plugs were replaced?
Try lowering the gap down to .28  It might be you are "blowing out" the spark with a wide gap.
What was the gap on the old plugs?
Yes, it was staggering prior to replacing the plugs. I honestly don’t remember what the gap was on the old ones. I hadn’t thought about that. At this point I’m willing to try anything.
A good starting point in the diagnostics is knowing the stored fault codes - the misfiring/staggering potential causes go beyond bad spark plugs.
Waiting on the delivery of the FORscan cables to run the diagnostic this weekend. Like I said, it hasn't thrown any codes previously, no engine light or anything.
Thank you for this. I'll have the cables by this weekend, already downloaded the software. I am hoping that the learning curve isn't too steep when dealing with it.
  • 4 months later...
We purchased a 2020 Edge (49,000 miles) and we have the staggering/jerking at take off and also when the speed is around 40 mph. We took it to Ford and they said it was the torque converter. They ended up replacing the transmission and torque converter. That did not fix the problem.
  • 5 weeks later...
  • 8 months later...
