lasseventies Posted February 16, 2025 Report Share Posted February 16, 2025 (edited) Hi folks! I have a 2024 Edge with shy of 6k miles on it and I have being dealing with a rattling noise coming from the rear right cargo side panel. It starts at any highway after 50MPH. I tried (while some else driving) to press firmly and find something loose on the panel but no luck. Anyone with a similar rattle issue? Here is a link of the noise: https://drive.google.com/file/d/1HaITQXoBgTHu7FPjOpRTE688jWJ7naMY/view?usp=drivesdk Thank you very much in advance! Edited February 16, 2025 by 1004ron 1 1 Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted February 16, 2025 Report Share Posted February 16, 2025 Not sure how to solve your particular issue, but one time I had a squeak in a door panel and I sprayed silicon in the area and it took care of it. I've only done it once and it worked once, so worth a thought. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
lasseventies Posted February 18, 2025 Author Report Share Posted February 18, 2025 On 2/16/2025 at 12:13 PM, Tim W. AZ said: Not sure how to solve your particular issue, but one time I had a squeak in a door panel and I sprayed silicon in the area and it took care of it. I've only done it once and it worked once, so worth a thought. Good luck. i guess I can spray some WD40 inside the air vent towards the seatbelt screws and see what happens Quote Link to comment Share on other sites More sharing options...
Haz Posted February 18, 2025 Report Share Posted February 18, 2025 Welcome to the Forum @lasseventies! As your highlighted illustration and your comment indicates, the rear seatbelt retractor lies beneath the trim panel, and it contains a pyrotechnic (mildly explosive) device to pretension the belt in event of a crash. Because your Edge is under warranty and within its Low Time In Service (LTIS) period, during which repairs are extensively documented and reported back to Ford, you really should contact your dealer to have a professional technician diagnose and correct the noise's root cause, which may be directly related to the seatbelt retractor assembly. Good luck! 2 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted February 18, 2025 Report Share Posted February 18, 2025 (edited) Wow! I listened to your recording and I too have the same thing happening. VERY similar sound! Interesting! I have a 2024 Edge ST with 6400 miles. At speeds above 60 MPH I hear a rattle/squeaking sound coming from the vent area highlighted. I sat back there while my girlfriend drove and it is behind that vent. WOW, same exact area. It seems to be speed related, not bumps in the road. Below 60 it seems to go away no matter how rough the road is. Almost like it is wind related. I was going to pop the vent out and see what I could find. Unless there is a TST or Service Bulletin, the dealers are pretty much worthless with this kind of thing. I also have a rattle in the right rear corner of the hatch back trim panel (right where the handle is that you would grab to close the rear door). It is present when you hit the slightest bump and is more noticeable once the car and interior are warm. I tried pushing on the panel while driving but it is inside the rear hatch door????? Edited February 18, 2025 by STBEAST Quote Link to comment Share on other sites More sharing options...
lasseventies Posted February 18, 2025 Author Report Share Posted February 18, 2025 9 hours ago, Haz said: Welcome to the Forum @lasseventies! As your highlighted illustration and your comment indicates, the rear seatbelt retractor lies beneath the trim panel, and it contains a pyrotechnic (mildly explosive) device to pretension the belt in event of a crash. Because your Edge is under warranty and within its Low Time In Service (LTIS) period, during which repairs are extensively documented and reported back to Ford, you really should contact your dealer to have a professional technician diagnose and correct the noise's root cause, which may be directly related to the seatbelt retractor assembly. Good luck! Yeah… you are right. I did make an appointment to take it to the dealership, but I am not quite sure if they’re gonna be helpful at all. 1 Quote Link to comment Share on other sites More sharing options...
