Everything posted by omar302
When ordering a new car, you should set up your priorities as you see fit. Since HID is important to you, you should have ordered it. Retrofitting HID is not good, blinding to other drivers and illegal in many places. For a proper HID upgrade, you should get the complete headlights of a factory HID Edge setup, which would cost a lot and makes the 301a package's cost a bargain. Furthermore, since you just "ordered" the car, many dealers can still accommodate changing the order before receiving the vehicle.
2011 MKX Certified Pre-Owned MFT/MLT Sync Update
omar302 replied to aford15's topic in 2011 Edge & MKX
Some 2011 models (maybe some 2012 too?) has early build software that made necessary for them to update (the Performance upgrade "Version 3.0.2") through a Dealer only. -
To confirm what Dingo said, if you the signal on, the signal noise will go away while the seatbelt chime is on.
- 35 replies
I know the MKX has it on the front windows only plus the vista roof. You just unlock using the fob and keep holding until they start rolling down. The feature is called "global open" by Ford. There is also a setting in the left cluster toenable or disable it.
Normal. Its even mentioned in the Owners Guide under "Power Windows": Though to be honest, it is really bad compared to my previous cars. Sometimes it even kind of whistles.
The Ford Headrest DVD's are quite expensive. How old is your daghter? My 2 & 6 year olds usualy are happy playing their tablets in the car. They can watch movies & even play games. And the tablets are much cheaper.
Manufacturer recommends 35 PSI. I believe the TPMS comes on at around 28 PSI. If your driving high speeds, it is better to go for 35 PSI. If your driving in the city, with bad roads like where I live, I would suggest 30 PSI & the TPMS will not come on.
Home Screen Wallpapers -- What do you use?
omar302 replied to Cellbine's topic in Audio, Backup, Navigation & SYNC
Since the 3.02 update, I hated the fact that the default Lincoln star wallpaper was not centered. Finally I was able to get hold of that image & was able to modify it to center the Lincoln Star. Also, I found one image that I liked in a Focus forum, so I just modified it to center it in the updated MFT/MLT screens & added a Ford/Lincoln Logo. I have added a .zip file containing all images because the pictures are changed when attached to the post. MLT - MFT.zip -
Anyone have an MKX ('11-'13) with 18" wheels?
omar302 replied to Limited59's topic in 2013 Edge & MKX
^^ Simply buy it with the 20" wheels & then put them up for swap. There are many who are willing to exchange their 18" wheels for the 20" wheels. -
It states in the manual that the oil life meter can reach up to 16000 km or one year. The manual recommends following the oil life meter. It seems the sticker you are refering to is just the dealer's way to get to come more often! By the way, even in extreme heat like in the Arabian Gulf, GCC, Ford recommends a 8000 km or 6 month interval (whichever earlier), basically a 50% oil life meter.
Dingo, few question if its not too much; Is there any difference in wind noise due to the smaller side view mirrors? Can you confirm, the high beam turn on function on the '13 is by pushing the turn signal stalk "away" (towards front of vehicle) where as in the '11 (like my MKX) is by pulling the stalk towards you past the detent? (both will have the "flash to pass" by pulling).
Remote Start Kit Series 200 Plug & Play
omar302 replied to rsucre's topic in Alarms, Keyless Entry, Locks & Remote Start
Your vehicle comes with an Integrated Keyhead Transmitters (IKT), basically the key & FOB are a single unit. If you want Remote start+ Alarm, I would suggest any of the following two routes: First option: Install the Remote Start System - 100 Series Plug-N-Play, which would replace your "IKT" with another one that includes a start button. And install the Ford Vehicle Security System - Alarm which would Arm/Disarm using the same "IKT" that unlocks/locks your doors. Thisoption, if possible, would give you the best "Factory look/function". Second option: Install the same Remote Start Kit Series 200 you mentioned, but you can buy regular Ford PATS key (without the FOB integrated) & use it with the new FOB from the series 200 kit. -
From the 2013 Edge Owner's Manual: So a hood switch will be installed if the vehicle is equiped with the "Perimeter Alarm".
First 5,000 mile service -- what kind of services do I need
omar302 replied to Jessey's topic in Buying, Leasing & Ordering
A tip for those who like a 5000 mile oil change interval is to reset the oil life meter to 50%. This way you would get a reminder at around 5000 miles or 6 months, give or take a few. -
Congrats. Hope you enjoy your new ride. -
This seems to be the same issue in late 2013 builds of the Explorer, 2011-2012 and early 2013 did not have this, its supposed to be a reminder that the vehicle is left running without a key inside. As far as I know, there is no way to disabble it. You can try to check with your dealer if there is a way for them to disable it.
Is that while driving at 90 Km/h? Straight line? I mean not going an uphill? If so, then 13L/100 Km is high. You should get 10 or less. You say this is as displayed, have you ever calculated your economy manualy to check if the display is showing correct info?
Where we live, in the GCC counties, we have extreme city driving. It is pretty normal in a single commute to accelrate from 5 to 60 mph 10 to 15 times for a short 10 minute drive.
Is there an indicator light for head lights on?
omar302 replied to RJG's topic in Interior, A.C., Heat, Interior Trim
The indicator shown in OnTheFence's picture is part of the LCD screen, so it might be a new program/update of the cluster, not an actual hardware change. I guess you can try and politely ask your dealer to update the cluster software (wich is not part of the MFT/MLT). -
I think it is because you have the system on Auto (for the air flow direction) so it might be that the system sometimes transfers the air flow to "Defrost" or "Defrost+Floor" & hence the recirculation turning off. Next time, try setting the air flow manualy to your preferred setting and test to see if recirculation turns off.
