jhenkin
Lost keypad entry code
The owner guide says: "The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner’s wallet card in the glove box and is available from your authorized dealer." Well, I don't have this wallet card being referred to. Is there any way to retrieve this 5-digit entry code???
Share this post
Link to post
inside and under the plastic fuse box cover by the drivers left foot
Share this post
Link to post
This did not work for me. I guess I'll have to go to the dealer. :banghead:
Share this post
Link to post
My code number is on a wallet sized card stuck in clear plastic slot, on the back of the black pouch that holds all the owner's manuals.
Edited by martunes
Share this post
Link to post
This post happens at the perfect time for me, I love the internet.
Bought a 2008 MKX on Saturday and didn't know the code.
Search the internet, come to this forum and wa la I have my code in my fuse box.
Thanks all
Share this post
Link to post
*gasp!* Kirby, noooooooooooooooo!!!!!!!
You know I can't help it. It's a curse.
Glad you found the code. BTW - it's "voila", not "wa la".
Share this post
Link to post
Bumping this thread because my wife has just bought a used (ex rental) 2013 Edge Limited and the card with the Factory keyless entry code is missing. I see on this thread that, in past years, the code was on a sticker on the fuse box. I have read elswhere that this is no longer true for the 13's. Can anyone confirm if and where the code is physically located in a 2013 model?
Thanks
Share this post
Link to post
I finally found my code, in the fuse box area, but you have to be a real contortionist to get at it and view. It was located way up near the top on the right hand side of the panel. It took a few tries to get it to work, I tried it initially via MFT but found it just easier to do on the key pad itself.
Share this post
Link to post
So I found my code and during setup I chose the wrong pill and erased the factory code instead of adding. Am I off to the dealer or is there a work around?
Share this post
Link to post
Brings me back to the days of my used 98 explorer with no keypad code. After removing plastic panel in cargo area and using a retractable little mirror to reach all the way back to the wheel well, I was able to read off one number at a time. They literally don't want you to find that number.
This should be a pass the kindness on type thing!! If you trade your car in give them the darn card that has the number!
On the 16s a simple engine start/shut off with both fobs, one at a time inside the center console will cause the sync 3 screen to display the factory code. At least ford has realized what a pain getting a used car is to use this feature
Share this post
Link to post
Its impossible to erase the factory code or ever reprogram the factory code, you can only add codes. If you have myford touch then it's in your setup menu. If you don't and have basic sync, it's up under the dash where your left foot sits when your driving.
Share this post
Link to post
On my 2012 Edge Sport I removed the cover that hides the fuse panel by your left foot while in drivers seat. Once cover is removed it was on the upper right corner of the fuse panel. it was 5 digits with a letter at the end. hope this helps.
Share this post
Link to post
Guest 16FusionTitanium
Yes, great of ford... but What of you only have 1 Key Fob... Not so good then, lol, also my 16 Fusion doesn't have a fuse box by my(Drivers) left foot!!! So... Now what??? Maybe the spare tire whell (hole) in the trunk?!?!?! I'm gonna look there next...
Share this post
Link to post
First, this is a forum forum for the Ford Edge, not Fusion.
2nd, if retrieving the code was very easy, then your vehicle would become easily accessible by anyone who had it for a brief drive. Like a valet or car wash.
3rd, you can always go to a dealer who can get easily.
4th, you can use ForScan to retrieve it.
Share this post
Link to post
Yes, Yes it is... I relized this I was signing up, when I Googled it I somehow clicked on the Edge Forum... So I went to the Fusion Forum and they don't have a post for this issue...
I also understand if it was easy it would be great right now, but not so much when someone else van also changes it... then we would be complaining that it's to easy for others...
With that note I know why my car didn't come with its little wallet card... I bought it used after being a rental car... Not something you want renters to access either... I'm sorry for the interruption in your forum, this is definitely a post queation that will be forever asked and discussed...
Share this post
Link to post
You can’t change the factory code - only add additional codes.  You need 2 keys anyway - go get another one and you can get the factory code.
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
