candurin
Everything posted by candurin
HIDEXTRA.COM ????
candurin replied to BLACK PEARL's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
8000k has to look horrible. That's damn near purple. -
You'll want the harness with a 55W kit. That's a lot of stress on the factory wiring. But, be cautious as the DDM harness is crap (mine melted after only a week). You'll want to get a quality harness like one from TRS (Morimoto).
Damn. I was happy with my 3.11 for workgroups cup. Beat me by a few years. But, I did have the satisfaction of sitting back and taking a sip of coffee after just pressing the turbo button on my pc (dx66 anyone?). Minesweeper didn't really run any faster.
Norm, really the main causes would be loose bulbs (but if I recall you made it quite clear you seated these properly in previous posts), loose o-ring gaskets on the bulb or a loose headlight housing. Is it very drastic? Are you driving on bumpy roads or does it happen on flat, straight roads as well?
I've used both the DDM and TRS Kit (I've used DDM for well over 15 years in a half dozen different cars, ever since they were Apexcone). I've had some crap DDM kits and some that were bulletproof. Having said that, I would completely recommend the TRS kit over DDM any day (there service alone is worth the extra $$). I noticed you were in Montgomery county. I am in Malvern 4 - 5 times per month (and will be next week). I'd be glad to show you my HID setup.
Primed grill, plasti dipped trim (looks as good as when I dipped it months ago).
Here's one more http://www.fordedgeforum.com/uploads/monthly_08_2013/post-22533-0-92172800-1376057397.jpg
Headlights in my 2013 EDGE
candurin replied to The Ripper's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
No problem. Also, take into consideration that if you go with the 55W ballasts, the color temp of the bulb you select will appear warmer. I.E. If you go with a 5000K bulb (all bulbs are 35W) at 55W, then it will appear to look 4300K (due to the "overdrive" of the bulb and warmer hotspot in the center of the beam pattern). 6000K looks 5000K, etc. I highly recommend 5000K with 55W ballasts. They look OEM and a perfectly crystal white color.- 79 replies
- Headlights
- Crappy
(and 2 more)
The kit has everything you need to install. http://www.theretrofitsource.com/product_info.php?products_id=3957- 79 replies
- Headlights
- Crappy
(and 2 more)
Use a rag between the needle nose pliers and the relay. Just needs some wiggling to come loose.
It sucks about the issues your having. I've been using the identical kit for over a year and a half (HD relay harness) and my auto function has always worked. I am using the positive and negative terminals on my battery for power connections.
- 38 replies
- Hid
- remore start
How To: Remove Front Bumper; 2011-2013 models
candurin replied to Cellbine's topic in Exterior & Body
They were a pain, but I had to do it as I replaced my chrome grill with a black one. If your really good at masking, then you should be able to PD it without removing the inserts.- 32 replies
- remove bumper
- remove front bumper
- (and 3 more)
Headlight rear caps
candurin replied to normcloutier's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Just search for: BT4Z-13N019-A Looks like this is cheapest: http://www.ebay.com/itm/FORD-BT4Z13N019A-GENUINE-OEM-FACTORY-ORIGINAL-PROTECT-CAP-/111241520146?pt=Motors_Car_Truck_Parts_Accessories&hash=item19e682e412&vxp=mtr You can get it less at levittown ford: http://www.levittownfordsupercenter.com/repair-parts.php (just search for part number). -
I really hate to ruin your holiday (hopefully you read this on Thursday!). But, you did receive the 35w ballast. 3Five (SS) is their 35w: http://www.theretrofitsource.com/product_info.php?products_id=21742 5Five is their 55W ballast: http://www.theretrofitsource.com/product_info.php?products_id=21743 I believe you mistook the SS designation as 55.- 79 replies
- Headlights
- Crappy
(and 2 more)
Different LED DRL
candurin replied to Brandon Walker's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Sure. Lots of us have them. Except we purchased them here: http://www.daytimebrightlites.com/Daytime_running_lights.html
