ADC Posted November 15 Report Share Posted November 15 New here and seeking some advice. I have a 2008 Edge AWD its making a very loud noise when driving down the road. Everyone I talked to said wheel bearing noise as it gets quieter when turning (right turns especially), louder with more speed. It's for sure coming from the front end. However I just had the bearings replaced on both sides even though they didn't seem bad. The sound never changed. The tire rod ends were also replaced as they had a little play in them. The noise remains the same. I was thinking maybe CV axels? but there's no popping sounds I am told is associated with it. You can barely hear it at low speeds and the sound gets increasingly louder with speed, to the point you can't hardly hear anything else. I don't want to keep throwing money at it and hoping it'll fix it, but I need to do something. If anyone knows what it is, I sure would like the help. If you have any further questions or advice on this issue, just let me know. Also, in a possibly related question,,, there is a loud clunk when going from drive or park to reverse unless you completely come to a stop and pause for a second or two, then it doesn't do it. This has been going on for quite sometime, maybe a couple years, but the other noise has progressively gotten louder over the last few months. If you could help diagnose the cause of this I'd greatly appreciate it too. (engine mounts seem solid if that matters) Thank you. ~ADC~ Quote Link to comment Share on other sites More sharing options...
ADC Posted November 15 Author Report Share Posted November 15 I am not sure how well you can hear it, but hopefully this will be helpful. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted November 16 Report Share Posted November 16 A sound that changes with speed and steering direction like that in my experience is usually a wheel bearing. One that loud should be pretty easy for a mechanic to find. Those will often lead to ABS sensor errors when they get really bad. Pretty common problem as a vehicle ages if that is what it is. 1 Quote Link to comment Share on other sites More sharing options...
niceonept Posted November 16 Report Share Posted November 16 Have you checked your brake pads? The Edge uses a mechanical wear indicator comprising a metal prong that makes contact with the brake disc when the pads are at their wear limit. It makes a horrible screeching noise. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 16 Report Share Posted November 16 2 hours ago, niceonept said: Have you checked your brake pads? The Edge uses a mechanical wear indicator comprising a metal prong that makes contact with the brake disc when the pads are at their wear limit. It makes a horrible screeching noise. What year and what manufacturer of pads have a squealer? Very few I found for 2016+ (I don't know what years are grouped together) aftermarket have them (Top Notch brand, some Akebono), none on factory installed pads I have seen. None for first gen. 1 Quote Link to comment Share on other sites More sharing options...
ADC Posted November 17 Author Report Share Posted November 17 Now we are think PTU, how do you troubleshoot it to know if it is bad? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 17 Report Share Posted November 17 29 minutes ago, ADC said: Now we are think PTU, how do you troubleshoot it to know if it is bad? I don't think that the PTU can be ruled out - there's some influence on the CV Axle when turning the steering - it's going to take some exploration to clearly identify the noise source. I've got one of those "exploration" problems on my 2017 Sport - vibration when accelerating at speeds around 60mph - changed the control arm, that wasn't it - this weekend I'll be replacing the CV Axle. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Sunday at 08:51 PM Report Share Posted Sunday at 08:51 PM (edited) My PTU made a noise similar to this before they replaced it. Gets louder with speed. (Lack of lubrication.) . Edited Sunday at 08:52 PM by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
ADC Posted 21 hours ago Author Report Share Posted 21 hours ago PTU was not the source of the noise, nor were the wheel bearings. Both were replaced. Where to look next? Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted 8 hours ago Report Share Posted 8 hours ago 12 hours ago, ADC said: PTU was not the source of the noise, nor were the wheel bearings. Both were replaced. Where to look next? I'd rotate the tires. If the noise moves, then you have found your problem. If it stays the same, then there's something else going on. But the rotational noise you're getting could just be bad tires. 1 Quote Link to comment Share on other sites More sharing options...
