omar302
    230
Everything posted by omar302
  1. I meant keep the engine running. While you are stopped waiting, do you keep the engine running for long periods of time? Try driving a long road, like 10km straight at 90km/h, what would your average mileage be?
  2. That speed limit feature is part of the Ford MyKey system. It will not have any effect on the mileage. On the other hand, the slower you go on the highway, the better the mileage should be. Your mileage is bad, but, do u do a lot of traffic driving? Do u leave the runnin running while stationary? These will badly effect your milage.
  3. That seat memory thing also happens in my MKX. The courtesy wipe, I first saw it in a 2007 Toyota Avalon. The faster you were driving, the earlier the wipe came until you would reach a speed were it would not come anymore. Speaking of wipers, another nice feature is the reverse wipe. If you your front wipers on, as soon as you reverse, the rear wipers makes a wipe (even when they are off). A feature that is also controlled via the left screen settings.
  4. In case of none wooden steering wheels, that part is also heated.
  5. Yes, master reseting will delete all your data. Its not a format cause you dont have to reinstall anything, but kind of like a restore to factory state.
  6. You cannot reflash yourself. Only the dealer can. Did you check the settings? They might have been turned off. If not, perhaps try a master reset?
  7. I just noticed that the gear shift indicator on the center console does NOT indicate which position is selected. Is that normal? All positions are illuminated white, I thaught that the selected position would be orange. Is that normal?
  8. Your car has a regular key, so the car should start even if the battery is dead! Also, since the door lock was opened using the FOB, the battery must have been ok. Did you try the same key again later?
  9. The oil life indicator is like a calculator that takes milage, time & engine operating conditions into account to calculate oil life. The system does NOT actually measure the oil life by a sensor. For those who would like to go for a 5000 miles (or six months) intervals, simply adjust the Oil life to 50% after an oil change. As for the other services to be performed, what I understand, you have to do them with any oil change interval that comes within 3000 miles, but if you reach the milage specified for any service, but you do not have any oil change requirement within 3000 miles, then you should perform that service without waiting for an oil change.
  10. Are you sure you dont have anything loose placed under the cargo floor, around the spare tire?
  11. I have a HTC One X with Sense 4+, so I geuss it should be a simliar experience to the DNA. Everything works except Contact Photos & Sync always tells me that the phone does not support Text messaging even though messages I receive are received by Sync & are even read out loud by it.
  12. I agree with Edgieguy, there is still now way to add factory NAV after the car leaves the factory. It is NOT a simple SD card issue as many people were led to believe when they purchased their MFT equipped vehicles.
  13. You can read about it in this thread. The link was posted there.
  14. I know its not for an Edge, but there was a person who installed OEM HIDs from a Taurus SHO to his non-HID Taurus Limited. The differences in the wiring harness might give you indiciation to what might also be different in the case of the Edge. http://community.webshots.com/album/576444195utMbwN
  15. The front windsheild is soundproof, but also the front doors should have them. But there is no "SoundScreen" writing on them, roll down the side windows & the look at edge or feel for the double layer. The rear doors have normal single plane windows, so you can compare to them to the fronts to find out.
  16. Check your front windows, are they made of two layeres each? You can see it from the top of the window, if it is then you have sound insulating side windows. I am geussing that the Limited has them, but not the SEL, if so, this might explain what you experienced.
  17. As per the 2013 Edge Source book, the sport is rated as 19/26 for FWD and 17/23 for AWD.
  18. You have to check your Owner's manual & the oil dipstick to determine what oil to use. My 2011 MKX speciies Mercon LV for the transmission fluid. Note: Mercon V is specified for the Power Steering fluid.
  19. I have had the update since November & never seen an inverted image.
  20. You have to look around under the dash. It is going to be hard to find out whats wrong without knowing what system is installed and having its installation/operation guide.
  21. Ford moved to NAVTEQ for maps, I don't have NAV in my car, but I believe that part of the "Performance Upgrade" was the switch to NAVTEQ maps.
  22. You can find the link to the TSB in the first post here. It recommends a Master reset only before the update.
