RPGR90s Posted August 1 Report Share Posted August 1 I have a question. The other day I wanted to do a coolant flush on my 2019 ST. The car was purchased now and currently has 103k miles. It's been a perfectly flawless vehicle. At the 1st coolant service, I had the Ford dealer flush and re-fill. They swapped out the original orange colored coolant for a green colored coolant. Now I see that the latest Ford coolant is yellow colored, so that's what I purchased. I found the drain (boy what a fun job it is getting access to THAT!!) and drained the old coolant. I then added a coolant flush with distilled water and let the car come up to temperature. I ran this for the specified interval (10 minutes) and drained again. The liquid coming out was mostly clear so I filled the tank with the new, yellow colored coolant and brought the engine back up to temperature. I let the car cool down over-nite and in the morning the tank was a bit low, so I topped it off. But what caught my eye was the coolant reverted back to a solid green color. Did I miss a step in my probess and possibly not get all the old coolant out? Thanks for any advice or direction. RPG 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 1 Report Share Posted August 1 Running the coolant flush for only 10 mins would not have warmed up enough to open the thermostat and you should set the cabin heating to MAX for it to circulate through it. Quote Link to comment Share on other sites More sharing options...
RPGR90s Posted August 1 Author Report Share Posted August 1 3 hours ago, 1004ron said: Running the coolant flush for only 10 mins would not have warmed up enough to open the thermostat and you should set the cabin heating to MAX for it to circulate through it. If I recall, the engine was already at max temperature and I did have the heat set to Max. Thank You! 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 2 Report Share Posted August 2 Just remember you are not completely draining the coolant from the engine with a normal flush. Old coolant will still reside in the engine so this may be the cause of your " green "coolant. 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 2 Report Share Posted August 2 The only way to get only the new coolant in the system is to do a few drain-fills with distilled water and then the final fill with a higher concentration of the new coolant expecting some distilled water to remain in the engine. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 2 Report Share Posted August 2 One could also use a system like the following to flush out the entire system and then fill with concentrated ( non-diluted ie; 50/50 ) anti-freeze https://www.amazon.com/dp/B0002SRH5G/?coliid=IBXVQ52CJGVOB&colid=1VY88PYQ3KPE1&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted August 2 Report Share Posted August 2 Not sure why you recommend pure antifreeze? Pure ethylene glycol freezes at 10f. The normal 50:50 mixture freezes at -35f. Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 2 Report Share Posted August 2 (edited) 1 hour ago, johnmarkp said: Not sure why you recommend pure antifreeze? Pure ethylene glycol freezes at 10f. The normal 50:50 mixture freezes at -35f. Not sure who that comment was directed at? I always buy the concentrate and mix it 50/50 and the product details state clearly not to go higher than 60/40. My comment was to drain/fill a few times with distilled water and that way you would have removed about all of the old coolant mix, then go back with say a 60/40 mix knowing that the engine still contains some straight distilled water. I use a vacuum fill kit similar to this. Edited August 2 by 1004ron Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 2 Report Share Posted August 2 2 hours ago, johnmarkp said: Not sure why you recommend pure antifreeze? Pure ethylene glycol freezes at 10f. The normal 50:50 mixture freezes at -35f. I stated concentrated, ie; non-diluted, because when you flush the system as described, you will be left with water still in your system. By using the concentrate, you will be close to a 50 / 50 mix. BTW, the concentrate is cheaper than the 50/50 mix from the supply store and you are paying for water. As 1004ron said, I also buy the concentrate and dilute on my own 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 3 Report Share Posted August 3 I have done two drain-fills on my 2017 Sport. The fact that the new spec Ford coolant is compatible with the old spec there's no issue with not purging all the old coolant and I didn't purge the system on each occasion - the first time it the fluid in the reservoir didn't look anything like the new color, and with the second drain-fill its closer to the new color. Maybe next time I'll purge it with distilled water before refilling. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 3 Report Share Posted August 3 On 8/1/2026 at 5:40 PM, RPGR90s said: If I recall, the engine was already at max temperature and I did have the heat set to Max. Thank You! Just revisiting this - fairly risky to drain the coolant with it at normal operating temperature and even if that was done, it would be well below operating temperature with the new cold coolant just added and would take longer than 10 minutes to get back up to operating temperature. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted September 18 Report Share Posted September 18 On 8/3/2026 at 7:54 AM, 1004ron said: Just revisiting this - fairly risky to drain the coolant with it at normal operating temperature and even if that was done, it would be well below operating temperature with the new cold coolant just added and would take longer than 10 minutes to get back up to operating temperature. So, you think getting hot coolant splashed in your face is bad? Check! 🙂 1 Quote Link to comment Share on other sites More sharing options...
NzP Posted October 17 Report Share Posted October 17 I plan to do this procedure tomorrow. I plan to drain over a drain plug, remove the thermostat, connect the housing back and apply about 15-20psi air pressure trough the expansion tank to get rid of all the old coolant. Then I will install the thermostat back, vacuum the system and fill it up with a fresh coolant. But the question: if I will remove thermostat - it's going to leak there because of no thermostat(like 1mm thick) should I make some gasket(from thick paper or a plastic) and put in next to the thermostat o-ring? Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 17 Report Share Posted October 17 @NzP That's a whole lot of unnecessary work removing the thermostat. The typical home size compressor can provide the pressure but not the volume needed to displace the coolant residing in the engine block - I used a leak blower which was more successful but also cant remove all the coolant. Flushing with distilled water and then adding concentrate to account for the remaining distilled water in the block is a more effective option. 1 Quote Link to comment Share on other sites More sharing options...