lasseventies Posted February 19, 2025 Author Report Share Posted February 19, 2025 3 hours ago, STBEAST said: Wow! I listened to your recording and I too have the same thing happening. VERY similar sound! Interesting! I have a 2024 Edge ST with 6400 miles. At speeds above 60 MPH I hear a rattle/squeaking sound coming from the vent area highlighted. I sat back there while my girlfriend drove and it is behind that vent. WOW, same exact area. It seems to be speed related, not bumps in the road. Below 60 it seems to go away no matter how rough the road is. Almost like it is wind related. I was going to pop the vent out and see what I could find. Unless there is a TST or Service Bulletin, the dealers are pretty much worthless with this kind of thing. I also have a rattle in the right rear corner of the hatch back trim panel (right where the handle is that you would grab to close the rear door). It is present when you hit the slightest bump and is more noticeable once the car and interior are warm. I tried pushing on the panel while driving but it is inside the rear hatch door????? Wow! Well.. I am glad that I’m not the only one here with the same noise. You’re right, below 50 or 60 mph It does go away… I do have an appointment in a couple weeks at the dealership to see what they have to say. Before reading your post my guess was that maybe one of the screws of the seatbelt assembly is making the rattle but it does make more sense to believe is air related 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted February 19, 2025 Report Share Posted February 19, 2025 I seem to think the noise could be coming from anywhere in that area, we are just hearing it through the vent. I also seem to remember that noise wasn't there a couple thousand miles ago. When I first noticed it, I would be above 70-75 mph, but over time it seems to have gotten noticeable at lower speeds. I can almost say without a doubt that you and I are having the same issue. I will keep you posted if I get any information as well. Please keep me posted, I am going try and tackle the rattle in my cargo door panel. It has become constant and very irritating, Jim Quote Link to comment Share on other sites More sharing options...
lasseventies Posted February 19, 2025 Author Report Share Posted February 19, 2025 2 hours ago, STBEAST said: I seem to think the noise could be coming from anywhere in that area, we are just hearing it through the vent. I also seem to remember that noise wasn't there a couple thousand miles ago. When I first noticed it, I would be above 70-75 mph, but over time it seems to have gotten noticeable at lower speeds. I can almost say without a doubt that you and I are having the same issue. I will keep you posted if I get any information as well. Please keep me posted, I am going try and tackle the rattle in my cargo door panel. It has become constant and very irritating, Jim Absolutely, I will keep you posted on what they tell me at the dealership and let me know if you find something on yours. an interesting fact is that I I’m currently out of town for work renting at 2024 Ford escape and it has a very similar noise coming from the driver seatbelt pillar… 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted February 19, 2025 Report Share Posted February 19, 2025 There is a slight chance that the rear license plate is loose. I had a rattler that only happened at higher speeds. I did not figure it out until the plate almost fell off. The Ford capture nuts are not very good. It is easy to over tighten and break them. 1 1 Quote Link to comment Share on other sites More sharing options...
lasseventies Posted February 21, 2025 Author Report Share Posted February 21, 2025 On 2/19/2025 at 2:52 PM, STBEAST said: I seem to think the noise could be coming from anywhere in that area, we are just hearing it through the vent. I also seem to remember that noise wasn't there a couple thousand miles ago. When I first noticed it, I would be above 70-75 mph, but over time it seems to have gotten noticeable at lower speeds. I can almost say without a doubt that you and I are having the same issue. I will keep you posted if I get any information as well. Please keep me posted, I am going try and tackle the rattle in my cargo door panel. It has become constant and very irritating, Jim I found this reddit post, can you check it out and watch the video and see if it is the same noise? Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 21, 2025 Report Share Posted February 21, 2025 (edited) On earlier Gen 2 models there was a TSB for a rattling sound coming from underneath the vehicle. Maybe worth checking out. Edited February 21, 2025 by omar302 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted February 22, 2025 Report Share Posted February 22, 2025 Hard to tell if it's the same as the Reddit post. But very similar for sure. The sound you recorded, and the location of the noise are the same though. Something behind that vent for sure. Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted February 24, 2025 Report Share Posted February 24, 2025 On 2/17/2025 at 7:44 PM, lasseventies said: i guess I can spray some WD40 inside the air vent towards the seatbelt screws and see what happens WD-40 is a petroleum based lubricant and over time degrades rubber and plastic. Silicon spray is just as effective and you can revitalize rubber door seals with it. Now days, I only use WD on metal to metal lube. 2 Quote Link to comment Share on other sites More sharing options...
