enigma-2
    303
  1. I had a blue 98 Sable where the leather on the steering wheel wore through. I was able to locate a used one in excellent condition from a junk yard over in Ohio. Had the local dealer install it. (Know how had it is to find a steering wheel for a 1998, blue Mercury Sable?) Anyway, I used a steering wheel cover and hated it. Call it OCD but I knew it was there, hiding behind the cover, edging me on. Couldn't stand it, had to get it replaced. .
  2. ?good to hear. How did you determine the rotor was "egg shaped"?
  3. Thought it only ran in heat mode was when you selected winshield defrost mode. Spoke too soon. You were right. It does run automatically in the auto position. Never really checked into this before. Also in defrost and floor/defrost modes.
  4. Weather {{{finally}}} warmed up here in the Great Lakes. Opened the BAMR tonight and ssssssqqqqqeeeeeekkkkkk. Sprayed the tracks with lube and nice and quiet and smooth again. I use WD40's Dry Lube for this. Works good, only needs a spray 2x a year.
  5. I would suggest the All Wheel Drive (AWD) forum.
  6. As you didn't chage them, did you check the pads? Kind of sounds like a bad pad.
  7. I'm currently running P245-50R20 Bridgestone Dueler H/L 422 Ecopia's on my MKX. Second set I've had on this car, and well satisfied. Quiet, smooth, long life, all-season. Little expensive at $250/tire but they are always offering a rebate. Couple that with Ford's rebate of $50 and it comes down nicely. One trick to watch out for, are the customer reviews. Most are from people who just bought the tires and have only a couple hundred miles on them. Tirerack.Com is loaded with these reviews. Amazon.com has reviews with several thousand miles on their tires. One particular tire I was certain I was going to replace my last set, had glowing reviews on tirerack.Com. But also checkled Amazon and seen where they have a very short life, as little as 10,000 miles in one cae. (I had also experienced the same thing with a set I had years ago, same brand). Great in the beginning, but hard, loud and rough after 20k miles. Haven't found this with Bridgestone. BTW, I looked up these tires on tirerack.Com, printed out the page, took it to local Ford dealer, he gave me his spiel on crappy tires for way too much, showed him the printout and mentioned I could have them shipped another local dealer, and he instantly matched to price. Got my Bridgestone rebate and my Ford rebate. Plus the job was done right the first time.
  8. Sounds like one of your tires is out of balance.
  9. I remember reading years ago that all systems leak slightly over the winter because the seals are not being lubricated and shrink. They re-expand and seal after you start running the system. I had my radiator fan assy replaced year or two ago and they checked the a/c system for pressure loss. They found a very small amount lost and topped it off. Said it was normal loss.
  10. One thing that a couple of dealers found was the wiring harness which connected to the SD socket had loosened and unable to access the card. Try looking at the connector to see if it's tight.
  11. Believe yours is on tbe firewall. Should be easy to find. Heres a video that might help.
  12. We don't sell a product. We sell a service. If you think it's not common, your fooling yourself.
  13. Actually it's over 100%. If you came to me and asked for a quote, I would find out which of my competitors you're with, and beat that price. If your new, I would find our who else you talked to and set a profit potential.Warranties are based on history and sales margins.
  14. If it one of those all-in-one fobs, it has to be programmed by a dealer (or locksmith). I'd have him call tbe original lock smith and ask him.
  15. I remember reading in another forum where the dealer found a loose connector on the card socket. (Not a big deal to check yours).
  16. Cloning the SD card will not work. They are encrypted with a special key that the system can read, but prevents cloning them. (Otherwise theyd be selling for $10 on Ebay.)
  17. Ummmmm, yea, but it involves a sledge hammer and a lot of vasoline. Seriously no, I would run it to the dealer. May involve a reload of software. Do you have an older card you can try? (BTW, this IS an OEM card, and not an Ebay clone, right?) And can you confirm that you did a Master Reset?
  18. I would try roving the card and clean the contacts with an alcohol wipe. Before reinsertING tbe card, stick a vacuum cleaner hose up to the opening and suck out any dust, dirt, doggie hair, etc. that may have gotten in there. If this doesn't work, remove the card and try a master reset.
  19. What the market will bear. My company has several different hourly rates. We will match our competitors (if we have to), else the rate is the rate. Simple business.
  20. Well, there are others .... here's one with all the bells and whistles. https://www.sonicelectronix.com/item_151293_Kenwood-eXcelon-DDX9905S.html
  21. Noticed last week when I arrived at a factory to conduct an inspection that the flexible rubber gasket that connects to a small, thin rail, on the underside of the sliding moon roof, was free and disconnected (only on the drivers side). It also had the appearance that it had been squashed in a twisted "S" curve, indicating that it had been disconnected for some time (getting squished crooked when the roof was closed. I easily reconnected the gasket to the rail and noticed that it became disconnected as the roof was nearly closed. I *think* that the unnatural curve in the gasket is putting too much stress on the "crimp" connection and it just pops off the rail. Currently I have it closed with the gasket connected, hoping that this will re-straighten the curve out of the rubber, but time will tell (may have been disconnected for years afaik.) Anyone have any other ideas as to what I can do to force the rubber gasket back into a straight alignment? Tried over bending the rubber by hand, thinking it would begin the retake the proper shape, but it continues to take the S shape. Thinking of using a hair dryer to heat the rubber, but the old doctors guide, "first do no harm".
  22. Really I think it was intended to send a record to the dealer of record to help generate additional sales.
  23. https://www.sonicelectronix.com/item_143985_Pioneer-FH-S700BS-SiriusXM-Tuner.html?id=143985&Product_page=2&afg%5Byear%5D=2011&afg%5Bmake%5D=Ford&afg%5Bmodel%5D=Edge&afg%5Bbody%5D=&afg%5Btrim%5D=SEL&afg%5Baudio%5D=with+Sony+Audio+System%3B+with+8%22+LCD+Screen&afg%5Bproduct_model%5D=
