    343
  1. Replace the fans with OEM parts. There is a good write up that should be pinned. If not use the search function.
  2. No it won’t stay in 1st gear. When you put it in S it’s still in automatic mode until you hit the paddles. It just shifts later and keeps RPM higher for better response.
  3. Put the shifter in “S” but don’t use the paddles.
  4. You forgot the simplest solution - don’t shut the door all the way.
  5. That delay is most likely the electronic throttle, not the turbo. There is no turbo lag to speak of.
  6. I’m going to laugh when you guys that turned of the horn honk end up stranded because someone walked away with the key and you didn’t realize it.
  7. That used to be the case years ago but they changed it. You can go to any Ford or Lincoln dealer for warranty service.
  8. It could be the brake booster but the noise would indicate the ABS was activated and I didn't think the booster would have anything to do with that. Especially if it returned to normal when the noise stopped.
  9. More common when turning but still possible. I wouldn't worry if the brakes are working ok now until it happens again.
  10. I don't remember what it feels like when the ABS engages.
  11. Sounds like the ABS engaged. Is it possible you hit a slick patch on the road? If not it may be a flaky wheel speed sensor.
  12. I don't think Sync 3 supports AA or CP over Bluetooth yet. Requires a USB connection.
  13. Not sync - sync services which nobody seemed to use anyway.
  14. Why is it a 10 step process if AA is already running on your phone and you just plug it in after charging it inside at night?
  15. You won’t get a mileage increase.
  16. Lincoln owner says mine was updated via wi-fi to 3.0 a few days ago but I haven’t had a chance to check it.
  17. Be careful with Rain-X if you have rain sensing wipers. Don't put it over the sensor behind the rear view mirror.
  18. They either have to play hard ball or permanently lower their prices or both. I think everybody caught on to the threaten to cancel to get the good rate trick.
  19. Check the CHMSL (center high mounted stop lamp). On my 2006 Fusion one tail/brake light stopped working when the chmsl went out.
  20. That's not true. They generally allow copies for backup purposes but not to simply share with other people free of charge - that would defeat the purpose of selling the documentation in the first place. If they wanted to give it away for free they would make it a free download. I won't delete the topic but we can't support this activity going forward so please take it to PMs.