gonesail Posted February 25, 2025 Report Share Posted February 25, 2025 (edited) just an FYI. i had a rattle in what i thought was the cargo area. drove me crazy. finally found out that the bottom of the tag was not screwed tight and was vibrating on the hatch. the bottom 2 screws were missing. i see this is a duplicate post. Edited February 25, 2025 by gonesail 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted March 18, 2025 Report Share Posted March 18, 2025 Well an update- I verified the noise we are hearing is coming from that side of the vehicle where the rear cargo vent is. I verified that it is 100% speed related and most likely wind too. I don't think it is related to the seatbelt, but possible the fuel fill/door/compartment. It doesn't seem to be there when everything is cold. I also seems to be getting worse- as in happening at lower speeds. I am tempted to pull that drivers side rear cargo area trim panel off and have my wife drive while I sit back there again. I am not sure exactly how that trim panel comes? Looks pretty basic. As for my other little rattle- seems to be coming from the cargo hatch, down by the automatic locking mechanism. I will have to do more research. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 19, 2025 Report Share Posted March 19, 2025 @STBEAST: From the 2022-2024 Edge Workshop Manual... Good luck! Loadspace Trim Panel - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted March 20, 2025 Report Share Posted March 20, 2025 A very big thank you, Haz. Not the first time you have helped me out. Very much appreciated!! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 20, 2025 Report Share Posted March 20, 2025 Kind of sounds like those pesky flapper vanes used in the air outlets flapping when the pressure (speed) gets high enough. Quote Link to comment Share on other sites More sharing options...
STBEAST Posted April 15, 2025 Report Share Posted April 15, 2025 Found it! Tighten the bolts holding the fabric material to the fender well and it is gone! I sent you a personal message and here are the pictures. Jiggle the area where my hand is and you should hear the sound. tighten the bolts about a half turn. 2 2 Quote Link to comment Share on other sites More sharing options...
GTEyes Posted April 15, 2025 Report Share Posted April 15, 2025 The fact that you found out what the noise is awesome. Way to go. Not every day we figure stuff like this out!! 1 2 Quote Link to comment Share on other sites More sharing options...
lasseventies Posted April 19, 2025 Author Report Share Posted April 19, 2025 On 4/14/2025 at 11:22 PM, STBEAST said: Found it! Tighten the bolts holding the fabric material to the fender well and it is gone! I sent you a personal message and here are the pictures. Jiggle the area where my hand is and you should hear the sound. tighten the bolts about a half turn. I confirm that this fixes the noise. Worked on mine as well!! Thank you so much!! 3 Quote Link to comment Share on other sites More sharing options...
Cardi Posted October 21, 2025 Report Share Posted October 21, 2025 I have the same noise on my 2020. I will try those fixes and report back. Thanks 2 Quote Link to comment Share on other sites More sharing options...
Cardi Posted October 24, 2025 Report Share Posted October 24, 2025 Problem solved. Someone mention checking the nuts that tighten the license plate in the back. They were tight but left space for the lower part of the plate to move freely. I replaced the nuts for others bought at an auto part store. It was actually the license plate's lower part flying freely with speed and making the noise. Nuts replaced, license plate cannot move anymore. The noise is gone. Quote Link to comment Share on other sites More sharing options...
edjunior Posted October 25, 2025 Report Share Posted October 25, 2025 2 hours ago, Cardi said: Problem solved. Someone mention checking the nuts that tighten the license plate in the back. They were tight but left space for the lower part of the plate to move freely. I replaced the nuts for others bought at an auto part store. It was actually the license plate's lower part flying freely with speed and making the noise. Nuts replaced, license plate cannot move anymore. The noise is gone. Cool. Thanks for reporting back with a fix. Quote Link to comment Share on other sites More sharing options...
