johnmarkp Posted August 6 Report Share Posted August 6 I have looked at virtually all the tire reviews for the ST. Most are centered on performance and/or mileage. I am looking for tires that give the quietest and most comfortable ride. I have the 20 inch wheels. Quote Link to comment Share on other sites More sharing options...
STBEAST Posted August 7 Report Share Posted August 7 (edited) I too am looking for a good alternative, I have the performance brake and tire package which came with the 21" P Zeros. The ST front suspension stiffness in increased by 10% and the rear suspension in increased by about 20%. They also use a monotube shock instead of a twin tube. And they use a solid tube sway bar instead of a hollow tube. I know the ST wasn't designed to be as comfortable as the base edge, so it is going to ride differently. Edited August 7 by STBEAST Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 7 Report Share Posted August 7 Probably running tires 5 psi lower would make a bigger difference than a tire with a softer sidewall. 1 Quote Link to comment Share on other sites More sharing options...
BlueSteel Posted August 8 Report Share Posted August 8 I got myself a set of the Michelin Pilot Sports for the summertime. I found that they were quieter and more comfortable than the OEMs that were on there. They had a good comfort/noise score on TireRack.com 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted August 8 Author Report Share Posted August 8 They look good, but the 20k mileage is just too low. Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted August 8 Report Share Posted August 8 I would suggest tires classed as touring or luxury. These tires provide a luxurious ride and since the speed rating is lower than sport tires, the tires will last a lot longer. Quote Link to comment Share on other sites More sharing options...
garycrist Posted August 9 Report Share Posted August 9 I do not know where you live, but here just north of Dallas, I bet I could find a set of used 18 inch tires and wheels that will satisfy your ride. It is the low aspect (2nd number) ratio that helps determine stiffness as well as grip for the wider tires. This stiffness is reflected in less sidewall flex, better fuel economy,better handling etc. So a 245/60-18 tire will fill the bill with the 18 inch rims. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 12 Report Share Posted August 12 (edited) My 2020 Edge ST came stock with 245 /50 R20 Hankook Ventus S1 Noble2 tires. Definately not a performance tire. Comfortable ride. Must be why I replaced them with performance summer & winter tires. With only 3000 miles on the Hankooks, I just need to find a local buyer Edited August 12 by Samurai Edge Quote Link to comment Share on other sites More sharing options...
TourGuide Posted August 13 Report Share Posted August 13 Ford must get a deal on the Hankook tires (besides all the other reasons they may pick them), because my original Edge 16 Sport had those on it. I didn't like them - they did not seem to do the job in the winter to my liking. For my climate it is Nokian tires for me. I usually run the WRG5 variety. Quote Link to comment Share on other sites More sharing options...
Davidoo Posted August 13 Report Share Posted August 13 I have a 22 ST that came with the Hankook tires as well. I do believe they are considered a performance tire, but don't provide a good ride at all......and I know the ST won't ride as well as a non-ST. I now have 31,000 miles. The Hankooks have worn fairly well, but I probably have less than 5,000 miles left before I wouldn't want to drive on them anymore. I'm also looking for something, preferably Michelins. I do see many have the all-season Michelins, but I don't really need that kind of tread here in Phoenix as I'll probably never drive mine in the snow. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted August 13 Report Share Posted August 13 Michelins seem a good option for climates like Phoenix where you are worried most about things like performance in the heat, rain, and treadware. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted August 13 Author Report Share Posted August 13 I just ordered 4 Pirelli Scorpion AS PLUS 3 tires from Tirerack. I hope to get them installed soon. I'll report back on how they perform. 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted August 20 Author Report Share Posted August 20 I got the Scorpion AS PLUS 3s installed yesterday. Its too soon to be sure about the tires. My initial impression is good. They are definitely softer then the Goodyear Eagles I had before. Road noise is very low. Expansion joint noise is about the same, not bad but still there. Handling seems to be pretty good. I think I will lose the last bit of handling near the edge of the ST's capabilities. But I don't push it too far in my old age, so no great loss. I'll come back with more when I get some miles on them. 1 Quote Link to comment Share on other sites More sharing options...
boostededge Posted August 29 Report Share Posted August 29 continental dws06 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted September 13 Author Report Share Posted September 13 (edited) After three weeks of driving I really like the Scorpian AS Plus 3. Very little road noise if any most of the time. They handle great. I have not driven them in heavy rain yet. In minor rain they were fine. Hopefully I will not have to test them in snow, here in Wisconsin for a while. I would buy these again. Edited September 13 by johnmarkp Quote Link to comment Share on other sites More sharing options...