NzP Posted October 18 Report Share Posted October 18 (edited) probably, but I already bought premixed coolant and can't return it. So I am looking for the best way to push the old coolant out(I do have a vacuum tool to fill it). I can use a big compressor(like 20 Gal) but i don't think I need it because I will not apply more than 18-20psi at the time. I am still not sure about the best way: I have an air adapter to the reservoir, I can disconnect the heater core hoses, plug one pipe on the water outlet and provide pressure to the other one(keeping the radiator drain plug open), I can easily take the thermostat out... Edited October 18 by NzP 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted October 18 Report Share Posted October 18 (edited) Don't count me in on being a good input on a proper coolant flush. But this seems like a good opportunity to take it to Jiffy Lube and have them do it for you. I never use Jiffy lube for anything, but they seem to be on their game when it comes to this. Years ago, they did a coolant flush on my wife's Mazda 626 and it was well worth the money. Or take it to the dealer and hope they do it right? Edited October 18 by STBEAST Quote Link to comment Share on other sites More sharing options...
NzP Posted October 18 Report Share Posted October 18 I will not trust someone working on my car. I used to work as a car mechanic for years. Now I'm not sure which way is the best to get rid of the old coolant and looks like no one knows(here and YT). So probably I will drain 1 gallon and add 1 gallon premixed I got(it says fits for all cars)... 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 18 Report Share Posted October 18 4 hours ago, NzP said: it says fits for all cars That is definitely not the way to go. There is no one coolant for all cars. As @1004ron suggested, is the best way to go. Drain/fill with distilled water several times until you have mostly distilled water, then drain and fill with concentrated coolant. Depending on you engine, fill half the coolant capacity with concentrate. Between drain/refill cycles, make sure to run the engine until it warms up to ensure complete mix. 1 Quote Link to comment Share on other sites More sharing options...
NzP Posted October 18 Report Share Posted October 18 As I said - my coolant is already premixed. So if the manufacturer of that coolant says it works with all makes and models(which means I can mix it up) - someone would definitely sue them if it wouldn't work then. Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 18 Report Share Posted October 18 (edited) Could you tell us what brand and specific type of premixed coolant you intend using? . Edited October 18 by 1004ron Quote Link to comment Share on other sites More sharing options...
NzP Posted October 18 Report Share Posted October 18 I have got one canister of PEAK Full Force (water(7732-18-5), Ethylene Glycol(107-21-1), Diethylene Glycol(111-46-6), Denatonium Benzonate(3734-33-6) and Proprietary inhibitors) + 2 canisters of PEAK (free of 2-EHA, silicate, nitrite, borate, and amines. Compatible with any color or type of antifreeze and coolant.) Now I think if I could disconnect the radiator and the heater core, loop inlet and outlet(heater core) and apply water from garden hose to the lower or upper radiator hose inlet to rinse the old coolant out of the engine(instead of using the air - but I am still not sure if it works this way). Quote Link to comment Share on other sites More sharing options...
NzP Posted October 19 Report Share Posted October 19 (edited) Also I got another idea: - loop the heater core in-out; - remove the thermostat; - disconnect the lower radiator hose(from radiator) and put in a bucket with fresh coolant; - disconnect the upper radiator hose(from radiator) and put it in an empty bucket; - start the engine up and let the water pump do the job(I hope the engine will not seize working for 10-15sec). What do u think, guys? P.S.: seems like it will not work because of the water outlet inner design... Edited October 19 by NzP Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted October 19 Report Share Posted October 19 Nzp It seems you are going to a lot of extra work for a simple coolant flush but do whatever you feel you need to do. I don't understand why you can't return the pre-mix coolant you already bought UNLESS you already opened it? Quote Link to comment Share on other sites More sharing options...
NzP Posted October 19 Report Share Posted October 19 I think I am going to drain 1 Gal of original green(or blue) coolant(I tested it with a tester that has plastic balls inside - 2 balls were floating only which tells the freezing point is -15C) and will add 1 Gal of brand new PEAK Full Force (water(7732-18-5), Ethylene Glycol(107-21-1), Diethylene Glycol(111-46-6), Denatonium Benzonate(3734-33-6) and Proprietary inhibitors)- an AI said it will work but I don't really want to trust an AI. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted October 20 Report Share Posted October 20 Your 2009 was a transition year, from Gold to Dark Green. HOAT to POAT change. If there was one thing I wouldn't trust to AI is coolant in any Ford with the 3.5. I changed my coolant every 40,000 miles on my 2012 Fusion with the 3.5, and at 160,000 I had the water pump failure that filled the crank case full of coolant. You can't even say if it is conventional green or long life, just keep pasting in the formulation. Look up the Ford specification like WSS-M97B51-A1 or WSS-M97B55-A (your owners manual should tell you, and if it is like my other transition year cars, a sticker on the degas bottle, or a build date cut off) and see of the coolant you are trying to use, I assume the Peak Full Force (conventional or long life) wasn't tested, certified, or says it meets either of those specifications. 1 Quote Link to comment Share on other sites More sharing options...
